Question about Health & Beauty
Need a manual for a bowflex 5596bow weight scale
SOURCE: weight watcher scale not calibrating weight correctly
Press the scale once with your foot. All screen options should display to initialize and then go to 0.0. Now step on the scale. It should read out your correct weight. If not, first remove and replace the battery for reset. If still not, replace the battery. If still not it's ready for return or replacement. Hope it works! Dave - CA
Posted on Aug 25, 2008
r321567499
  • 74 Answers
SOURCE: owners manual for WW 47 bathroom scale
This link allows you to request user manuals...
I hope this helps.
http://www.conair-store.com/cc_contactus.asp
Posted on Jan 07, 2009
fitnessbalan
  • 59 Answers
SOURCE: instruction manual soehnle scale
I have looked and maybe you have the model number wrong the scale you are talking about 63700 Calando Quattrotronic scale is a simple digital scale and does not provide bmi, and hydration.
here is a link to the manual, http://www.leifheitusa.com/manual/63700.pdfit is in several languages including english as the company is european and sells to many countries. If you look english is there it is a very simple manual as the scale is only desinged to weight in either lbs or kgs nothing more. Sorry. If you would like a bmi chart you can get that here http://www.healthdiscovery.net/links/calculators/body_massindex_chart.htm and figure out your bmi based on height and weight in the chart.
Posted on Apr 24, 2009
gpgab97
  • 77 Answers
SOURCE: Need to know how to adjust the weight
Try putting brand new batteries in and letting the scale zero out and then shut off on its own. Sometimes it's "zero" is misrepresented by an old set of batteries. Also, do any kids live in the house that might have jumped on it? If so, it would be wise to buy a new one as the sensitivity will be ruined for life.
Posted on May 08, 2009
  • 5 Answers
SOURCE: Weight Watchers bathroom scale, Model WW60X
I got it! Press "set". You should see "start goal" in the bottom right. Press the user # you want to save as and press "set" again. The display will blink then display "0.0". Step on the scale to get your current weight. Once it's read you current weight, press "set". A goal weight will display. Press "User 1" to make your goal weight go up and "User 2" to make it go down. Press "set" when the display shows your goal weight. That's it. Now all you have to do is press your user # and wait for "0.0" to display before stepping on the scale.
Posted on Mar 26, 2010
Need Bowflex scale instructions
hi!! google model# to their web site and download the user manual
then print it out. most are free
Oct 03, 2012 | Taylor 5728-4072FBOW...
Selector knob spins, no clicks, does not select the weights. The metal disk near the handle does not move.
1. Check to assure that the ******** handle is fully depressed into the ******** base. If not fully depressed, the locking mechanism will not be released and may be keeping the adjustment knobs from rotating. 2. Check to see if any weight plates have been put into the base assembly backwards with the "support ******" facing the grip of the ******** handle. All weight plates must have the selection ****** facing away from the grip of the ******** handle. 3. Check to see if there is any dirt, debris or other obstruction in the ******** base. You may need to remove the weight plates from the base to accomplish this check. Remember to put each weight plate back in its appropriate location with the selection ****** facing away from the ******** grip.
Aug 15, 2011 | Bowflex Selecttech Dumbbells
My bowflex dumbells are jammed and i cant remove them from the holder
Hi I called 1-800-628-8458 (the number in the manual) after trying several of the methods shown here. None worked. your dumbbell needs to be on a flat surface, no roll the dumbbell over to where the weight is facing the floor and the base is up in the air. With both hands lift the base and gently shake, the weight should fall out. Put the base back on the floor face up and inspect the grooves where the weight plates go for any debris. Clean this area if you find debris. Now you will need a pen or pencil with your weight. Grab your weight, still facing down and you will see a black release button on both sides on the inside of the weight. It is in between the metal dial and the inner part of the weight. Now press down on that button with your pen or pencil and start turning the dial (caution: the weight plates are going to fall out) keep turning until all of the plates are out. Do the same thing for the other side. Now grab each plate and put it back on the base where it goes, the smallest plate on the outside to the largest plate on the inside, make sure the small metal piece on the bottom of each plate is facing away from the inside of the base. Do this for all of the plates. Now back to the dumbbell. Grab your pen or pencil again and press down on the black release button and turn the dial to where the number 5 or lowest weight is selected where it reads Bowflex. Do this for both sides. Now grab your dumbbell and carefully put it back into the base. It is important that you put the dumbbell down straight, avoiding any shifting in plates.
I hope this helped.
Dec 21, 2010 | Bowflex Selecttech 1090 Dumbbells
Selecttech 1090 Dumbbells: the end caps that adjust the weight are stfrozen, ...
Just call Bowflex. If you don't want to call here's the solution. There is a reset button on the bottom of the handle. Take the handle out, place on the floor side ways, depress the square button and turn to 5 lbs. Whatever weights that were on handle will fall out. Place the weights back into the holder. Make sure they are positioned correctly then put the handle back. Then test by dialing up different weight settings and lifting the ******** out of the holder. You should be back in business. If that doesn't work call Bowflex which you should do anyway.
May 18, 2010 | Bowflex Selecttech 1090 Dumbbells
Where can I get a manual, after moving I can't find mine!
Troubleshooting Conair WW81 Weight Watchers Body Fat/Hydration ... Solve Your "Conair WW81 Weight Watchers Body Fat/Hydration Scale" Problem Now! ... Tanita Ultimate Scale 2001 - no user manual -how to set. ...
www.fixya.com/support/...conair_ww81...body.../solutions
Oct 05, 2009 | Conair WW81 Weight Watchers Body...
Need to reset scale weight
You have probably set your scale to kilogram and not pounds. There should be a button to set this underneath the scale or even a reset button to reset the scale to its original settings.
Jul 08, 2009 | Homedics Glass Top LCD Digital Lithium...
Instruction manual soehnle scale I need to rest the scale so it shows the bmi, hydration and weight.
Apr 23, 2009 | Soehnle 63700 Calando Quattrotronic Scale
Bowflex 1090 selectech fault
If you have an issue with the SelectTech dumbbells of any kind, just contact the customer service phone number 1-800- BOWFLEX. All they require is a proof of purchase (receipt) to be sent in and they will send you any replacement parts free of charge. You do not need to send the old parts back first.
Feb 17, 2009 | Bowflex Selecttech 1090 Dumbbells
Weight watcher scale not calibrating weight correctly
Aug 12, 2008 | Irons
Health & Beauty Logo
94 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
jeff tilburn
jeff tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
