Question about Water Heaters
My boiler is using a huge amount of propane. What are possible reasons?
  • Water Heaters Master
  • 3,313 Answers
Outside reg leaking on tank , leak on tank , Depends what you call huge ?
Posted on Dec 31, 2016
Ignition at Orifice
The gas control valve is passing . It will need a replacement.
Mar 10, 2014 | Water Heaters
Bosch propane boiler
Some times you have to bleed the line
Dec 27, 2013 | Water Heaters
Keeps giving a code of ops on boiler and will not kick blower on
Are you certain this is a boiler? Furnaces use blowers; boilers do not.
Could you be referring to an induced-draft small blower motor that normally runs immediately on a call for heat?
Is there an electronic control board measuring about 6 inches by 8 inches visible?
We can help if you give us a model # and brand name. Does it operate by oil, natural gas, or propane (LP)?
Feb 02, 2013 | Water Heaters
Boiler keeps going out
have you checked that you thermostat on wall is set to a reasonably high temp. if not when room eaches temp setting , then the boiler will switch off,. Other than this obvios one , i would suggest you could google your boiler for the manual /instruction.
Parts For Porsche Cayenne
Jun 11, 2012 | Reliance Water Heaters
Wocester 37cdi condensing boiler when on low fire makes a reverberating noise that appears to come from fan/burner gas mixing assembaly whentemp arond 50 -55
Does the lit gas vary in amount of flame ? Are the gas jets clean?
Is the autovent screw opened at least 1/2 to 1 turn?
Possible resonance within the boiler casing - press and hold side & front panels to suppress the resonance frequency
Mar 14, 2010 | Water Heaters
Ferroli boiler error code A3
boilers need a certain amount of water pressure to operate as specified--there may be a pressure regulator valve, allowing a certain amount of water to your boiler, and when water is drawn elsewhere, there may not be enough getting to the boiler---this is one possible solution, but there are easily 20 more, and that is where a trusted plumber is worth it's gold...very difficult to diagnose most plumbing problems without being onsite
Mar 03, 2010 | Water Heaters
How is liquid lpg system set up? i have a aqua star mod.125vp that i would like to install in my home, the liquid lpg. is the part im not shure about. thanks d.r.
The lpg either cylinder or gas tank must have a pressure reducing valve which sets the gas pressure to that required by the boiler.
After that valve the piping is the same as for any gas boiler.Where the pipe goes through the wall floor of similar - make sure the pipe has a sheath to protect it from gouges and or wet
The regs - Not sure about the USA but here in UK we have comply. different regs for tank or cylinder
The lpg supplier is a good source of info
Feb 16, 2010 | Bosch 1600H-LP Liquid Propane AquaStar...
Locating pump on Baxi Back Boiler
hi this problem sounds like a pump problem. now if its not in the airing cupboard, sometimes they can be besides the boiler in a cupboard or under the floor where the boiler is sited, or boxed in in a dummy casing either side of the boiler/fire unit.
i suspectthatthe pump is stuck & needs releasing or worse case scenario a new unit fitted.
The reason you mentioned about frequently getting air in the system is condusive of sludge build up or the pipe-work configuration is not installed correctly giving rise to air being drawn into the system & posing future probs such as component failure.
If the pump is sited under the floor by the boiler it is at risk of collecting sludge as its at the lowest point in the system.
Recommendations re-site the pump if possible & look to have the system power flushed, to assist the life expectancy of the system
Kindly
Richie
Dec 02, 2008 | Water Heaters
Instructions for my Ideal Mexico CF60P Propane boiler
Hi tessajoe,
I'm Harvey, the master plumber. You asked where you can
download instructions/user manual/installation guide for
Ideal Mexico CF60P Water Heaters. I believe this is the correct link:
http://www.chspares.com/partselect.php?test=121
Some Companies will e-mail it, others will respond if you call them on the phone and they will fax it or mail it. Contact info on the link that you requested form me.
I'm happy to help you!
Feel free to contact me.
Harvey the Master Plumber
Sep 07, 2008 | Water Heaters
Water Heaters Logo
64 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
