Question about Karen Ware / Time-O-Matic Kitchen Appliances - Others
My Karen Ware Time Matic pan lids are loose.. What type of screw drive is used to tighten ?
jackboy
  • 2985 Answers
SOURCE: freezer drawer handle loose...how do I tighten screws?
With a screwdriver?
Screws in plastic will wear with constant use , take the screw right out and wrap it with aluminium foil, then replace
Posted on Jan 24, 2008
  • 51 Answers
SOURCE: Head will not tighten on AF2100 Pistol grip
one of the treads in the tripodas head is broken try unscrewing the grip the other way to remove it, then examine the grip, if one of the threads on the part of the grip that screws in to the head, is broken then you might be able to get a new grip, and that might work, but there might also be damaged threads inside the tripod head, in which case you neet to replace the head if you can, but if you cant, then I do not think that you can repair that tripod
Posted on Aug 01, 2009
SOURCE: THE LID IS LOOSE AND THERE ARE NO SCREWS TO TIGHTEN ON THE HINGES
You do not need to replace the hinges, however your need to remove the font panels of the screen and laptop to remove the hinges. You will see that the pin that connects the top part of the hinge to the bottom part of the hinges has over time moved out of alignment. With pliers and a hammer manipulate the hinge pin so that it is now flush with the hinge itself. You will see that the hinge will then become tight. Then just reinstall the hinge. I just did this and I know it works.
Posted on Nov 07, 2009
Lady Spark
  • 51 Answers
SOURCE: Persistently loose handle on a 20+yr old 9' fry pan
What has happened is the threaded hole the screw goes into had 'stripped out'. The best option is to fill the threaded hole with epoxy, and put the screw back in, tightening it well and letting the epoxy cure. The only alternative is to thread the hole to a larger size, and use a larger screw.
Posted on Feb 05, 2010
SOURCE: loose hinge/lid on Dell latitude D410 laptop
I took the hinge cover off to look for myself to see if there were in fact some set screws to tighten the monitor up. None were found, no suprise there. While on ebay ordering a new hinge set I noticed that the picture of the new hinges didn;t look the same as what I observed on the laptop. The pin on the right was sticking out on my lapto but in the picture on ebay it was flush.
I used a flat ended phillips tip screwdriver and pushed the pin back in while gently rocking the monitor back and forth. That seemed to solve the problem.
Posted on Jun 14, 2010
I would like to replace one of my pot's whistling knob that goes on the lid.
Sadly we here on FIXYA have not idea do not know where or when you got it but possibly that retailer could assist you .
Nov 21, 2017 | Kitchen Appliances - Others
One of the tumbler blades is loose. How can I tighten the screws? I can see there are two screws holding the blade to the drum. What is the best way to get to the screws so I can tighten them? thanks
There are two clips that hold the lid down. they are located about one inch in from either side of the machine you can use a flat tip screwdriver and push them in and the lid will come up giving you access to the drum vein screws.
Dec 02, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Can you walk me trhu the transmition fluid change im going to chenge the transmition fluid my self
This job requires some special tools first a swivel to get to the pan bolts and you have to remove all nuts off the oil pan on the transmission. you will need a pan to pick up 4 quarts of fluid that will come out when you loosen the oil pan, next after you hav all the nuts out use a pat scraper and a hammer and tap around the edge of the pan to get the pan loose, next once the pan is off unbolt the screen from the transmisson housing, Next drop the pan and then remove the filter remoce the filter oring and install new one from the kit you bought. clean bolts out then put the bolts in the holes and screw then in so you can install pan back on without the gasket falling off, after filter is in place and screwed on screw on the oil pan for the transmission go from right to left and front to back one bolt at a time tighten lightly till all bolts are snug. next undo the treansmisson line on the bottom of the radiator seperate the line and start the motor put it in drive with emergency brake on then put in low gear and allow 3 quarts of oil to drain out of transmission,, shut off motor and add 5 quts of ATf dexron 2 or dexron III EATIER WILL WORK . next with line still loose run three more quarts out, it will take about 12 quarts to change all trasnmisson fluid to change out all fluid also add one quart of lucas transmisson condtioner this will make the transmison shift smother and soften band and seals put the line back on the oil cooler on the radiator then start the car in park check for leaks, if you see no leaks then at idel check fluid level it should not be less than a pint low or a pint high it will cause problems. if you add to much loosen the line and let some run out then tighten and you check the fluid again if it's to the top you done. test drive after done this will take about 4 hours doing it this way good luck on your job.
Aug 17, 2010 | 2000 Ford Windstar
How do you change the transmission filter in a 1997 jeep loredo
If you have a pan drain plug, drain the pan. If not, remove all bolts around it's perimeter, leaving two on one edge loose but not removed. Use a large catch pan or I've seen some people use a garbage pail cover over a smaller pan with holes drilled in the center of the cover so it drains.
