My phocopier can't photocopy it ask me to contact a technical agent
I requested technical specifications of printer EPISON 1805 but I didn't get them.
If you requested the spec from a dealer or service workshop, ask the dealer or service workshop what happened.
Either way, ask Epson for the specs...
Jul 13, 2016 | Office Equipment & Supplies
What is error code 6 on krups ea850b10 means?
Error 6 means machine thinks it has a leak in one or more of the following
1) Distributor
2) Thermoblock
3) Pump valve
4) Pipe leakage
Repair will involve specialised tools and parts, not really the sort of job to attempt yourself. Contact Krups and get from them contact information for your local service agent.
Aug 03, 2015 | Krups Small Appliances Espresso Machine
It has a code 1334
C1334 Duplex take-up print
command error
• A Duplex take-up print command is not received for
the paper to be taken up from the Duplex after the
paper has moved past the horizontal transport, but
before it reaches the Transport Roller.
• The number of Duplex take-up print commands falls
short of the number of sheets of paper to be taken
up from the Duplex, or the leading edge of a sheet
of paper, for which a Duplex take-up print command
is yet to be received, activates the Transport Roller
Sensor.
Apr 09, 2013 | Minolta Office Equipment & Supplies
I would like to know how can i activate multimedia messages for my phone nokia x2
Download MMS and GPRS settings from the network provider. Or Just call the network provider customer service hotline and prompt to talk the technical support agent, and ask for activating your MMS and GPRS setting. next the agent will tell you how to do so.
May 06, 2011 | Cell Phones
Konica Minolta bizhub 163 Display M2. and not functioning Photocopy. Please sugest me ?
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
Dec 29, 2010 | Sharp AR-5320 Black and White Copier
Dec 29, 2010 | Sharp AR-5316 Advanced Digital Imager...
Photocopy of demende we contacted technical support
OK, what is the error code under the "Copier needs Service Tech"?
Jul 04, 2009 | Toshiba e-STUDIO 282 Black and White...
Equipments for TV broadcasting
tanderburg is fine but ask about dealer or agent near you for availlable technical support(this in case you have video conference in your businnes ).-ask for second hand machine to save your money and check it will befor you pay anything.-check for availlable manual on line-complete your connetion from radio shack near you.
Jul 15, 2008 | Nortel Lands Phones
Ricoh Aficio 1018 photocopier
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
k24674
jasbo
jasbo
