Question about Procom Heating & Cooling
I just bought a procom pck80t btu/Hr. Filled it with no.2 denial tried to start up blows out smoke and shuts off.
tbugger
  • 232 Answers
SOURCE: THE HEATER STARTS THEB BLOWS ALOT OF SMOKE
There are any number possibilities for intermittent running.
1. Bad ground connection at the Ignition Device (transformer, spark box)
2. restricted fuel filter causing fuel starvation
3. crack in the plastic end cover
4. crack in the airline
5. crack in the fuel line
6. crack in the nozzle adapter
7. water in the fuel
8. Others I’m sure I left out
You must be the one to troubleshoot & find the cause.
Follow these troubleshooting tips
Posted on Dec 22, 2008
  • 3238 Answers
SOURCE: Gas smell from Procom 28000 btu infared heater
check the connections with some washing up liquied and water in a bowel and try the connections with this , it should help find your leak use a paint brush to put on
Posted on Jan 13, 2009
SOURCE: All-pro 60,000 BTU multi-fuel
i have the exact same problem on same model.
Posted on Oct 11, 2009
rowdy45176
  • 2176 Answers
SOURCE: runs for 2 minutes well then shuts off and smokes
I would suggest calling Portable Heater Parts at 1-800-362-6951, you will need your model number and a description of the problem and talk to their technical service department for assistance and to order replacements parts for this unit. Let me know if you need more assistance.
Posted on Dec 08, 2009
  • 69 Answers
SOURCE: i have a master 150000 btu kerosene direct fire
The white smoke is the kerosene fuel hitting the hot combustion chamber. Your flame has went out. The cause for this could be many. The first thing you need to do is check your fuel. Remove your fuel cap and look at the bottom of the tank for trash or water. Use a good flash light. It will all settle to the bottom. If so, drain and clean out your tank. Add fresh kerosene. Check your fuel filter. Replace if dirty. Test again. If problem continues, It is possible that your photo eye could be deffective or just dirty. It is located next to the ignitor or spark plug. It sees the flame. If the flame goes out, the unit shuts down. The flame has to be smooth (not sputtering). Water in the fuel will make it sputter and the unit will shut down. When the water/moisture in tank settles to the bottom, your suction fuel line is just off the bottom which results in it picking up the water instead of good fuel. Always disgard the old fuel from previous year and start with fresh fuel. This will cut down alot of your problems in the future.
Posted on Dec 10, 2010
Pilot turns on and so will unit for about. 5 minutes...pilot flickers as if there were air blowing into it...any suggestions? It is. A Pro-com MD100TBA
the flame confirmation thermocouple might need looking at biased on your description , this item sits inside a stainless steel metal tube that's about 1.5 inches long an is someplace around the edge of the heater , this item confirms that the main flame has lit and shuts off the pilot most times too . this is why I believe it is not working
Jan 18, 2016 | Procom 10K BTU, Vent Free, 2 Plaque...
Whats most likely the prob if I filled my dirtbike oil level to full and within 1 hr of riding low on oil with white smoke and oio blowing out of exhaust
it would be helpful if you would give us details like what kind of oil, etc. and tell us if it is a 2 stroke or 4 stroke, off road only or dual purpose
Sep 23, 2014 | 2007 KTM 660 SMC
Hearthrite HR-15ML Propane Heater Malfunctioning
Could be dust build-up from the months of inactivity. Try taking a can of compressed air and blow into the ignitor and flame port. If dust is the problem, that should clear it out.
Dec 10, 2012 | Empire Comfort Systems Empire 15,000 BTU...
I have a Laars Max Boiler 75, 90K with white smoke out chimney
Hello
Yes,more then likely its moisture from the high effenicey system of the boiler.
I have a laars boiler at work and some mornings when its cold out it looks like there is a fire, which is really only steam.
As long as your not shutting down on low water failure or loosing pressure and holding temp.This is normal.
Hope this helps.
Jan 26, 2010 | Heating & Cooling
Jan 13, 2009 | Procom (177653) Utility Heater
Dec 21, 2008 | Reddy Heating & Cooling
Procom MN300HPA ventless heater conversion
You need to first get a regulator which will go between the propane tank and the burner. You will need to know the burner capacity in BTU/HR and the pressure required. All of this can be found on the furnace specification plate or on the gas valve. It is a no brainer Circut!
Ray
Nov 06, 2008 | Heating & Cooling
PROCOM QL300TYLA
The QL300 has a range of 20,000 to 30,000 btus. That shouldn't be too big for your 300 square foot room with high ceilings and a loft. It has a thermostat, so it will shut off when the room gets warm. 1 pound of propane contains about 21,000 btus, so you will be burning 1 to 1.5 pounds each hour that the stove is running.
Jan 17, 2008 | Procom QL300TYLA Heater
Readyheater portable forced air 170,000btu/hr
reset switch my heater did the same thing after 5 sec of running
Dec 20, 2007 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heating & Cooling Logo
41 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
