Question about LG RUMOR Cellular Phone
How do i make a song from my sd card/tunes my ringtone?
  • Chris
    Chris May 11, 2010
    If your LG phone is like mine, you need to text the sound file to yourself and when it arrives in your inbox (and it usually has to be less than 350 KB) you can go to options and set the file as your ringtone.
4 Suggested Answers
SOURCE: my mobile's music player wont recognize my mp3s
I had the same problem and found the solution on the following site!
http://www.lg-vu.com/index.php?topic=2660.0 Reading thru the blog you will find the best solution is to download the MP3 tag which there is a link for and untag the retag your MP3's and they will work. So easy but up to 6 hours or more to locate.
Scooter72908
Posted on Feb 04, 2009
SOURCE: I am adding music on SD card, by a Mac, but when put card into ph, it does not transfer to "My Music", it transfer to audio/ringtones
make sure you read the manual about your phone to see which music file format does it support(MP3, WMA etc).
Posted on May 31, 2009
brennan0331
  • 12 Answers
SOURCE: How can I get the music I put on my sd card to be ringtones
Well first off you need two save your ringtones to the card and then plug the sd into your computer. The sound your trying to turn into a ringtone will need to blend in, meaning you will need to make sure its the same format as the other ringtones, and place it in the same folder.
Posted on Dec 29, 2009
How can i get ring tones from windows 7 to my phone
Go to your app store and install a ringtone maker, then select the music from the SD card, edit it to the part you want, and save it as 'song name ringtone' (so it doesn't overwrite the original song).
Mar 10, 2015 | Cell Phones
Ringtone maker can't find some songs in google play
it is usualy the songs are saved on external sd.. if you don't have one..buy
Mar 22, 2014 | HTC Cell Phones
Set my fav tunes as ringtone ?
Ringtones or songs downloaded or copied to your storage card are not automatically added to the ringtone selection menu. You need to go to the Music application and set a ringtone or song in your storage card as your ringtone. To do that top up arrow and Music then tap the three paralel lines at the bottom-left corner of the screen to go to the Library. Play the song that you want to use as a ringtone and on the Playback screen, press MENU and then tap Set as ringtone.
To change the ringtone press MENU, and then tap Settings. Tap Personalize > Default ringtone. The Phone ringtone selection menu then opens and you can scroll through the available ringtones and tap the ringtone you want to use then tap OK.
Feb 14, 2011 | HTC Wildfire Cell Phone
I want to download an app to download songs and ringtones
Method 1:
Transfer the song(s) you want to set as ringtones onto the microSD card either by connecting to pc via USB or using an SD adapter. Next, Tap on the Music Player, open the music list, press the menu button and select PLAY ALL, this will scan your SD card for music/audio files. Once all your songs have been added to the list, select the song you want to set as ringtone and click MENU key, choose SET AS RINGTONE and that will take you to the RIngtone Trimmer, make the ringtone 30 seconds or less, select Trim and you're done.
Method 2:
Root your HTC Hero, create a directory in your C: drive and name it HeroRIngtones, HTC, or whatever and put there all the ringtones you want to be added (30 seconds or less), then open Command Prompt; make sure your device is connected and already visible. Run the following command "adb push directoryname/myringtone.mp3 /system/media/audio/ringtones" and press enter. Do same procedure for all the audio files you want to set as ringtones.
Method 2 is not available for non-root users.
Dec 17, 2010 | HTC Hero Smartphone
How do i use songs from my sd card as ringtones
The phone is not designed to read data stored on a sd card. Acquire the ringtone from the network instead or upload the tunes on the SD card onto a computer to be saved to a network site from where to download to the phone which should have been connected by which time the network.
Dec 04, 2010 | LG Neon GT365 Cell Phone
Ringtones
The phone will only play ringtones applied to its memory. You need to move the tone from the SD card to the phone. First check your user manual for ringtone specifications. It should tell you how big a file you can use.You may have to edit the song to fit.
Aug 17, 2009 | Cell Phones
Need help with my micro sd card!
What format are the songs you have on your memory card? What format does your phone support for Ringtones??? Likelihood is the phone doesnt support ringtones in the audio format your trying to set, thus when your going for them it wont see any available ringtones
Jun 13, 2009 | Cell Phones
Can i put a song from my SD card as an ringtone on my pantech duo?
You can but the file needs to be labeled My Ringtones. If you have tones in the ringtone folder and its still not working check the size and format of the tones, windows mobile 6 was only designed to accept tones under 320k and in .mp3 or .wav formats.
Sep 07, 2008 | Pantech Duo Smartphone
Ringtones
lal you hato do is download the songs in to a mico sd card en get ringo T www.ringo.com and try
Apr 17, 2008 | AT&T 8925 Tilt Smartphone
Not able to set my fav song as ring tone
If you convert the song to mp3 format, you can set it as a ringtone.
Mar 29, 2008 | Pantech Duo Smartphone
LG RUMOR Cellular Phone Logo
124 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
