SOURCE: PUMP RUNS BUT DOES NOT **** UP WATER
I have experienced this same problem and all I needed was to prime the pump. Unless your pump cannot pump up that high.
SOURCE: how to setup pump
just need a smaller pump hose for infeed and out feed and power supply to the pump the water is cycled from bottom to top .
THANK YOU FOR USEING FIXYA
RATE ME
SOURCE: The motor runs, but not take in the water
Check the strainer at the pond. Prime the pump and see if it pumps anything.
SOURCE: need head pressure on 1hp shallow well pump SDTS10
reducing the pipe size helps build head pressure.
SOURCE: Fountain pump motor runs but no pressure to push water
You can try to force prime with a garden hose. Put the hose in ether side suction or discharge.
