Question about Lexmark Wheelwriter 2500 Typewriter
My IBM Wheelwriter 2500 won't keep items in storage if I turn it off. It will store as long as I have it on, but when I turn the power off, it deletes everything I have entered into storage.
  • 478 Answers
Needs new batterys
Posted on Feb 02, 2017
  • 3594 Answers
SOURCE: Store Information
To clear an address in memory press and hold delete key on the l. side of keyboard and 01-99 to clear those addresses. To store info. press and hold store and the address 01-99 where you want to store it, when complete press store again. To print press play and the address.
Merry Christmas
DickyO
Posted on Dec 28, 2007
JayBlair
  • 328 Answers
SOURCE: IBM Wheelwriter 1500
All WW machine switches are is the upper left rear of unit. Red lever.
Posted on Jan 12, 2009
  • 3594 Answers
SOURCE: how do I store & then retrieve the stored item
On the L. side of the keyboard are 3 keys store, plat & delete. To store hold the store key and press 00-99 for an address, type info., press store again. To play hold play and press address, the delete works the same way. to find out what is in memory press code and "D".
DickyO
Posted on Jan 19, 2009
  • 3594 Answers
SOURCE: IBM Wheelwriter 6 - No Impact
We sell the solenoid pad for 20.00 includes instrictionxs and shipping.
DickyO
Cleveland Business Machines
216-241-027
Posted on Aug 18, 2009
  • 49 Answers
SOURCE: IBM Wheelwriter will no longer turn on. The
Turn off the power. Check inside the machine for staples, paper clips etc. that could be shorting on electronics. Remove the printwheel and turn on the machine to see if the carrier will travel to the left side frame and then move to the left margin position. If not, turn off machine and move carrier manually to the middle of the machine and repeat the power on. If the carrier will move to the left side frame, then try cleaning and lubrication the carrier mainshaft ( by the rubber belt). If no carrier movement is present the machine will need extensive troubleshooting.
Posted on Nov 16, 2009
Testimonial: "Thanks! "
How do i use the memory function on my ibm wheelwriter 6?
Before we start turn it on after it completes is power on just the #1 light should be lit this says the batteries are OK. If they flash replace the batteries and clean the holder.
To store hold the store key while entering an address 1 - 99, type info then press store again.
To play press play with the address.
DickyO
Oct 07, 2014 | IBM Wheelwriter 6 Typewriter
My IBM Wheelwriter 2500 isn't typing at all.
Try a new printwheel, look for debris in the P/W area.
DickyO
Mar 21, 2013 | IBM Wheelwriter 30 Typewriter
I recently acquired an ibm wheelwriter 6 type 674X typewriter. I have looked on line for an instruction manual. I can't find one for this model.i am wanting to type labels or phrases repeatedly and am not...
To record you hold down"store" and hit "1" that opens the storage unit. Type what you want to keep. when finished press "store" again. that closes that storage unit. When you want to play that , hold "play" and tap "1" that storage unit will play out. You can repeat this in storage areas "1" to "99" until the memory is full. To delete the storage unit, hold "delete" and hit a paticular storage area, such as "1" all will be deleted.
Jun 21, 2010 | IBM Wheelwriter 6 Typewriter
How do I store information to be typed, edit the typed info then play and print on a Lexmark Wheelwriter 2500?
There are 3 keys on the L. side of the keyboard, store, play and delete. To store hold the store key type an address 01-99, rel. store key, type info, press store again. To play hold play ket type the address, rel. play. Delete works the same way.
DickyO
May 24, 2010 | Lexmark Wheelwriter 1000 Typewriter
No user manual for my IBM Wheelwriter 6
You can download the IBM Wheelwriter 6 series II 6784 Operator 's Guide from Lexmark site (look for "IBM Typewriters" in the bottom of the page):
http://images.lexmark.com/publications/pdfs/2007/index/en.html
If all you remember is the # 80, maybe what you have to do is insert the the paper in the machine and then press [PLAY] + the number 80 and, then, each time the playback stops at a stop point, type the variable text to be inserted (check the " Playing back a repetitive letter" section of the manual).
You can also get a print "directory" of all text stored (check the "Advanced Storage" chapter).
Hope this helps.
Jul 23, 2009 | Lexmark Office Equipment & Supplies
I have lost my manual for the IBM Wheelwriter 6. I need directions to use the storage application for this model. Can you help me. Thanks annie_o46@hotmail.com
On the L. side of the keyboard there are 3 keys store, play & del. To store hold store and put an adress 1 - 99, release store, type info. when finished press store again. To print press play and the address.
Be sure the batteries are good and the holder is clean.
DickyO
Feb 18, 2009 | IBM Wheelwriter 30 Typewriter
How do I store & then retrieve the stored item
DickyO
Jan 17, 2009 | Lexmark Wheelwriter 6 Series II Typewriter
IBM Wheelwriter 30 Series II
On the l. side of the keyboard there are keys labeled store, play & delete. Press & hold store then type an address 01 thru 99 release store and type whatever you want. Upon completion press store again. To play it back press play and the address, to clear delete and address.
DickyO
May 16, 2008 | IBM Wheelwriter 30 Typewriter
IBM personal wheelwriter 2 memory
I have a IBM Personal Wheelwriter 2 by Lexmark and when you turn it on it beeps and then the single and double space lines light up and stay on but the it will do nothing else. (It's like it is locked up
Mar 25, 2008 | IBM Wheelwriter 30 Typewriter
Lexmark Wheelwriter 2500 Typewriter Logo
93 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
