Question about Ovens
We have a Ignis built in fan oven model no all 906ix the back fan is working but the top fan in roof of oven not going round
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    barkencoa
    • 3463 Answers
    SOURCE: Faulty electric oven (Ignis AKL828/AV)
    I think you will find that it is the oven element that has shorted, causing the trip to go. The fan will still work, but with no heat.
    Remove inner rear panel of oven, there you will see the element.
    Remove and replace.
    Plz rate my solution.
    Thanks.
    Posted on Dec 30, 2008
    SOURCE: No heat from oven but fan and light works
    Timer might be blocked on auto, you need to get it back to a manual setting.
    Posted on Oct 18, 2009
    SOURCE: I had an ignis build in, single, fan oven, model
    Hi i have the same oven, Ignis AKL907/IX. Worked ok for 12 months but now cuts the power in the whole house out when the cooling fan is engaged. Just out of warranty and call out fee is
    Posted on Aug 28, 2010
    • 3 Answers
    SOURCE: Fan works but oven doesnt get hot
    One of the switches looks to be a 5 position switch. 0=off, 1=Light, 2=fan
    Posted on Sep 23, 2010
    Instructions for a ignis electric oven as there is no temperature guide or modes on front of oven
    I don't see what looks like your model anywhere, or a manual for any model, or a company website, so if no one can help you try this.
    The left dial could be- bake, broil, fan, convection cook, now the bottom pan should come out so you can see the bake element.
    Turn it one setting and see what happens, either broil (top),,, bake (bottom), convection fan (bottom), turn and wait to see what happens.
    Right should be temp, not sure if the dial has a stop or you can spin, but it at 12:00, put at 6:00 I say this maybe 300deg F.
    Get over temp gauge (cheap).
    If you don't get any help, then you need to try and see what does what and mark it down.
    If you can't see top burn, maybe top pan come out so you can see it.
    They get red hot, so you can tell which one turn on.
    Sorry, can't find any info.
    Apr 01, 2013 | Ovens
    I had an ignis build in, single, fan oven, model AKL907/IX installed in January, worked fine now, switches off when the oven is on, beeps and then can be restarted if pressing the ok button, however the...
    Aug 15, 2010 | Ovens
    Hotpoint sy36x grill element works fine but when switched on to oven it doesnt heat up, fan working.
    it seems to me that it is a fan oven and the top element won't heat up you need a new fan oven element. it is a round element that sits behind the back grill surrounding the fan...
    regards
    richard saupe
    appliance repairman
    Mar 14, 2010 | Hotpoint SY36 Style Line Stainless Steel...
    Built in oven front panel gets too hot
    No. There should be a fan that runs and blows cool air from a gap at the top of the door and over the controls.
    Feb 15, 2010 | Ovens
    Help!!!!!!!!
    Sounds like the oven element is faulty.
    This is usually located at the rear of the oven compartment behind a remov eable cover.
    Please rate my solution.
    Thankyou
    Jan 25, 2010 | Ovens
    Feb 24, 2009 | Ovens
    Remove and replace.
    Thanks.
    Dec 30, 2008 | Ovens
    Oven no heat
    for king louie
    fault is the circular element round the fan. take off the back plate inside the oven and you can often see the damage but not always. to get at the terminals, remove the rear cover and test for continuity across the element with a multimeter - remove any connections before doing this and note down where they go
    for tarzantony.
    i can't remember where the cutout is but probably on top of the oven or close to the fan on bthe back. just trace the wiring from the element and it should lead you to it
    Mar 25, 2008 | Neff U1721 Double circotherm Electric Oven
    Wall Oven No Power
    yes the oven thermal fuse blew when the fan went off its also called a tco switch if you pull out the oven and take the top off there will be a tech sheet there that will give the location of the tco some are on top some are on back this can also happen if the oven is too tight in the cabinet not enough room around it to let the heat dissipate its a round metal disc with two wires on it
    Jan 30, 2008 | GE JKP30WMWW 27" Built-in Single Electric...
    Ovens Logo
    24 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
