Question about Canon Office Equipment & Supplies
Canon printer stuck on message - Canon Office Equipment & Supplies
  • kakima Dec 19, 2016
    Hi Gail Marston, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What does the message say?
Error message 6A00? on Canon MP830 - mrssage occurs on switching printer on - tried to switch off and on again and same error message appears
That error, 6A00, says that the cleaning station is either stuck or broken. If the printhead is not stuck on the right, pull it out to the center and look inside with a light and see if paper scraps or something is stopping it. There is also a spring loaded squeegee that could be stuck on the rubber cups and needs to be gently pushed to the rear. If The squeegee is stuck you need to use a wet Q-tip and clean the tracks it rides on and it shouldn't stick again. If these things don't help you will need a shop to replace the purge unit. about $20.00 plus labor charges. It is too complex to replace at home.
Jan 11, 2011 | Canon MP830 All-In-One Printer
Error message - the paper is jammed
Check for either a small piece of paper that has torn and stuck, the paper sensor is triggering your "Paper Jam" message. If your printer has paper there for more than twenty seconds or if the printer is turned off and on and the sensor is still triggered it will report a paper jam. Next, check the sensor to see if it has come off the bracket when you pulled your stuck paper out of the printer. Also try and open the printer preferences in your Canon software, under the maintenance tab select quiet mode. Now re-download the printer driver and software, click on the link below to download and then restart your computer for the changes to take effect:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp450#DriversAndSoftware
Dec 15, 2010 | Canon Pixma MP450 All-In-One InkJet...
Have a new canon pixmaiP4600. Installed software
open the cartridges may be stuck off and installed
first is printer is good ofter prin out coming
Jun 10, 2010 | Canon PIXMA iP4600 Color InkJet Photo...
What does 6A60 error message indicate and how do I resolve on my Canon MX700 all in one machine.
6A60 error is an APP (Application Printer) position error. It means that an error has occurred when the motor was running during the purging operation on start up.Check the sheet feeder and purge unit.Sometimes pieces of paper stuck in purge unit.
Thank you!
Nov 02, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Instal cartridge message when everything is installed
It's telling you that you need a new printhead, Canon confuses us with that error. It's not talking about inks, it says replace printhead.
Aug 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Message on screen says there is a paper jam when you try to print
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tonl-i-24
Mar 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Won't print, and shows Error Code 3
Check to see if anything is stuck inside. Sometimes a small fragment of paper gets stuck inside and triggers the "jam" message.
Feb 03, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Check document message
It thinks there is a document stuck in the document handler. Check for a small piece of paper, or a stuck sensor.
May 27, 2008 | Canon imageCLASS D340 All-In-One Laser...
24 people viewed this question
old marine
old marine
