Can I turn off IR on my IPC122? It constantly changes from normal to IR. Annoying clicking
Curious problem. Try putting some cardboard in front of your radiator. If that fixes it, you may have a faulty fan solenoid problem causing the fan to run constantly. There may still be air in the system, it is ridiculously annoying to get it all out. Try doing this again if the first idea doesn't work.
Aug 08, 2013 | Honda Civic Cars & Trucks
Toshiba E studio 35 has a constant beeping. Can
Nov 19, 2009 | Toshiba e-Studio 350 Copier
Rancilio Epoca S1. Constant click noise??
It is the sound of the pressure stat turning on and off, that is normal.
Aug 12, 2009 | Rancilio Epoca ST-1 Espresso Machine
2002 trail blazer - front left "drive-shaft"? sounds and feels like a bad bearing. What may be the problem/solution?
a few things to check and try to help determine if its bearing . the good ole annoying " growl" that gets progressively worse as speed increases. does the noise change when making turns... try swerving the blazer side to side. if it changes...u have a bad hub assembly . as a rule a drive axle wont do more then vibrate or click on a turn, especially that year with the constant velocity joints in the front. hope this helped you out
Jun 23, 2009 | 2002 Chevrolet TrailBlazer
Sounds when "sending" or "complete" message pops up
I think you need to turn the system sounds off. You can do this by going to Control Panel and clicking on the Sounds icon. Mush through that and see if you con find anything.
Jun 14, 2009 | Xenon XEN 1510T 15.1" Flat Panel LCD...
Can't turn off alarm
Here are the instructions to view, change alarm time and turn off alarm:
From normal time display:
Press MODE once to display stop watch.
Press MODE again to change alarm time.
Press MODE again to change time.
Press RESET once to display current alarm time.
Press and hold RESET then press START to turn on and off alarm (watch for alarm symbol on top left)
Press and hold RESET then press MODE to turn on daily alarm vs one time (watch day marker lines at the bottom)
Hope this helps.
May 05, 2009 | Watches
Clicking coming from inside my laptop
No no it is the noise of your hard disk i have also same sound coming frm my laptop...
Dec 01, 2008 | Compaq Presario Notebook
Pioneer DEH-P6900UB problem.
It's called Reverse. Just set it to No.
Oct 14, 2007 | Pioneer DEH-P6900UB CD Player
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
