Question about Sony Audio Players & Recorders
Sony str-450z subwoofer hookup? - Sony Audio Players & Recorders
  • 8 Answers
SOURCE: brand new sony str-dg820 7.1 sub woofer problem
Did you turn on the sub out put?
Posted on Jun 27, 2009
kerguney
  • 577 Answers
SOURCE: Connecting a Sony Subwoofer SA-W2500 to a STR DE 598
It is based on your sub-woofer type..whether powered or passive sub woofer..
Assume that you have powered one..RCA sub woofer jack is the best to feed it ..you should use RCA sub woofer output on your receiver as well..good luck
Posted on Jan 15, 2010
dunnbiker
  • 8546 Answers
SOURCE: HELLO HOW TO CONNECT SUBWOOFER TO SONY
It would depend a lot on what type of subwoofer you have and it wouldn't be pretty.
According to the manual I found it doesn't have a Woofer Output so it isn't designed to route Low Frequencies anywhere.
Even if you rigged an Active Subwoofer to it using the Tape Output you wouldn't have central volume control for it unless the (unnamed) Sub was driven by speaker-level outputs from the Front A or B Speaker posts on the receiver.
Your question would be better framed and answered if we knew the details of the Sub and referred to ITS manual.
Posted on Apr 10, 2010
Testimonial: "Thank you for your advice. This is exactly what I needed to know . Jerry"
dunnbiker
  • 8546 Answers
SOURCE: Can't get subwoofer working with sony model STR-DE845 receiver
read the manual
http://www.retrevo.com/support/Sony-STR-DE845-Receivers-manual/id/387ci973/t/2/
First, it must be a self-powered subwoofer, then you've got some settings to select in the receiver.
Posted on Jan 21, 2011
budmrtn
  • 11361 Answers
SOURCE: New STR-DH810: No tone or
User manual: http://pdf.crse.com/manuals/4168075131.pdf
The SUB WOOFER RCA (see page 11 of the user manual) jack is the audio line out level, you need to feed it to Powered SUB-WOOFER speaker.
Hope it helps.
Posted on Mar 21, 2011
I have a Sony STR-DE597 FM/AM Receiver .It has audio out plug and i have a Jensen js650 100 watt Subwoofer. how can i hook them up? Thanks.
The Jensen JS650 does not accept line level input so you need to use the Front B speaker output from your Sony receiver and not the RCA subwoofer output. Even though your subwoofer is active, it does not support line level (RCA) signals.
Just connect the subwoofer as you would a pair of speakers. Once connected, you make sure the front panel speaker switch on the Sony is set to A+B so you get sound from your existing speakers (A) and subwoofer (B).
I hope that works for you.
Feb 15, 2015 | Sony STR-DE597 Receiver
Just received a Sony Receiver STR-K650 with a sony video DVD recorder SLV D300P WITH NO MANUEL OR INSTRUCTIONS ON HOW TO HOOKUP THE TWO SYSTEMS AND PLAY iT.NEED HELP?
STR-K650:
http://esupport.sony.com/US/perl/model-home.pl?mdl=STRK650P&LOC=3#/manualsTab
SLV-D300P
http://esupport.sony.com/US/perl/model-home.pl?mdl=SLVD300P&LOC=3#/manualsTab
The above links will give you the instruction manuals and the connection guides.
Sep 07, 2011 | Sony STR-K650P
Can I hookup a Sony receiver STR-DE505 to a Bassbite 2 KLH Audio system and how??
Yes.
It's frustrating that KLH manuals seem impossible to find anywhere online BUT a simple picture will suffice...
Go here and supersize the picture of the rear of the sub...
http://cgi.ebay.com/KLH-Audio-Systems-Bassbite-V-Model-E214708-Speaker-/110673631693
Run your front channel speaker wires to the CLEARLY-MARKED connectors on the sub and daisy-chain your front speakers to the CLEARLY-MARKED connectors on the sub.
Adjust the sub volume to match the front speakers levels. This will give you local volume control at the Sony.
Jun 04, 2011 | KLH BB-II Subwoofer
Can I connect a passive subwoofer Sony SS-W581T to a SONY receiver STR-DH510 ? Thank you
No. Like most AVR's it only provides a Line Level output for an externally powered subwoofer. Get a separate amp for the sub.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DH510-Receivers-manual/id/23637ci375/t/2/
Apr 17, 2011 | Sony STR-DH510 5.1 Channels Receiver
I have a sony str-de 405 recevier . how do i connect a subwoofer to it .....
http://www.retrevo.com/support/Sony-STR-DE405-Receivers-manual/id/387bh944/t/2/
and refer to the manual that should have come with your unnamed subwoofer.
Mar 21, 2011 | Sony STR-DE425 Receiver
No sound output sony str
Unplug and replug connections in firmly and try again. Nothing? Check that the subwoofer is getting power. The sub sometimes has a built in fuse. Check that the fuse is not blown.
Feb 12, 2010 | Sony STR-DH500 A/V Receiver
read the manual
Sep 15, 2009 | Sony STR-DE845 Receiver
Trying to use a passive subwoofer with STR-DE445
The output of the Sony is "signal only" not power. Being "passive" like your sub. What you need is a sub amp, and they are not cheap, 400-600 on average "min". Unless you have a Velodyne 15 or 18, just get an amplified sub, they start around 150 new. Hope this helps
Mar 27, 2009 | Sony STR-DE445 Receiver
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
