Question about Samsung Televison & Video
My TV keeps flickering after it warms up Samsung TV model number HL 72a650c1f
    Top Expert:
  • Samsung Master
  • 75,169 Answers
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result will display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Posted on Dec 20, 2016
4 Suggested Answers
  • 2334 Answers
SOURCE: Samsung DLP TV shuts off
First thing I would suggest is to check and make sure that the cooling fan is working properly. The lamp may also have an intermittent failure as well.
Do a visual inspection of your lamp. In your case check for a fogged condition. If the failure is intermittent, the lamp will look fine to the visual check.
The newer TVs have blink codes that can be use to determine if the lamp is defective. Check for the LEDs on the front panel blinking and count how many and the time intervals they blink.
If you need any further assistance, let me know.
Posted on Feb 25, 2008
  • 7 Answers
Hello All, I may have an inexpensive solution to your problem. I had the same problem with my TV as well. It would shutoff by itself about an hour after it was turned on. The when I would turn it on again it would shut off after 5 to 10 minutes. Finally I got fed up. I knew it was not my bulb because the picture still looks good. I did here a buzzing if I would turn the TV on right away after it would shut off. That was do to the bulb recharging itself. I noticed the TV was extremely hot in the back. So automatically I thought it was the cooling of the set. All post I read keep saying the TV would last about 2 years to a year after a service. Which would be right because (most) service repair clean out the units before installing new parts. What I did was I opened unplugged the TV from the wall and opened unscrewed the back panel door. I used my Air compresser and blew out all the dust inside. ( A can of compressed air should do the job if you do not have a compressor) I removed the bulb and blew out the dust on the bulb as well. I did not remove the bulb from the housing unit. After I dusted the bulb and housing unit I reinstalled it. I keep my home clean but you should have see all the dust that came out. The dust covering the components overheat the unit which causes it to shutdown. It has been about 2 weeks and have not experienced any problems since. All I can say is give this a try and maybe this will work for you. This will only cost you about 10 dollars and 30 minutes of your time. This is better that Hundreds of Dollar in repair.
Posted on May 25, 2009
ladywinn
  • 5138 Answers
SOURCE: samsung 50 tv model number
Do you have Sound and No Picture?
Posted on Apr 12, 2011
I have a 40inch Samsung le40r88bd that keeps flickering and is getting worse is there an easy fix?
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY most common way MODEL ...
Flickering picture
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 13, 2013 - A flickering picture on your TV can be caused by the following conditions: Television settings; Incoming signal issues; Electronic interference ...
How to fix Samsung LN46C630 screen flickering issue
Jan 16, 2016 | Samsung Televison & Video
Samsung tv flickering ln40a500
Defective capacitors on power supply board. Replace capacitors or power supply board.
Sep 15, 2015 | Samsung Televison & Video
Magnavox tv keeps turning off
it mite be your power button that needs to be replaced
Jan 06, 2014 | Samsung DLP HL-P5663W 56" TV
My Samsung plasma tv is only around 4yrs old and suddenly started going from normal to dimmer projection, flickering between the two, is there a way to fix it or should I get a new tv
I have seen this in Samsung sets before, the flickering is likely a jumper in the power supply that needs to be removed, they had this issue on a number of sets---a jumper in the power supply (that board) likely is causing this, someone else here did post the location but search the model number with google for flickering and you may find it, it was widespread and as a last resort call Samsung or even a authorized service center.
I hope this helps and if you want (I spend a lot of time and effort answering questions here and if you get me the full model number I will research it when I get a chance, answer about 600 questions here a week.
Google the model number with "flickering" and I bet you can find a lot of info.
Happy holidays, Temp here is 11 degrees F right now but warm now inside the house.
Dec 19, 2012 | Televison & Video
Tv turns itself on and off
in general terms it means the microprocessor in the set is locked up, you have indicated a Samsung part number but NOT a brand and model number and those are needed to know if help can be given or not.
Dec 09, 2012 | Philips Samsung HL-N5065W1X/XAA...
I have a 46" Samsung tv, model HL-P4883W. It was
Lamp must be going bad, they only last for 5,000-8,000 playing hrs.
Mats has Lamps for $89.00 1-800-628-1118
Samsung Parts.com1-800-627-4368 Go to their website for Part Number for this Model.
Jul 30, 2011 | Samsung Televison & Video
My dlp tv (model number-hl-s5087w)is making a humming noise
Bad Color Wheel.
Samsung Parts 1-800-627-4368
Mats 1-800-628-1118
Oct 14, 2010 | Samsung HL-S5087W DLP TV
Samsung, DLP TV 50 inches Model # HL-T5075X/XAA
Samsung just told me they wouldn't fix my tv because it was produced in Nov. of '06 and the only ones they would fix were made in August of '06 or earlier. I am way too angry right now to call the service tech number they so very nicely provided.
May 19, 2010 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
24 people viewed this question
Jerry Greenberg
Jerry Greenberg
