I have a CD-RW that has files on it currently but it was originally written using a computer installed with windows xp which mapped it to a CD-MRW and will not allow me to reformat
Please advise if there is a way to do a full blank format on this without purchasing software in order to do it
SOURCE: I cannot format DVD-RW
I had to download the latest firmware (rev. VS0M) for Lite-On DVDRW SOHW-832S. This fixed the problem.
Posted on Jun 23, 2008
SOURCE: dvd/rw
one possible way of solve this problem is remove ur nero and install latest version of nero........... if this option is not fix the problem means defenetly that is lense problem.. so give one service to ur drive u will get the solution........ okeeeeeeee........... bye......!!!!!!!!!!!!!
Posted on Jul 06, 2008
mumma_1
  • 903 Answers
SOURCE: my equium ea60-155 needs to be reformated ; can i use xp install
Loading XP back on isn't the problem, it will be the chipset drivers that you will need for your onboard graphics, sound etc... before you format and load XP back onto your laptop contact Toshiba for the chipset drivers for your laptop.
If XP is causing you problems, why no repair the verison you already have on there? If you put the XP disk in when given the choice to press enter to install or 'R' for repair. Press R. It will replace any corrupted files to your system with new ones.
I hope this helps.
Posted on Nov 11, 2008
SOURCE: Data Becke30,000. Business Card software I can't reinstall the CD
If you did not go to Start/Settings/Control Panel and deleted it from there....You can try the following....
1. Go to the desktop trashcan and see if the icons for the
software is there. If it is highlight rightclick and select restore.
2. Launch Windows Explorer, select the C: drive if it asks for
permission to display the contents say yes or ok.
Look for Program Files folder and open it. Look for a folder
that resembles the program name i.e. Databecker or something
similar to it. Open the folder and look for an *.exe file tthat may
have a large file size. (*note may contain subfolders so keep
opening them)
3. You can try a System Restore
a. Start/Programs/Accessories/System Tools/System Restore
b. Try to restore to a day that you think you had the
program available
Good Luck
Posted on Jan 22, 2009
arpit47
  • 162 Answers
SOURCE: In CD Easy Write Reader
if this problem apperared then how much time spent you by use your cd/dvd rw i give you one suggest if you have cd writer+dvd rom then buy a dvd writer it can works or if you have already a dvd writer then check your region settings for check region settings go to my computer properties and after open properties. Go to Hardware then go to device manager and then go to properties of your drive then select the nation where you live then try it can work i think
Posted on Jun 25, 2009
Why can't I download my CANO SCAN set up CD-Rom on to my new Windows 7
The CD-ROM has the installers for older versions of Windows. The installation routines for the newer versions of Windows have changed considerably from those that were in use when the CD was written. You can get the drivers and Canon Toolbox software for the scanner from Canon: http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide25#DriversAndSoftware . Select Windows 7 in the dropdown menu. The software will work with any version of Windows 7.
The only exception is that the third-party software is not available for downloads. If you want to use the original CD software (assuming the disc is undamaged) and you have Windows 7 Pro or Ultimate, you can download and install Virtual PC and XP mode for a free XP virtual computer. Then install the scanner to the "XP computer" as you normally would. However, the virtual computer and the Win7 computer cannot both have the hardware installed simultaneously. So to share files, you may need to save them to external media (optical or hard drive). If you have one of the other versions of Windows 7, you can do the same thing with any virtual PC program and a licensed older version of Windows.
I hope this helps.
Feb 12, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
How to copy anything else on finalised DVD or - to HDD on samsung HR 755
If the disk is finalized you can't normally write anything else.
The words "Finalizing" and "Closing" are used interchangeably by most recording applications. To "Finalize" or "Close" a disc means that no additional data can be written to it. This is done when the last session's lead-in is written. The option to close a disc is usually selected after all of the data that will be written has been placed in the project window, and the user knows that no more data will be added to the disc in subsequent recording sessions. The next writable address on the disc is not recorded in that lead-in, so the CD recorder, in subsequent attempts to write, has no way of knowing where to begin writing.