Remove the filter, making note of the position of the filter and screw length (if any screws are longer or shorter they must go back in the same holes)
Remove ALL gasket material from the pan and rail, clean the pan and magnet.
Reverse process to assemble. Pan bolt torque is around 14 inch pounds.
You don't need a torque wrench if you use a 1/4 inch ratchet and do not pull down hard when tightening. DO NOT crush the gasket so tight it bulges out. Install all bolts by hand before tightening, tighten in a cross pattern, not around in a circle. Re fill with the proper fluid, run the engine till warm, check level, check for leaks. Make a short test drive, re-check level and again for leaks. If any leaks, tighten the bolt closest to the leak and also the two on either side of that one.
Jul 17, 2010 | 1997 Jeep Cherokee
1997 Dodge Caravan Sport. I was driving normal then it quit pulling. Now have 3 forward gears no more than 8 miles an hour. No reverse. Dropped trans pan small metal on magnet.Fluid looked ok. Changed...
The correct fluid to put in a 1997 van is (ATF-3). Sounds like you need to make adjustment on both the forward and reverse bands of the transmission to correct your problem. The kickdown band (front) forward is located at the top (outside) of the transaxle near the front. To adjust the band,loosen the lock nut approximately 5 turns. With the lock nut loose the adjusting screw should turn freely in case. Tighten the adjustment screw with an inch lb. torque wrench to 72 in-lbs. Then back the screw out 2 1/4 turns, hold the screw in place and tighten the lock nut to 35 ft-lbs. Then after removeing the transmission pan and filter the low-reverse band is located next to the valve body. Loosen the lock nut 5 turns so the adjustment screw is free. Turn the adjustment screw in to 41 in-lbs, then back the screw out 3 1/2 turns. Hold the adjustment screw and tighten the lock nut 10 ft-lbs. Install transmission pan/with gasket and refill transaxle to proper level. Test drive van. Be safe and block the rear wheels before you raise the van and try to work under it. Hope this will help you.
May 19, 2010 | 1997 Dodge Caravan
Red fluid dripping from bottom of car, is comming from a black cover (maybe transmision oil?)
Red fluid it auto matic transmission fluid. The black cover is the bottom of the transmission where the transmission filter is. Most of the time.. unless you recently had the transmission filter changed is inthe hose area where the hoses fromthe radiator connect to the transmission.
It is still quite possible for your transmission pan gasket to be leaking. Most of the time people think that by just tightening up the bolts that they fix the leak when in fact the over torque the boltrs and it leaks even more. If the transmission pan gasket is leaking buy a new gasket making sure the bolts are tightened per the manufactures torques.
Thanks for using FixYa.
Kelly
Mar 06, 2010 | 2001 Toyota Prius
Feb 04, 2010 | Faberware Farberware FSU236 12-36 Cup Urn...
Sony VGN AR630
If the lid has a small slack and then is firmer again when the lid/screen is in another position, then the hinge mounting screws is most likely loose and the mounting screws needs to be tighten.
If the hinges are loose no matter what the position of the lid/screen is in then, they need to be replaced, there is no adjustment to tighten the hinges.
Jul 23, 2009 | Sony VAIO VGN-AR630E Notebook
What's the sequence for the bolts on oil pan???
Torque specs on pan aren't really necessary. First put all screws in place to get the pan properly located, (make sure you have put a decent dab of rtv sealant at the corners of the end seals before you put the pan up) Run each screw up to where it begins tightening (but no further) Start with either side center, then the opposite side, then work in an X pattern towards both ends, using enough force to make the bolts secure, but not so they are crushing the gasket. The larger bolts at the corners (where you put the sealant) can be tightened a bit more than the small ones. Let it sit about an hour, then just go over it again. Use a 1/4 drive short ratchet to avoid overtightening, after runing check for any seepage. You can turn those screws a bit tighter to take up for any pan warpage.
Been building engines for a long time and aside from the first time, I never used a torque wrench (specs are in inch pounds, usually 12-15...Ive found that unless you have a brand new pan that is absolutely straight and flat, using those specs often produces leaks.
Jun 15, 2009 | 2005 Dodge Caravan
Washer Doesn't move from cycle to cycle
this washer has a problem with the lid hinge screws coming loose. check the left hand hinge and you will find the screws loose.
this cause the lid switch to not engage and then nothing will happen until it thinks the lid is closed.
try to tighten the screws and listen to see if the switch "clicks" when you open and close the lid.
that should fix it until the screws come loose again.
Jan 30, 2009 | Whirlpool LSR6334LQ Top Load Washer
Kitchen Appliances - Others Logo
42 people viewed this question
Top Karen Ware / Time-O-Matic Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Karen Ware / Time-O-Matic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
