My c6400 can't photocopies it asks me to contact a technical support
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
Do what it says and contact technical support.
Posted on Dec 19, 2016
I requested technical specifications of printer EPISON 1805 but I didn't get them.
If you requested the spec from a dealer or service workshop, ask the dealer or service workshop what happened.
Either way, ask Epson for the specs...
Jul 13, 2016 | Office Equipment & Supplies
How can I fix the error c6400 on kyocera taskalfa 221?
Hi
I found this explanation of your error, although my understanding of it is not entirely clear.
Code: C6400
Description: Zero-cross signal error
Interrupt of the zero-cross signal does not occur more than 1 s.
Causes: Poor contact in the connector terminals.
Defective power source PWB.
Defective engine PWB
You can find this here:
Error Codes Kyocera Mita TASKalfa 221 Code C6400
and also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 17, 2014 | Kyocera Office Equipment & Supplies
ADD TONER ERROR
Good day, if your error is toner then make sure the small white gears on the back of the toner cartridge is turning, if they are not then replace toner bottle, if they are turning ask a technician to test the toner motor. If your machine displays error C6400 then enter service mode by pressing 10871087, now press 163 and OK, now restart your machine, if the code is still there then you should replace your fuser/fixing unit.
Apr 03, 2014 | Kyocera TASKalfa 180 Copier
I have an error code C6 020 in my copier kyosira KM 1635. Please give me the means of this and what I can do to reslove the problem. Thanks
goto service mode by pressing 10871087. then press 163 then start 4 times.the machine will restart and wola
Jun 03, 2011 | Kyocera Copystar CS-1635 Copier
Konica Minolta bizhub 163 Display M2. and not functioning Photocopy. Please sugest me ?
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
Dec 29, 2010 | Sharp AR-5320 Black and White Copier
Dec 29, 2010 | Sharp AR-5316 Advanced Digital Imager...
C6400 error problem of kyocera printer
C6400
Contents: Zero-crossing signal problem
• The engine PWB does not detect the zero-crossing signal for the time
specified below.
At power-on: 3 s
Others: 5 s
Check procedures/corrective measures: Check the connection of connectors YC7
on the engine PWB and YC2 on the power
supply PWB, and the continuity across the
connector terminals. Repair or replace if
necessary.
Causes: Defective power supply PWB.
Check procedures/corrective measures: Check if the zero-crossing signal is output
from YC2-11 on the power supply PWB. If
not, replace the power supply PWB.
Causes: Defective engine PWB.
Check procedures/corrective measures: Replace the engine PWB if C6400 is detected
while YC2-11 on the power supply
PWB outputs the zero-crossing signal.
Dec 17, 2010 | Kyocera FS-1118MFP Laser Printer
Kyocera FS1118, error code C6400, how do I resolve This?
Hi
Error C6400 appears in Kyocera FS118 when Zero crossing signal problem occurs i.e when the engine PWB doesnt detect the zero crossing signal. This can occur due to --
#1 Poor contact in the connector terminals.
#2 Defective power supply PWB.
#3 Defective engine PWB.
To reset it from Mainatince mode turn the power switch off and open the front cover. Now, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,
C6050, and C6400 are reset.)
4. After this is complete press the back key. The indication for selecting a maintenance item No. appears.
Daniel Scott
Jun 21, 2010 | Kyocera FS-1118 Printer
Photocopy of demende we contacted technical support
OK, what is the error code under the "Copier needs Service Tech"?
Jul 04, 2009 | Toshiba e-STUDIO 282 Black and White...
Problem of kyocera
you probably got hit by a surge... try the best solution on this page...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
May 25, 2009 | Kyocera Mita KM-1815 All-In-One Laser...
22 people viewed this question
k24674
jasbo
jasbo