Mar 09, 2008 | Televison & Video
I have cd-rw and every time i try to write or format them it says it contains files, i know that and that is why i am trying to reformat them. what do i need to do/
sounds to me like windows has files waiting to be written to a blank cd. open my computer , select your CDRW drive look for files waiting to be written. delete them. and try again. cheers. Try using your CD writing software rather than windows, its often easier. It will be something like roxio, nero, CD wizard or the like. cheers.
Aug 25, 2010 | Maxell MAX630030 CD-RW, 700MB/80Min,...
Can't load my burner
The CD Burner drive is compatible with your Windows XP the software version is where the problem is. You need to get an updated version of the burner program, something like Nero burning ROM or Roxie EZ CD creator.
Buddy
Corporate Computer
May 15, 2010 | Acer (99.B0112.102) CD-RW Burner
Sony Optical Drive Optiarc CD-RW CRX880A Problem!
First, I would try burning at a very slow speed to see if this helps. If it doesn't help and you think the burner is just worn out you can buy a USB burner for about $50
Feb 27, 2017 | Sony Computers & Internet
Have anyone heard of this: How-To: Find Windows XP Product Key from the Windows XP CD: 1) Insert Windows XP cd into a working computer. 2) Exit the Autorun introduction. 3) Open ?My Computer? 4)...
If you are testing this on an already installed windows XP it will report as incorrect. On a new installation it will work. By new I mean a removed and a replaced partition.
It is an emergency installation when the original has been lost. It also somehow ties up with the original issued number by its sequencing. MS can tell you the original code from this series of alpha numerals if this series of alphas are quoted.
Thanks for using FIXYA
Mar 07, 2010 | Computers & Internet
How to reinstall windows xp if files are missing??
actually you can reinstall your xp system but this you can't, why:
the reason
your windows xp system are being updated every month...
the version from original system are being extracted to a new version....
by this time reformat you hard disk...
Jun 18, 2009 | Gateway 310 Series (158920) PC Desktop
Can i install xp on pendrive ?
  1. Put the cd with xp on it in the cd rom
  2. plug your pen drive into your computer
  3. open "my computer"
  4. drag and drop the cd to the pen drive and it should copy the files to it.
Let me know how it goes.
Jan 05, 2009 | Microsoft Windows XP Professional
Nov 01, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Windows error
Hi notsoscrewed- As long as you have your original XP disk you can save everything. First, make sure your pc is bootable from your cd drive. If you know it is good. If not, when your pc boots it should say something like hit F2 or <del> to enter setup. Go into the BIOS and find your boot options and make sure your cd is listed as bootable and listed to boot before your hard drive. Then save and exit. When your system reboots make sure you have your XP cd in your cd drive and your pc will say press any key to boot from cd rom. Press any key and follow these steps:
You must boot from your XP CD. Please make sure it is the same version of Windows that is currently installed on your computer (ex. XP Home cannot repair XP Professional). Place the CD in your CDROM and start your computer. Newer versions will work as well (ie. Windows XP Pro SP2 CD will work on an older WinXP Pro SP1 installation)
Before the Windows logo appears, you will be asked to press any key to boot from CD, so do just that.
A blue screen will appear and will begin loading XP setup from the CD.
Choose the FIRST option, NOT recovery console.
Choose F8 to continue
Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation or install a fresh copy of Windows XP
That should be it. Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts, have your CD-KEY handy . You may have to install XP updates again and reactivate XP but small price to pay and little time to be able to save all your software and info. Let me know what happens.
If this solves your problem PLEASE rate this as fixed. If you need more help with this just add a comment and I'll be more than happy to assist you further. Thanks.
Jeff
Jun 23, 2008 | Computers & Internet
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
