Question about Sharp Office Equipment & Supplies
Sharp compet CS-1780 Machine won't advance paper. When I push the paper forward key it just buzzes and the paper won't advance. The calculation functions seems to work well
4 Suggested Answers
vladp995
  • 81 Answers
SOURCE: need a manual for a sharp compet cs-1680
I didn't find nothing about such calculator, is it real, try to look here:
http://www.retrevo.com/samples/Sharp-Calculator-manuals.html
or here:
http://www.usersmanualguide.com/sharp/calculator
or here:
http://www.sharpusa.com/products/TypeManuals/0,1083,15,00.html
Rate me please, thanks.
Posted on Jul 11, 2009
SOURCE: Have a Sharp Compet CS-2790 calculator. How do I change the
I work for the state and cannot incur a charge. Sorry for posting my question. The problem is still not fixed. Was trying to help someone else that has the calculator.
Posted on Oct 08, 2009
emissionwiz
  • 75077 Answers
SOURCE: My Sharp EL-2630PIII calculator has
turn the machine on its back, there you will find 4 or 5 screws, remove them and separate the cabinet from the chassis bottom, this provides access to remove the paper jam. also below find a link to the user manual on pdf.
http://files.sharpusa.com/Downloads/ForHome/HomeOffice/Calculators/Manuals/cal_man_EL2630PIII.pdf?cal_man_EL2630PIII.
Posted on Oct 21, 2010
How to install paper
Without a manual, look at the picture of the calculator. Mount the paper, with the feed coming forward and over the top of the calculator. Insert the paper (recommend cutting it flush) into the feed slot in the back. Then use the paper advance key to advance the paper through the rollers. Unfortunately the manual is not available from the Staples website. Good Luck,
Mar 02, 2015 | Staples SPL-P100 Printing Calculator
Paper does not advance properly on my sharp el-1801p calculator
probably there is paper underneath the printer..if you are handy you have to open the printer underneath to take stuck paper out.
or take apiece of clear place ,that can enter where you pass the paper.and let the plastic come the other side out.
probably it willcome with anything that is stuck beneath the printer
M.P
Sep 11, 2014 | Sharp EL-1801P Calculator
Oct 07, 2009 | Sharp Office Equipment & Supplies
Need a manual for a sharp compet cs-1680 calculator - received one and I need a manual to know how to work it
or here:
or here:
Jul 11, 2009 | Office Equipment & Supplies
I can't figure out how to load the paper into the Sharp EL1701v!!
Well depending on the model ther is often a small slot on the back of the calculator where the paper would feed through, you would push the paper in then press the feed key, which is often on the top left corner of the key pad. If you still cannot get the paper to load then call us at 1-800-BESHARP. or 1-800-237-4277.
Jun 30, 2009 | Sharp Office Equipment & Supplies
How do I thread the paper tape to the machine
Hello, my name is Curtis, and I am a Sharp Customer Service Rep. What you will want to do is on the back of the calculator there should be a thin horizontal slot that you would feed the paper through, it will only feed so far before it hits a wall on the inside, make sure the calculator is turned on and press the feed key in the upper left side of the calculator, it should take up the paper, if not then give us a call at 1-800-237-4277 or 1-800-BE-SHARP. Hope everything works out.
Jun 08, 2009 | Sharp EL-1801AII Calculator
Loading paper
Cut paper at an angle and insert and push into back slot with tip of angle (apex) to the right of machine when facing it. It should engage number wheel when you hit addition sign, You may need tweezers to pull it thru if it doesn't advance.
Jun 20, 2008 | Canon P23-DHV Calculator
Casio FR-2650A
the tape goes into a small slot on the backside of the machine, not in the clear plastic cover. Install the roll so the paper rolls off the bottom, not over the top. Folding the paper back about 2" does help you get it through.
Aug 30, 2007 | Sharp CS-2850 Calculator
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
