Question about Minolta bizhub 350 Black and White Copier
I HAVE A KONICA MINOLTA BIZ HUB 350 I PUT TONER IN AND TURNED MACHINE ON BUT THE SCREEN IS BLACK. POWER IS ON BUT WILL NOT MAKE COPIES OR RECEIVE FAXES WHAT IS WRONG
  • Minolta Master
  • 6,680 Answers
Check the contrast / brigthness control
Posted on Mar 12, 2017
firecontrol7
  • 6680 Answers
SOURCE: konica minolta bizhub 350 error code c5352
Cooling Fan fault. To clear open and closer the front door.
Posted on Apr 04, 2010
canontech
  • 1219 Answers
SOURCE: my konica minolta 2300 prints purples instead of
it could be problem in color registration.Try to do color adjustment, but also check the trnsfer belt and drum
Posted on Jun 15, 2010
xeerie
  • 347 Answers
SOURCE: Put in new toner into KonicaMinoltaBizhub200,says exchange toner
Machine is still saying to exchange toner because toner is not feeding into the machine. to supply the toner always do this, 1-insert the new toner bottle in the toner section and close the cover. 2-Press "Utility/Counter" Button. 3-click on "USER CHOICE" or "USER SETTING" 4-click on "Toner Supply" 5-Toner bottle will start moving and hence the error message will not appear again.
Posted on Jul 06, 2010
  • 20 Answers
SOURCE: My minolta 1083 is making black copies ,The drum
you need to clean out the drum unit of waste toner than probably have to replace the cleaner blade.
Also check to see if there is a tension spring employed to add friction(since this is a phase - out model, I'm guessing there is), you might have to modify this spring to add tension to the cleaning blade support plate.
Posted on Feb 23, 2011
firecontrol7
  • 6680 Answers
SOURCE: di152f-cannot receive faxes.
clear the memory then in service mode
METER COUNT
STOP00 STOP01
PRESS 11
PRESS THE START KEY UNTIL CLR appears
THE PRESS the START key to blank it out the in will reappear
POWER off the machine wait ten seconds and power on
Posted on Mar 01, 2015
I was changing the toner of Konica Minolta biz hub 163, and it shows a message that reads service call C0070. Please, what will I do to continue my work?
Sir/Mam,
Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KNUB on the side of the bottle is damage put a new one in. That KNUB is what the toner motor uses to turn the bottle, if it damaged you get a code. If that does not work, you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad.
Jul 13, 2016 | Konica Minolta Office Equipment & Supplies
Why are copies on konica minolta biz hub 200 light
you said copies how about internal test page?
if in copies only you need to clean the platen glass
Apr 25, 2014 | Konica Minolta Office Equipment & Supplies
There is an error code c-2558 showing on my machine konica minolta bizhub c452 please do let me know the proper remedy for it ASAP
Abnormally high toner density detected Black TRC sensor-
1. Correct the TRC Connection on the underside of the imaging unit if faulty
2. Reinstall black image unit
3. Change image unit
4. Change PWB-M
5. Change PWB-MFP
you can try # 2 then run 20-30 sky shops (copies with lid up to make black copies) put a white piece of paper over lead edge section of copy glass so you are only making 1/2 black copies if you don't the copy may jam in the fuser due to excess toner. after running copies turn machine off for 10 secs to reset and power backon. if problem continues I would change the image unit.
Aug 21, 2011 | Konica Minolta bizhub C250 All-In-One...
Wanted suitable konica minolta black and white copier to be installed in a school
First for a school you will need to know the volume of copies you are going to use per month.Then go from there, there so many segments.For example 30k to 40k per month would put you in a segment 4 something like a konica Minolta Biz Hub 601 or Biz Hub 750
Sep 07, 2010 | Konica Minolta Bizhub 222 Black and White...
Konica Minolta dirty copies
remove the filter and housing from the i/u and vac out the spilt developer, do the same on the underside, if background/halo is still there increase the seconary transfer value by 2 for plain paper
Jun 11, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica/Minolta biz 350 C2557 after replacing DV unit and drum F8
tha minolta di3510 developer unit looks the same as the unit for the konica minolta bizhub 350 but the toner sensor in the minolta unit uses a different voltage range for the toner sensor and it will throw this code make sure you have the correct unit for this machine also you can try this
go back into tech rep mode and change these settings:
select tech rep choice mode
select printer tab
select atdc sensor gain
set the value to about 165
then back all the way out to the ready screen and power the machine off then back on and replenish toner in the user management screen.
Apr 22, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Biz hub C252
YOU CAN RE-TONE THE MACHINE BY ENTERING SERVICE MODE SELECTING IMAGE PROCESS ADJUSTMENT AND TCR SUPPLY SELECT THE COLOUR THAT IS DEFICIENT AND RUN THE SUPPLY JUST ONCE. BEFORE YOU DO THIS CHECK THAT THE SEALING STRIP ON THE TONERS HAS COME AWAY AND NOT STUCK OVER THE HOLE HENCE STARVING THE MACHINE OF TONER.
Apr 17, 2009 | Konica Minolta Office Equipment & Supplies
My bizhub 350 is starting to make " dirties copies"
Proper service and periodic maintenance is required for your Biz.its drum unit's life is 1 lac copies.
Mar 12, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Jan 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Minolta bizhub 350 Black and White Copier Logo
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
