Question about Samsung HL-T5076S 50 in. TV
The problem with my samsung model hl-t5076s there is three flashing lights one red an two green. The red light flashing is called stand by temp an the two other green light one is time an one is lamp
    Top Expert:
  • Samsung Master
  • 75,025 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Dec 20, 2016
SOURCE: Samsung dlp model hl-s5086w. The
fixed it. my ballast was bad.
Posted on Jul 16, 2008
  • 147 Answers
SOURCE: TV won't stay on. Green & Red light timer-lamp (Green) stand by/temp (red) flash.
Most likely needs a new lamp. Easily done yourself.
Posted on Apr 15, 2009
  • 8617 Answers
SOURCE: I own a Samsung HL-R5067W 50
The color wheel needs replacing. Thats causing the whining and it will also make the lamp light blink.
Posted on Sep 20, 2009
SOURCE: my samsung dlp hl-s5686w turns for a minute video
I'm having the same problem. Tried several things from dusting the inside with an air blower, removing the bulb and putting it back in, making sure the side panel is installed correctly and none of this has kept it from shutting off. Samsung's site says the three lights flashing means replace the bulb but I'm not buying it. My picture looks perfect....jsut that the TV keeps turning off. It all seems like a heating problem but my fans are still working. I'm scratching my head thinking what to try before forking out $150 for a new bulb.
Posted on Aug 15, 2010
  • 5138 Answers
SOURCE: I have a Samsung HL-S4266w TV When I plug in tv I
You need to replace the Color Wheel.
Encompass Parts Distribution 1-800-638-3328
Samsung 1-800-844-7871
Posted on Oct 25, 2010
I have a Samsung HLT5076S DLP Tv and when I turn it on I get a blinking Green Light for a couple of Mins. Then after awhile all three light start to blink. The standby light is Red and the timer and the...
It is the lamp but try to check the filament of the lamp if defective because if the color wheel is defective you will hear a whirring noise. Try to check the lamp if defective replace it and if you replace the lamp you should reset the lamp hour meter, feel free to send feed back good day and best regards.
Aug 22, 2011 | Samsung HL-T5076S 50 in. TV
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
When i try to turn on my tv the green power light will flash for about a minute the it will turn of and go to red then try to turn back on automatically no picture will ever come up because the green light...
i had my tv on for about two and a half hours then it will shut of and the temp light will flash, I think its overheating but not sure if its the fan or color wheel or both, wtf can somebody please help?
Dec 26, 2010 | Samsung HL-T5076S 50 in. TV
I have a SAMSUNG model HL-T5076S flat screen TV. A blue light stays on at the bottom of the set after I turn the TV off
Acording to the user manual there is an indicator light that Blinks and turns off when the power is on and lights up
in stand-by mode.
This information can be found on Pages 6 & 7 of the Owner's Instructions wich can be found here:
Sep 16, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
My samsung HL-T5076S won't power up.
Ok, i just realized you stated that you get no stand by light. this is a dead power supply board. you will need to replace this power board in order to restore proper function in this unit.
May 29, 2009 | Samsung HL-T5076S 50 in. TV
Samsung HL-T5076S 50 in. TV Logo
23 people viewed this question
Jerry Greenberg
Jerry Greenberg
