Question about Garden
I have a cable activated Isarmatic Mark 111a Western snow plow. I used it today for a while than it quite going up all the way and would not angle . And the motor makes a high squeling sound
  • 89 Answers
SOURCE: western snow plow will only angle to the right .
IVE NEVER WORKED ON A SNOWPLOW BUT NOONE ELSE IS OFFERING ANY HELP. IT SOUNDS LIKE FLUID IS LEAKING BY THE VALVE AND PRESSURIZING THE LEFT SIDE ALL THE TIME. IT ALSO COULD BE YOUR NO-SPILL COUPLERS CLOGGED OR NOT OPENING FULLY PREVENTING FLOW OF FLUID ON THE LEFT SIDE. GOOD LUCK. JODY
Posted on Apr 07, 2009
redbeard00
  • 957 Answers
SOURCE: Can I make a 99 Chevy 1/2 ton Western Unimount
No. it is technically possible but there is a good amount of metal fabrication involved.
Posted on Apr 28, 2009
  • 832 Answers
SOURCE: western snow plow when you try to angle to right
This is a control valve problem. From you comment, it is
clear that the control valve flows to one direction only.
Please check the control valve of the snow plow that
execute the angle to right or angle to left. Also check
the pipelines before and after the valve. It must have a
free flow of the fluid.
Posted on Dec 02, 2009
  • 2468 Answers
SOURCE: I changed the hoses on my western sonw plow today
off the (joy-stick) in the cab, can you hear the hydraulic motor run when it's set to move to the left???,if so when you changed hoses,did you have all plow angles and heights "centered" when you did this? you may still have a lack of hydralic fluid to that position,does it try to move that way (jittery)?if so, again check for an air pocket in this line and re-bleed the system,overtime it will work itself out of the lines,but you may have it trapped in this hose run
Posted on Feb 07, 2010
  • 146 Answers
SOURCE: I have a western unimount
88-to early 99 all models 1500 to 3500
Posted on Nov 17, 2010
Testimonial: "Thanks a lot for the answer. I've been shopping online for a truck and this is the most straight forward information I've seen for this question."
Plow lights work OK, but why is there no power to joystick?
Bad connection in plug,bad wire, fuse or fusible link, faulty joystick.
press the helpful button and check link below
western plow problem Snow Plow Forum Let Talk Snow Discussion Forums
Jan 14, 2016 | 2002 Ford F-150
I have a minute mount plow, when I try to use it only goes to left and right side but doesn't go up, when I try to lift the plow goes to the right. What can I do
2002 Fisher Minute Mount Inst-Act Wont Angle [Archive] - PlowSite ...
www.plowsite.com > ... > Truck & Equipment Repair
Nov 17, 2011 - 90 posts - ‎9 authors
My plow went up it was jerking and did it in steps , but , it got there . Now , it onlyjerks when i try to angle it right or left or up . I filled the fluid ... Drop it and if it doesn'traise you can just use a jack and shorten the transport chain to hold it. .... I do havecontinuity on the plow side for all 3 wires going to the plug . Hooking Up A Fisher Minute Mount 2 In Under 1 ...
Feb 1, 2011
Plow Wont Angle
Oct 19, 2010
What's wrong with my plow?
Jan 9, 2003
Looking For Minute Mount Tips
Feb 13, 2002
More results from www.plowsite.com
Ultramount Intermittent Angle Problem - Snow Plow Forum - L
Dec 27, 2015 | Cars & Trucks
Meyers home snowplow goes up n down no problem.angle right it inches its way to the right.angle left motor runs no movement. any thoughts
It sounds like a faulty valve. Some valves use O-rings to seal between ports and they may have failed. I would check the lines for trapped air first.
Oct 25, 2015 | Meyer Home Plow Home Plow by Meyer...
While driving down road my western snow plow is rocking all over.
not good or safe! check all mounting pins and frame mounts. A lot of force is on snow plows and the frame mounts often need to be welded up. I imagine it is the whole unit and not just the plow.
Mar 12, 2015 | Cars & Trucks
I have a 93 chevy with a western unimount. was plowing and now the motor runs,but wont lift or angle. possibly something sheared off in the pump? fluid is full,and no visible leaks.
If you have a Western Plow ISARMATIC pump, a very common problem is ice forming on your pump pickup screen. This will cause intermittent up/down AND left/right functions. Western recommends the fluid be changed annually and I agree. Here's what it looks like after dirt and moisture form on the pump screen. Thats an ice chunk below the screen that appears to be a hump in the case. Be sure to verify that the pump motor is actually spinning before you suspect the pump screen. b7cfa544-07c8-441e-a344-3d5d97b0b2b0.jpg
Mar 08, 2011 | Chevrolet 1500 Cars & Trucks
NO power wont lift
boss plow will not go up or down, do not have light on main control. Truck lights will go on but when toggle switch is activated, truck lights stay on and plow lights will not go on.
Jan 28, 2011 | 82" TruckSUV Snow Plow
Western snow plow when you try to angle to right it goes up does same thing if you try to angle left
Oct 30, 2009 | Plumbing
Wiring for western plow joystick
My western snow plow will not go up or left or right with joystick. I can use a screw driver and make contact on the silanoid and then move the cables with the joy stick and then it will work. I have relaced selinoid and contacts. any ideas? Stomped
Oct 25, 2009 | 1990 Chevrolet Crew Cab
Western snow plow will only angle to the right . take the line off for the left and then it will angle both ways for a short time
Mar 10, 2009 | Plumbing
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
