Question about Water Heaters
I have a ITT Grinnell Excello Gas heater in my garage. Model PTO-50. The pilot lit will not stay lit. I ned to change the thermocoupler. Where can I get a manual that shows how to get at it?
  • Water Heaters Master
  • 2,464 Answers
Google the make and model number this should bring up the makes web site and you can download manuals from there .
Posted on Dec 31, 2016
SOURCE: i have a richmond gas hot water heater model
resetting your lock out for richmond power vent
Posted on Nov 26, 2009
john224
  • 1378 Answers
SOURCE: Natural gas hot water heater not stying lit
Probably a bad solenoid in the gas valve. Higher voltage of a new thermocouple keeps it open longer but it still fails over a period of time. Look into a new gas valve for the water heater.
Posted on Dec 17, 2009
kel1guy2002
  • 3740 Answers
SOURCE: pilot light on water heater wont stay lit
The thermocouple has failed. It is the temp probe that goes from the pilot lite burner area to the control valve. Go to your local plumbng repair shop and buy one. Most appliance parts stores have them also. Take the old one with you and they will hook you up with an exact replacement. They are not that hard to change. Usually a nut or 2 screws in the temp bulb area at the burner end and a nut that threads into the control valve.
Make sure before you install the new one that the area where it mates to the gas valve is clean. Should be about a 20 min job including clean up with replacement parts in hand.
Posted on Jan 23, 2010
Testimonial: "exactly what I wanted yo know. thank you"
  • 454 Answers
SOURCE: I have a Rheem 50 gal. natural gas water heater
The most common reason a pilot light will not stay lit is a bad thermocouple. How old is the water heater? If the pilot light will light, but then go out when you release the safety button, that is a sure sign the thermocouple is bad. You can buy a replacement thermocouple at your local home improvement store. There is a small chance that the control valve has gone bad, but that is highly unlikely.
Posted on Feb 23, 2010
SOURCE: Pilot won't stay lit in Reliance 606 gas water heater
The Reliance 606 has an enclosed thermal couple. Before you try taking that assembly apart take a wire brush to the bottom opening directly under the burner. There is a metal filter on the very bottom of the water heater. It could be that the filter has gotten filled with dust or animal hair. It took a serviceman 2 days to figure this out for me. The water heater has to have good airflow through that filter to work well.
Posted on Sep 29, 2010
I have a Rheem21vp50e1a hot water heater. the vent is running continuously but the pilot is not on. Turned it off to reset and it will still not run. The house has gas so what could be the problem.
More information is needed to give accurate do-it-yourself help.
Have you changed the thermocouple?
http://waterheatertimer.org/pdf/How-to-replace-thermocouple.pdf
http://www.youtube.com/watch?v=v0aBPsNg6vo
Some model numbers do not have a standing pilot light.
What do the re-light instructions show on side of unit next to gas valve? What does your manual say?
What type of gas control valve does unit have. Is this electronic gas control valve?
Add a comment with information.
Open following links for READING about general pilot light problems across different types and models of water heater: do-it-yourselfer will find useful resources.
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Standing-pilot-light-maintenance.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 02, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem 22V50F1 pilot won't stay lit. Changed thermo couple & it lit, ran then went out. Let it sit overnight & it lit, ran then went out. What next? p.s. The unit is 5 years old. Thanks
If pilot lights and flame is robust and clear blue, and pilot goes out later, then some suspects can be excluded: air in gas line, low gas pressure, thermocouple is overtightened (finger-tight + 1/4 turn), thermocouple not positioned correctly in the flame, dirty pilot tube.
If flame is yellowish and small: then clean pilot tube and combustion parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Remaining suspects can include: air in gas line, low gas pressure, bad gas control valve, tight house so household vent fans pull air down water heater vent that blows out pilot, hot attic with inadequate ventilation, water dripping down vent.
Open following links to read troubleshoot resources.
Aug 16, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Pilot won't stay lit, replaced thermalcouple but
I would remove pilot light assembly and clean orifice and blow out gas line to pilot. Check to see that thermocouple is centered in pilot flame. It is possiblethat your gas valve is bad but it is also possible that you got a defective thermocouple. I would change the thermocouple again as they are much less expensive then the gas valves. The next time when you are sure you have the thernocouple mounted as close to the center of the pilot flame hold the pilot button down for several mins. If none of this works then you may have to change your gas valve.Thank you.
May 06, 2011 | Rheem Water Heaters
I have a Rheem 50 gal. natural gas water heater mod#21V50-6A followed all instruction and can't get pilot light to stay lit.
Feb 23, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
I don't know how to restart my old bosch water wizard 10p, pilot light has gone out.
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
Jul 12, 2009 | Bosch & Tankless LP Hot Water Heater
I have replaced the control valve and thermocouple but burner wont stay lit. when burner shuts off so does the pilot
Thermocouple is probably not adjusted in to the pilot flame correctly, readjust and try again, if that does not work replace the thermocouple, not all brand new thermocouples are good right out of the bag
Jul 01, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Pilot light won't stay lit after release of gas valve.tried few t
Most likely it's time to replace the thermocouple, the safety device that makes sure the pilot is lit. New thermocouples are cheap and you can find them at most hardware stores and the big-box places (Home Depot, etc.)
Here is a site with basic information to get you going.
Apr 08, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water Heaters Logo
70 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
