Why would our unit pop a circuit breaker after running about seven minutes?
    Top Expert:
  • Heating & Co... Master
  • 41,674 Answers
Inadequate wiring for the current draw of the A/C, especially while starting.
Posted on Dec 20, 2016
  • 2692 Answers
SOURCE: furnace keeps tripping circuit break
Furnace. To confirm use an Ampprobe or other brand ampmeter and see how much current is being drawn. If it is more that 80% of the breaker rating, it si for sure the Furnace.
Posted on Jan 10, 2009
  • 30 Answers
SOURCE: Hitachi RAS09UH randomly pops 15A circuit breaker
Two things that you could check: 1) If you have access to an ampmeter, determine if the unit is drawing over over 14 or 15 amps, 2) replace the suspect circuit breaker in case it is beginning to go bad. Breakers only trip for overcurrent conditions or failure of the breaker itself. If it is pulling close to 15 amps, then it could heat up over time and trip.
Posted on Jul 09, 2009
  • 396 Answers
SOURCE: Central AC unit replaced breaker trips after running 20min
Unit is drawing two may amps for the breaker. Could be compressor sticking.
Posted on Jul 22, 2009
  • 582 Answers
SOURCE: CENTRAL AIR UNIT IS TRIPPING BREAKER
IF YOU ARE NOT ELECTRICALY EXSPERIANCED I WOULD FIND SOME ONE YOU KNOW TO CHECK THE FULL LOAD AMPS ONE THE UNIT AND USE AN AMPROBE TO CHECK AND SEE WHAT AMPS ARE BEING DRAWN. SOUNDS LIKE YOU MAY HAVE A WEAK CONNTACTOR THAT IS CAUSEING THE PROBLEM
Posted on Aug 10, 2009
SOURCE: Breaker breaks
This unit may have an internal overload mounted on top of the compressor. You would have to get to the
compressor to find out and it maybe faulty. That may
explain why the compressor comes on later on, this
overload protects the compressor from getting hot.
When you trip the breaker and then reset it again only to see it trip again almost sounds like a direct short or loose wire. It could also mean that your
capacitor needs to be replaced or that you need a hard start kit and the unit needs a good cleaning.
Try just operating the fan and see if it trips the breaker, if it does then either the blower motor is bad
or it is still the capacitor.
Posted on Jun 25, 2010
Testimonial: "The blower fan works fine. The breaker only trips when a load is put on it, but not always. I think the overload protecter could be the problem. Thanks."
Kenmore 80 series dryer keeps tripping breaker after it runs for 5-10 minutes
First, see if you get the same result when you run the machine on "Air-Fluff." If you don't pop the breaker on Air -Fluff you know the problem is originating in the heat circuit, get inside the machine and inspect the wiring for crispy/burned terminals and the heat element for damage or contact with the housing... If it does pop the breaker on Air-Fluff: Inspect the terminal block on the back of the unit where the power cord is bolted on (with the unit unplugged), look for any scorched spots- if that is clear, remove the outlet cover and inspect the wire connections on it for scorching (with the circuit break off). Can't be more specific without a model #!
Help Me Find My Model Number RepairClinic com
Jul 04, 2016 | Kenmore Dryers
Tripping circuit breaker
That unit shows that it takes 15 or 20 AMPS to run. What is the breaker amperage on the circuit where it is plugged in? Is the breaker a GFCI? You can tell by looking for the two buttons on the circuit breaker or the outlet.
Jul 18, 2017 | KitchenAid KCMS1555RSS Stainless Steel...
I open the box and plug the unit into any outlet, the outlet's circuit breaker pop-off within a minute. I turned the knob to off position before plugging into outlet, and the circuit breaker still pop...
There is something wrong with the unit, it should not trip the breaker.
You are going to have to send it back.
I tried to see how many amps the unit draws, but there website is poor
and I don't even see a way to get the manual if you needed one.
Feb 07, 2010 | Wolfgang Puck BCGL0035 Indoor Grill
Unit comes on and runs for 5 minutes, the circuit trips off
30 is the correct size breaker for this unit. It sounds like there is a grounding issue going on in the system. Or off of the Thermostat. Something is grounding out causing the switch to trip. Are you running #10 wire to breaker and the unit? If not you will need to increase your wire size
Jan 03, 2010 | Dayton D-F79 Electric Space Heater- the...
Jul 09, 2009 | Hitachi RAS-09UH Air Conditioner
Dishwasher pops the circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Jul 01, 2009 | Whirlpool GU1100XTLB / GU1100XTLQ /...
RE: Roper Electric Dryer, front load
You have a ground fault or short . Disconnect dryer and remove small panel that holds the cord. Check if any wires are frayed, loose or touching any other metal objects.
Jun 29, 2009 | Dryers
Reddy 10 breaker pops
check amp draw on unit if not high amps replace breaker
Jan 26, 2009 | Reddy Heater RLP100 Portable Forced Air...
Furnace keeps tripping circuit break
Jan 10, 2009 | Haier Energy Star ESA3183 Air Conditioner
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
