Question about Welding Tools
I have a 350 xmt which is holding power. It is clean on the inside, all cords are connected, and it is not giving any codes. The welder is not putting out any amps. Any ideas on the problem?
  • 1388 Answers
SOURCE: 225 thunderball,has no plug cord,need to know
The following link will provide you with information about a 225 thunderbolt. We have serviced many Miller welders over the years and find them to be very reliable. Good luck with your project.
http://www.millerwelds.com/om/o316g_mil.pdf
Posted on Jun 23, 2009
97F350diesel
  • 1326 Answers
SOURCE: watt size fuse do i use to connect a 350 watt
You use the same amp fuse as on your amp, nothing larger. The fuse just keeps the wire from overheating/shorting and causing a fire.. IF you amp has a 30 amp fuse then you use a 30amp fuse off the battery
Posted on Sep 14, 2009
bubby001
  • 18 Answers
SOURCE: Connecting 220 plug to 185SG welder- Power cord on
are you sure you have the right plug?wite wires are normaly found only on 120v and 347v systems. but if it realy is 240v then black to black, red to wite and yellow/green to green.
Posted on Oct 26, 2009
Testimonial: "I bought the plug from Airgas welding store, and your color intrepretation worked perfectly, Thank You"
SOURCE: lincoln mig welder 180, 230 volt 20 Amp Input.
Inspector is correct! In wall or conduit wiring awg will always be greater than "open air" wiring. IE: the size of wire coming from your pole ... it's smaller than from your service riser into your meter. Code allows the cord to heat up... open air will cool it down.
Posted on Dec 13, 2009
boss408
  • 43 Answers
SOURCE: The connection where my power cord plugs is loose
Acer Aspire 4720 4720G 4720Z Notebook Service Guide
Posted on Sep 14, 2012
I have a HEL p-6 code on a xmt 304 how do I fix it
Sounds like a input power problem . Make sure voltage is correct coming to the unit and wired correctly. I checked a Miller welder recently ,auto link that would come on and weld but not good . Took cover off and it was wired wrong .
Dec 08, 2014 | Welding Tools
Install a power cord
Depends on what kind of welder we are talking about. Different welders have different power plugs and there are also different prong outlets. Explain your situation.
Sep 17, 2014 | Welding Tools
200P AC/DC /PLASMA WELDER WONT WORK
try cleaning the ground inside the welder. and make sure you have a good power supply ie. power cord. check the transformer for continuity and clean all the contacts ( are you sure the power inverter diodes are only passing current one way and are not "open" )
Nov 24, 2013 | Welding Tools
Burning up tips fast with Miller S-22A
tooslow and probaly too close to work piece try turning heat down a little also make shure you have a good ground/ maybe angle your gun a little more
Dec 17, 2012 | Miller Welding Tools
I have a miller xmt 304 i bought it used. i have a 12vs wire feeder on it and im not getting power to it. any suggestions on what the problem could be
Hi:
Ok, let troubleshoot this one.
There is only two connectors on your 12VS wire feeder; the lead cable that goes to the + side of the XMT welding machine and the VS cable (Volt Sensing) that goes to you work piece joining the ground cable (don't forget the ground clamp).
a) The mode switch on your XMT must be on V-sense feeder.
b) Your 12VS feeder depending on what kind of wire you are using (innershield) negative side or gas wire + side.
That's it. If there i no spark, there is something wrong with your XMT.
If this was useful to you please vote. Thanks.
Apr 01, 2011 | Welding Tools
Welder doesnt turn on...
Have you connected the feed from your breaker box to ADJACENT lugs on a dual pole breaker? By code you must use a ganged breaker.
You should use a voltmeter to verify the plug is getting power on teh desired pins.
Sep 25, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Millermatic 200 will not weld
1 - Check the ground connection to the work, including the actual cable to clamp connection.
2 - Make sure that the wire feed rollers are nice and clean. The wire needs to be clean too.
3 - Check that the polarity changing wire connections are nice and tight, clean, etc.
4 - change and or service the contact tip at the end of the gun.
as always, gently clean out the loose junk inside the case. A clean welder is a happy welder. :-)
Nov 16, 2008 | Welding Tools
Welding Tools Logo
109 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
