Question about Hardware & Accessories
In wall timer.they sent a plug in - Hardware & Accessories
I need the istruction booklet
More information is needed about timer.
Check out following options, or add a comment any time.
Adding a comment sends email and I will answer.
1) Add a comment and describe timer dial or timer buttons in detail, and include if timer is in-wall, or plug-in, or box type.
2) Open following link to see Intermatic, Woods, and GE timers plug-in, in-wall, and box timers, including indoor and outdoor:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/GE-timers-and-manuals.html
http://waterheatertimer.org/How-to-set-timers.html
Sep 08, 2011 | Hardware & Accessories
I bought a home which has the timer . But I don't know how to set the timer. Timing is now from 8 pm to 10 pm, I need to change it, how?
Adding a comment send email and I will answer.
1) Open following link for setting analog timers.
Applies to in-wall and plug-in type analog timers.
2) For a programmable timer, a comment and describe timer buttons, and include if timer is in-wall or plug-in.
3) Open following link to see Intermatic, Woods, and GE timers plug-in, in-wall, and box timers, including indoor and outdoor:
I bought a new timer the model # is 59382 I have tried setting and it didn't work. I called the store were I bought it and a guy told me how over the phone it still didn't work. I am getting very...
http://waterheatertimer.org/Woods-timers-and-manuals.html#59382
Quote:
Maximum load 500 watts, used for indoor or outdoor
Set current time, rotate dial until current time lines up with black triangle.
Around outer edge of dial are segments.
Pull up all segments for times you want timer OFF
Leave segments down for times you want timer ON
Locate switch on timer.
Push switch toward the 'V' shape that is pointed down.
Plug into wall outlet, plug lights into timer.
End quote.
Two people have written to fixya saying their 59300 series timer had no switch.
But none of those folks sent a photo of their timer so I could see how they had the settings.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Apr 18, 2011 | Hardware & Accessories
Can't get the timer to turn on
Woods timers:
You posted under Woods 59383.
Plug timer into wall after setting timer.
Push switch so the V shape is down.
Plug into wall outlet, plug Christmas lights into timer
Drink ale and eat turkey legs.
Add a comment if this is not your timer, or if you need more help.
Nov 23, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
The Woods indoor timer I purchased for my barn doesn't work . I have tried in the house and it does work. Does this timer work with appliances without a switch ? In the barn we use extension cords for our...
Most of the plug-in wall timer manuals mention that they don't work with extension cords.
I assume this has to do with the rechargeable battery.
A work-around would be to buy the Woods, or GE or Utilitec in-wall timer where the clock is powered by the electric circuit and not a battery.
The timer takes the place of a wall switch.
And then wire the timer circuit to a wall receptacle.
Of course this would take wiring.
The following page shows a variety of in-wall timers.
http://waterheatertimer.org/Programmable.html
Nov 07, 2010 | Hardware & Accessories
Lost instructions on how to set it
If I understand correctly, you have an indoor timer
Your timer is Woods brand. (other brands may program differently)
Your timer has a circular dial on the front. (other types of timers do not have a dial, they has a digital display)
Your timer plugs into the wall -or- it is installed in-wall where a switch goes.
Here is a photo that might help.
To set current time, you rotate dial until is lines up with the triangle shape located on inner dial.
If this is not your type of timer, please answer in return and we'll get your timer going with information that is accurate to your model.
Push pins in and out to control ON OFF functions.
If your timer plugs into the wall, then it will not have the manual override slider switch shown above.
Oct 21, 2010 | Woods 2C 24 Hour Indoor Mechanical Timer...
I bought two indoor timers with the pins and the instructions are very vague on how to set the timers can you help??
If I understand correctly, you have a Woods brand timer.
To set current time, you rotate dial until current time lines up with the triangle shape located on inner dial.
If this is not your type of timer, please answer in return and we'll get your timer going.
Oct 21, 2010 | Woods Hardware & Accessories
How to set a tork timer?
Tork makes a page-full of timers.
Rotate dial until current time lines up with arrow, then set the pins as shown in photo below
1) If timer plugs into wall receptacle, it has pins around the dial.
2) If timer replaced a wall switch it also has pins around dial.
GE and Woods and Tork and Intermatic each make similar timers.
Pull and push the pins to set times.
The wall-switch type timer also has a switch >>> move switch to Timer
Up-vote if this information helped. Thanks for the feedback.
Oct 15, 2010 | TORK 401A 24 Hr Mechanical PlugIn Timer ...
I have a Tork 806A timer, but no instructions on how to set the on/off cycles.
Tork 806A: There are 6 outlets. Bottom two outlets are always on. Top four outlets controlled by timer all four outlets turn on and off at same time.
Load: Total load on all 6 plugs cannot exceed 1500 Watts, which is typical for 15A circuits. Indoor wall plugs are 15A. Don't add more load to timer than you would put on ordinary wall plug.
Set Time: Rotate dial clockwise to set time. On face of dial, Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} push tabs down to turn on loads, pull them up to turn off loads.
Reset: Timer has reset button in top left corner.
Jul 25, 2010 | TORK Digital Interval Timer Ssa100r-24
I would like to put a danby on an electrical timer so I can dehumidify my camp trailer 2hrs a day. It has a soft start though. Is there a way to do it?
If it plugs into a wall outlet of 120 volts then all you have to do is go to a hardware store and buy a timer that you plug into a wall outlet and program it for two hours a day and then plug the danby into the timer. But make sure the timer will carry the amp load of the danby, for instance wall outlets are usually 15 amp, so the danby amp rating should be 10 amp or less and you don't want anything else on that circuit.
Nov 24, 2009 | Heating & Cooling
Hardware & Accessories Logo
48 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
