Question about Kitchen Appliances - Others
My kettle will only turn on at the right time otherwise I can push all the buttons to no avail what can I do ?
  • kakima Dec 19, 2016
    Hi Eric LeBlanc, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model?
2 Suggested Answers
  • 29 Answers
SOURCE: Overheating kettle
It is in warranty period just call to support where you have brought this products definitely to get your solution or you need something other related this product like products details or services then check
Posted on Aug 04, 2015
The machine keeps beeping and kettle does not get hot
I am assuming this is a Gold Medal Popper with the Big Eye System, since it is the only Beeping popper currently available. The beeping is an error code that the thermostat is not connected. Double check the kettle is plugged in tight, otherwise contact a service technician.
May 11, 2015 | Kitchen Appliances - Others
Information to question already asked the fact the power is lighting both lights up but no noise of starting to boil does this kettle need a new element and if so where can a get it fixed.
You are not specifying what make it is but you hardly get replacement elements for kettles any more. The fact that you can see that power is available at the kettle it is indicating that it might be the element being defective. Had it been it switched on without any water in it? If it is the old type where the electrical cord gets plug in at the kettle check if it is well plugged in otherwise it is time for a new kettle.
Apr 09, 2015 | Kitchen Appliances - Others
The lid is stuck
Have you tried pushing your lid down to make sure catch doesn't hang-up before pushing back on the button and pulling it upward?
If that doesn't work it maybe damaged (melted by steam, overuse or gunked up with heavy mineral deposits) but to be honest we don't ever open ours. We fill from the pour spout just fine with the lid always closed. You can pour in your descaler the same way.
Hope this helps a little...
Dec 07, 2013 | Oster 5965 Electric Kettle
1.7 l cordless kettle model JKC930C lid release does not work
Had same issue on 2 B&D JKC930C kettles. Just push in button (hidden under front of lid) located in the centre above the spout with a butter knife and the lid will open.
Jul 12, 2013 | Applica Black And Decker Cordless Electric...
No light, no water heating
The heating element may have failed.
Sep 11, 2012 | Braun WK200 Electronic Water Kettle...
Kettle has just suddenly tripped the electricity. Tried changing fuse and different plug socket but still tripped. O oh!
This is because there is a current leakage between the live and earth terminals of the kettle.
You see, if current leaks from live path to earth, you will get an electric shock when you touch the outer metal surface (because the metal part is earthed). To protect you, the trip switch will cut off the electricity supply.
You can try drying the kettle in hot sun. This is because the current leakage is most probably due to water leaking in to the circuitry.
You can try replacing the heating element, if it is available in the store. Otherwise do not use it. That's better for your safety.
Jul 22, 2011 | Dualit 72024 Cordless Electric Kettle
The warming button is stuck in the "on" position.
Push down on it toggles it on and off. Push down on it and it will release back up. Hope this helped...
Jan 11, 2011 | Oster 5965 Electric Kettle
Overheating kettle
this same thing happened to me
Sep 10, 2008 | Bravetti EK119H Electric Kettle
No water coming out of water filter
check to see if the filter is in backwards! most inline filters flow only one way!
Dec 18, 2007 | Kitchen Appliances - Others
Switches off before full boil
Look under the kettle at the round circular connector in the bottom. Inside there is a small button that is depressed when the kettle is put on the base. If this is not pushed in far enough it will have problems.
The cause is that after some use the connector in the base plate collapses into the base by 1-2 mm This means the switch is not pushed in far enough.
My kettle had similar issues... I pulled the base plate apart (3 screws I think) and cut a round disk of plastic to lift the connector up by about 1-2mm and then reassembled the base.. No more issues
Nov 23, 2007 | Russell Hobbs RHOK3123 Cordless Electric...
Kitchen Appliances - Others Logo
67 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
