Question about Acer Tablets & eReaders
I need to update my Acer tablet - Acer Tablets & eReaders
  • yadayada
    yadayada Dec 19, 2016
    To what?
Keep getting message Google play store has stopped I tap ok and it goes away but I can't get in to play store.I have Acer tablet.
it depends what android software is and your games and apps try and update your tablet to see if it works
Mar 11, 2018 | Acer Tablets & eReaders
Hi i have an acer iconia tablet ive forgotten my password to unlock the screen how can i resolve this
You would need to do a factory data reset. If you have data backed up, you will be able to retrieve it.
Power off the tablet. Press and hold the Volume Up and the Power button.
SD Image Update Mode
wipe data/factory reset.
Yes - delete all user data.
Reboot system now.
Your tablet will reboot without password
Jan 17, 2018 | Acer Tablets & eReaders
How do I get my Acer tablet to stop upgrading ALL the time
Go into software settings and turn off automatic updates. They are a curse!
Sep 20, 2017 | Acer Tablets & eReaders
How do I get my acer tablet to work it says ui system has stopped
The problem is with the Google search engine not being compatible with the User Interface and an update failed
Delete your Google search and re-install the latest from the Google store.
If you still have problems you may wish to try the following at your own risk
Settings > More > Application Manager
change to All
Scroll down to the Google App and select it
select "Uninstall Updates"
If it asks to install a factory default, agree to that
Aug 05, 2017 | Acer Tablets & eReaders
Acer tablet CPW700
M y Nook allows me to play Acer games on it, Barnes and Noble own the Nook Tablet.
Dec 09, 2013 | Acer Tablets & eReaders
Battery overcharge
first ask your self where you got it from and why you got it.
p.s. i am 9
Nov 03, 2013 | Tablets & eReaders
I appear to have lost the driver for the ethernet controller. Where can I find the driver to reinstall it?
The driver's can be found on Acers website Acer Drivers. Scroll to the bottom to: "Or select my product from a list:" Select: Notebook, TravelMate, TravelMate C300. Acer only supports Windows XP on this model according to the driver list. If your running 7, you might have to install the driver through a Windows update.
Nov 30, 2010 | Acer TravelMate C302XMi Tablet PC
How do you update the serial number in the BIOS
This is *NOT* a question about an ACER Travelmate LCD display.
The "short" answer is "you cannot", without the proper tools,
namely the tools to physically remove the BIOS chip from the motherboard, and a 'PROM-burner' device, to extract the contents
of the BIOS (about 2Mbits of data), update a few bits, and then
to "program" the updated data back onto the PROM (Programmablel Read Only Memory) chip, and then reinstall the BIOS chip back into your motherboard.
Good luck! Always "experiment" with a "test" motherboard, rather than first goofing-up your "production" motherboard.
Jan 09, 2010 | Acer TravelMate C300 14.1 XGA LCD Display...
Acer c300 tablet color went nuts after vid driver update
Hi I am Vortash .. first thing to do is get rid of your old driver and the update .. start the computer up in safe mode . you do this by hitting f8 just after the bios flash screen or if you dont have that .. just as it is about to start windows .. go to add and remove programs remove the driver if it is listed .. then go to add and remove hardware ( both these are in control panel ) and click on Display adapter and uninstall them then close all the programs and rebboot it will search it'self for drivers and at first probably load generic PCI drivers dont worry let it do that .. you can change it after .. when its rebbooted install the correct drivers and reebbot again the computer should then re-install your graphics .. hope this helps Regards Vortash
Jan 21, 2009 | Acer TravelMate C110 Tablet PC
Tablets & eReaders Logo
24 people viewed this question
Top Acer Tablets & eReaders Experts
Nicola Conroy
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
