How do I transfer my iPad photos to my computer
First, Plug your iPad into your computer using a iPad charging cable, iTunes will usually by default open, just hide the window,, as well an AUTOPLAY window should open, find where you can see "open folders", click, Windows explorer will show an internal storage image file, double click the internal storage image, you should see a folder called DCIM, double click the DCIM folder. Once open, you should see several folders with funny numbers and letters, they make no sense, but, this is where images that were either, captured by camera or, from the iPad desktop capture feature will be stored, along with any other software that has the ability to capture an image and save it to the camera roll. You can open a folder or select one by clicking once on it, then press CTRL & the letter "?", this selects all the folders, the press CTRL & the letter "C" this will copy all the selected folders, then open your pictures folder, or where ever you'd like the images saved, press CTRL & the letter "P" this will now paste all the folders with the images from your ipad into the location you have selected. Done! Alternately you can sync your iPad, however you must first select the correct setting within iTunes to sync to the correct folder, as well you can turn on iCloud Drive and sync your photo's to the cloud system, which leaves a folder with all the synced images inside the iCloud folder. I hope you have found this information helpful, if you have please leave a positive rating. Good Luck!
