Question about Mitsubishi Televison & Video
Hello. My t.v. Mitsubishi is having difficulty I turn it on we can hear the cable but the picture doesn't come on. Then the green light is not green it turns red? What can we do ?
  • 1153 Answers
SOURCE: Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Posted on Sep 18, 2007
  • 1153 Answers
SOURCE: Mitsubishi VS-50607 Won't Turn On
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Posted on Oct 06, 2007
  • 239 Answers
SOURCE: Mitsubishi 52" WD52725 flashing green timer light
your projector bulb went out. you need to call the manufacturer and order a new bulb. they cost 300 to 400 dollars a piece I believe your tv only has one bulb and they are really easy to install.
hope this helped
please rate well.
Posted on Mar 06, 2009
MNfisherman
  • 11896 Answers
SOURCE: Mitsubishi VS-50603 Wont Turn on
The power supply will need to be changed. The capacitors inside the power supply are not sending the correct amount of power to tv and will need to be changed.
Posted on May 13, 2009
  • 16 Answers
SOURCE: WD-52525 - No picture, green status light then turns to red lamp
check the lamp
Posted on Jun 26, 2009
My Mitsubishi 73 in SDLP works fine for about an hr then turns green and starts jumping. I can turn it off and back on and it's good for about 15 mins. If its off for a while it starts within a hr
Hello. When the picture changes color after warming up, chances are that the color wheel is defective. If you get close enough, you might be able to hear a whining sound. If you do hear a whining sound, you definitely have a bad color wheel. Some color wheels are still available from Mitsubishi. Good luck!
Jul 31, 2016 | Mitsubishi Televison & Video
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
My mitsubishi modelLT-52151 has green picture only how can i fix this?
Hello, if your using the "component" inputs check or change the cables or try it on different inputs and see if you still have the green picture. if you do, it may have either a bad T-con board or a bad main board, there's no way of telling which without a tech looking at it.....tks
Jan 09, 2015 | Mitsubishi Televison & Video
My tv turns but it doesn't show a picture but you can still hear
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 28, 2012 | Mitsubishi WD-60737 60 in. HDTV
After researching online, my TV problem seems pretty common. TV - Mitsubishi 1080 series WS 55511. Green blinking light blinks for 3 seconds, then goes out and TV never turns on, but I hear a slight...
The green light is known as "The blinking green light of death". This refers to the green LED on the front panel of the TV that normally blinks when turned on after a power failure or when unplugged: the green light is supposed to flash for about 1 minute while both microprocessors boot up: If it won't stop blinking it means that they aren't communicating w/each other. Unfortunately, it's common in Mitsubishi & other RP TV's. Getting this fixed by a professional is around $6-700 with labor, parts, etc. It's really not worth it in my opinion. I would go out and buy an LCD or an LED TV.
Nov 28, 2010 | Televison & Video
No picture with sound
yes , u need a new lamp shop around , cost less
May 08, 2009 | Mitsubishi WD-Y57 57" Projection HDTV
Flashing Green Light
My apologies Pete but I just saw your request until this morning and I was going to suggest to check for any loose or unplug wires/cables.
I'm glad everything worked great for you.
Nov 08, 2008 | Mitsubishi WS-65713 65" Rear Projection...
Mitsubishi WS-55909 dm board repair
I have a mitsubishi 48" integrated 1080. The Timer green light keeps blinking. I have no picture. Can this be the fuse? My coworkers say this might be the problem. Can I replace it myself? If so, where is it located?
meeh.shell@yahoo.com
Oct 13, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Open Questions:
Televison & Video Logo
55 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
