My switch that turns on heater,air conditioner blinks when turning on air conditioner
  • Heating & Co... Master
  • 1,655 Answers
Typically means you are in a brief time delay.
Posted on Mar 02, 2018
  • 391 Answers
What is the make and model of your Air Conditioning unit? Airbulance would love to help you with your Air Conditioning Repair problems.
Posted on Mar 01, 2018
  • 236 Answers
SOURCE: Air Conditioner will not turn off with remotes
Remote control has a reset button found in front or at back inside battery compartment. If you replace your remote control with battery or your remote control is malfunctioning you to reset it.
You don't have to go outside to turn off the unit, you can "on" or "off" the unit using the emergency operation switch.
Posted on Jan 02, 2008
  • 95 Answers
SOURCE: air conditioner blower
it sounds like a thermostat or sequensor problem in the air handler
Posted on Jun 25, 2008
  • 958 Answers
SOURCE: Exterior fan does not automatically
could be a stuck relay that control the fan. check the 24 v relay or 24V magnetic contactor. could be a welded contact also.
tnx 4 using fixya,
Posted on Oct 09, 2008
  • 3361 Answers
SOURCE: Snowflake blinking and air conditioner won't turn on.
If it is blinking it is in a 5 minute time delay.
It should settle to a steady snowflake after 5 minutes and come on normally.
Posted on May 25, 2009
  • 9 Answers
SOURCE: My old Amana air conditioner will not turn on. Is
I need to know more. when you call for cooling does the indoor fan run? Does the contactor at the outdoor unit pull in? Have you looked at the fuses,breaker. If it has been very hot lately open the outdoor unit and look for a thing that looks like a large battery it should have 3 to 5 wires on it this is the run/start cap the high outdoor temp will sometimes make this fail. You can see a failed cap 85% of the time just by looking it will have a defromed top or be leaking oil. YOU DON'T WANT THIS OIL ON YOU!
Posted on Aug 30, 2009
Why is my Kenmore 72012 blinking?
Does the display blink no matter what is displayed? If the display always blinks the same info, what might that be(i.e. error code)? If you are able to cycle through settings and the display changes while blinking, the problem is likely in the control circuitry. The controls have a built in delay to protect the system from abrupt changes. You'll notice this delay, and the blinking display, when you first turn these units on and when changing modes.
Jul 12, 2014 | Kenmore 72012 Portable Air Conditioner...
2004 chevy Impala my heater and my air conditioner wont blow air
start with using a meter to test for power start from fan back to switches need to check harness and connectors
Nov 02, 2017 | 2004 Chevrolet Impala
Heater controls dont turn on
check all 20 amp and check the 10 amp fuse to heater and air conditioner control, problem could be in the heater and air conditioner control switch,let dealership check it out.
Sep 01, 2012 | Cars & Trucks
I'm using whirlpool mastermind chrome split ac.. clean filter light started blinking so i cleaned and replaced the filters but still CLEAN FILTER light is blinking. please give a solution
If you didn't turn the Master ON/OFF Switch to OFF, before removing the filter. That is the problem. To clear the error message. Turn the Master ON/OFF Switch to OFF, unplug the unit, remove the filter and reinstall it. Wait 10 minutes, plug the unit back in, turn the Master ON/OFF Switch to ON. The controls should have reset themselves and the clean filter light should not appear.
Hope this helped you solve the problem. Please let me know. Thanks.
Jun 12, 2011 | Whirlpool ACC108PS Air Conditioner
My tank says I have 32 gallons left but the heater won't work (rinnai 556f). It turns on for about 15 seconds and the light on the power button turns red and starts blinking. What does this mean?
If you hold down the economy button and the up and down arrow buttons for 5 seconds the unit will start an error code display. Get a helper and yell out the numbers when they start blinking. Post the error codes and we can help you
Dec 23, 2009 | Rinnai EnergySaver 556 Air Conditioner
Turning heater on : combustion air switch failed to close?
This air switch proves that the inducer motor is running and moving air. If not, check to make sure that the inducer motor starts and that the flue is free of bird nest, ice/snow, or some other critter that found a new home.
Oct 03, 2009 | Coleman Propane Forced Air Heater...
My carrier A/C turns off by itself but the light blinks
Switch OFF the circuit breaker of ac, after 5 seconds. Switched ON the circuit breaker. If this will appear again try to check the wiring connection of ac.
Jun 17, 2009 | Carrier 36KCARMS Air Conditioner
Air conditioner and heater come on by itself
Has anything been changed since it last worked well or normal? Thermostat ?
Aug 04, 2008 | Coleman Mach III Air Conditioner
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
