Equivalence transistor tt2206
Transistor de vertical
    Top Expert:
  • Televison & ... Master
  • 74,482 Answers
Equivalent Sanyo 2S?5793
Features : I(c) : 10A, V(cbo) : 1600V
1. High speed.
2. High breakdown voltage (Vcbo=1600V, Vceo=800V, Ic=10A, Pc=65W ).
3. High reliability (Adoption of HVP process).
4. Adoption of MBIT process.
TT2206 equivalent circuit is 2S?5793, TT2202, JL6920, 2SC5446
Posted on Dec 20, 2016
What is the equivalent of c6093 transistor?
This information was provided from a forum:
http://tv.yoreparo.com/reparacion_de_tv/892663.html
bu2520af or bu2527df but at 12 amperes
Also you might try DM1803DFH. DM1803DFX o 2SD2627 y BU1508DX, with damper
C6093 Datasheet PDF Alldatasheet
quema horizontal C6093 Reparacin de TV YoReparo
transistor c6093
Aug 22, 2015 | Computers & Internet
Where can I get a schematic for the TRS-80 video monitor model no. 26-9202 ?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 25, 2014 | Televison & Video
I change the TT2206 transistor of samsung tv model CS-29Z58M1 because it is shorted, after i replace,it works but after three minutes it shorted again and tv does not work,
Check and replace damaged components associated with horizontal output section circuit. Check the FBT too. Check this link for more details. Pull up older posts there.
Mar 18, 2013 | Televison & Video
Siapa yg tau jenis tr tt2206 dan apa penggantinya
Hallo mr. Ragil, Welcome to FixYa,
Ini transistor utkTv. Ini digunakan utk tv yang horisontalnya bermasalah. Boleh di cari di toko sparepart electronik di Jakarta atau dipesan saja lewat service electronik terdekat.
Salam, di vote ya, Jaya
Jan 24, 2011 | Televison & Video
Tv was dead no vvidei no sound after checking found that power supply capacitor and horizontal deflection output transistor was defective i lost that tr no part no please tell me what should i do?
Hello
There are few models of Sony telivisions which uses transistors in vertical output section. It will be a matched pair of PNP and NPN transistors. According to Sony schematic which I have with me used 2SB6494(PNP) AND 2SD669A(NPN) as vertical outputs and 2SC2383 as vertical drive, 2SC1364 as vertical oscillator. Just try to get the orginal numbers or find its equivalents from data book. Ok.
Oct 17, 2010 | Sony KV-35S42 35" TV
When turned on you view only a vertical line. i beleave a power surge caused this. what part or parts do i need to replace. mod no-ps35123. tnank you
There is no vertical chip in this model/ ctc 169.
it's a transistor- resistor - cap circuit.
It's either the yoke wires on neck of the tube have
become de-soldered or the more likely possibility
is the viliot / white wire from the yoke have simply
become de-soldered if you first re-solder those two
Jun 01, 2010 | Televison & Video
Vertical line
Most probably the vertical deflection amplifier is failing. The most common part that fails is the vertical output transistor.
The set is too old to find documentation on part numbers and descriptions. Probably the part is no longer available and you will need the assistance of someone who can help you find an equivalent transistor that will do the job.
Of course, without testing we cannot be certain the failure is the output transistor. It could be from something else such as the voltage regulator that feeds the dc line to the vertical section. Could be the vertical synchronous level that goes too low to trigger the vertical sweep generator.
Other bad parts in vertical deflection circuit though there are not that many parts that would kill the deflection entirely.
Loss of power to vertical deflection circuits. Check for blown fusable resistors/fuses and bad connections.
Loss of vertical oscillator or vertical drive signals
Good luck.
Jun 01, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
After changing c5707/c5706 transistors its burnt after 10 minute? i have changed its 3 times, pls advise me about actual problem
On E152fpb dell only replace all driver transistor the c5706 or c5707 this 2 types of transistor is not desame one is PNP & NPN so you must be careful of replacing component maybe it will help you
Apr 26, 2010 | Dell E152FPb 15" TFT LCD Flat Panel...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
