Question about Miscellaneous
What are Costco/USA hours on Christmas eve? - Miscellaneous
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Miscellaneous Master
  • 102,366 Answers
It may vary from store to store, but my nearby Costco will be open 9:00am - 5:00pm on Christmas eve. For your local Costco, try http://www.costco.com/warehouse-locations?langId=-1&storeId=10301&catalogId=10701&COSTID=Header_Locations_MAIN
Posted on Dec 19, 2016
Tip
While preparing our families Christmas Eve dinner The dreaded F7 error code...
Do you have the dreaded F7 message pulsating from your oven? The original purpose of the F7 message is to signal a stuck START key, which is a rare occurrence. The more common cause is a type of short circuit that occurs in the touch panel near the cable slot. The fix that I will describe addresses this type of fault. It will not fix a stuck START key. It will not fix a faulty Electronic Range Control (ERC). If you are getting other errors, such as F1, the fix may still do the job. F0 is usually a shorted off key. Cleaning the ribbon cable connector is a myth. What you accomplish is to temporarily disrupt the short circuit occurring near the slot in the touch panel. With time the short circuit grows back. It happens more often when the humidity is high. So here is my solution to the F7 problem. The most important step is first turn off the power to the oven at your circuit breaker panel. You will need to open the touch panel. There are typically three small screws on the bottom edge of the touch panel. It is advisable to have an assistant to hold up the panel while you work on it. Pull the panel outward at the bottom to gain access. There are many wires attached to the panel. Do not allow the panel to dangle by the wires. When the panel is open, you will see a flat ribbon cable connecting the ERC to the touch panel. See photo # 1. The principle of the fix is to apply additional insulation in and around the ribbon cable at the slot where it exits the touch panel. There are three basic styles of touch panels. Here is how the fix is applied for each style. 1. Plastic touch panel with a two-segment ribbon cable. Apply a slip of paper or file card material between the two segments of ribbon cable in the area of the slot. Work the paper down as far as it will penetrate. Typically it will only go in about 1/8?. See photo # 2. 2. Metal touch panel with a two-segment ribbon cable. Apply the extra insulation as per style 1. In addition, apply extra insulation on both sides of the ribbon cable and the edges of the slot. See photos #3 & #4. 3. Metal touch panel with a one-segment ribbon cable. Apply the extra insulation on both sides of the ribbon cable and the edges of the slot. If your style is different from the above three styles, the fix will not work for your situation. Don?t be concerned about using paper for the insulation. It will not get hot enough to burn. You will probably find a set of instructions printed on paper in the top of the oven when you open the touch panel. If the fix doesn?t work for your situation, you will need to replace either the touch panel or the ERC. Here is how to determine which one is faulty. 1. Turn the power off. 2. Remove the ribbon cable connector from the ERC. 3. Turn the power back on. If the F7 does not appear after a few minutes, the problem is in the touch panel and it must be replaced. If the F7 returns after a few minutes, the problem is with the ERC and it must be replaced or repaired. Check www.cgiltd.com for information regarding repairing ERCs. Good Luck. May the ?fix? be with you.
on Dec 26, 2009 | Ovens
A 2 word saying about pain or the word pain in it
Drilled thumb. (3 hours in Casualty Christmas eve)
Take Pains
Royal Pain
at pains
A bother
Gammy leg
off color
in agony
is throbbing
Dec 30, 2016 | Cars & Trucks
Store costco opening time in quebec
Hours
M-F 10:00am - 8:30pm
Sat. 9:00am - 6:00pm
Sun. 10:00am - 5:00pm Christmas Eve
9:00am - 5:00pm
Christmas Day
Closed
Boxing Day
1:00pm - 6:00pm
New Year's Eve
9:00am - 5:00pm
Dec 17, 2016 | Office Equipment & Supplies
What do you think about merry christmas images for free?
There are many internet sites online that are providing information concerning christmas images for free totally free. These specially made for people who are want to reveal greetings on holiday eve. for more information please go to this site :
http://bestanimations.com/Holidays/Christmas/Christmas.html
Nov 30, 2016 | Cars & Trucks
How do I clear a carriage jam on my HP D7160 printer?
We suggest you first remove all of the ink cartridges from the HP D7160 printer, then attempt the carriage un-jamming instructions as provided by the others above. If the jam still cannot be cleared then either the flex driver cable has a problem or the service station (below carriage assembly) is blocking carriage travel.
For advanced HP D7160 printer diagnostics specific to your printer model, please refer to 'HP Diagnostics Tests' .pdf file at the following Inkjet411 support site link: http://inkjet411.com/?page_id=1813
Please note that all Costco USA (all stores), Costco Canada/Mexico/UK (most stores), Fry's Electronics USA (all stores), Best Buy Canada (13 stores) support this ink cartridge series. Our network of retailers stand behind the product and performance - guaranteed. For store locations and details on ink refill pricing:
Costco USA Ink Refill Service (465+ stores):http://www.costcoinkjetrefill.com
Costco Canada Ink Refill Service (59 stores):http://www.ca.costcoinkjetrefill.com
Costco Mexico Ink Refill Service (35 stores):http://es.costcoinkjetrefill.com/
Costco United Kingdom (7 stores):http://uk.costcoinkjetrefill.com/
Fry's Electronics Ink Refill Service (34 stores):http://www.frys.com/ads/page51
Best Buy Canada (13 stores):www.geeksquad.ca/inkrefill/
We also have ink refilling centers in many University stores across the USA & Canada, including:
Brigham Young University, Brigham Young University - Idaho, Cornell University, New York University, Queen's University, San Diego State University, University of Calgary, University of San Diego, University of Virginia and University of Wisconsin - Madison
Refill Store Map Locator:http://www.go2ris.com/
Just bring your ink cartridges into any of our authorized refill center locations. The in-store representatives (at either Photo/Electronics support center) are trained to refill over 300 different ink cartridge types from all the major manufacturers (i.e. HP, Epson, Canon, Lexmark and Dell) and can answer any additional questions you may have. It typically takes less than an hour to complete the refill from the time you drop the cartridges off. Our network of retailers stand behind the product and performance - guaranteed. All of our inks are Made in America and closely match original manufacturer's ink quality - we are sure you'll be satisfied with both color 'pop' and image longevity performance.
The RIS InkCenter - the power behind retail Inkjet Cartridge Refill Services: http://www.youtube.com/watch?v=e7tlmEexor8
Save Money. Save The Environment.
Customers who have questions regarding the use of refilled ink cartridges can visit http://www.inkjet411.com or contact us directly at INKJET411HELP@GMAIL.COM
Alternatively, if a refill center is not close to you and you need to purchase a new ink cartridge(s) and are trying to cut costs, we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating, come with a 1-year warranty and provide free shipping for all orders above $20 (available for US Residents only).
-Thank you
Oct 17, 2014 | HP Photosmart D7160 InkJet Printer
My officejet pro 8600 will not accept thick paper to print on
Use upper tray , not the main tray for thick paper, see for setting in upper tray.....
Oct 11, 2012 | HP Officejet Pro 8600 Plus E-all-in-on...
Water rushing out of ice maker last night (something was resting in bin). Removed that and now it it "churning - making a noise, but no ice is being made after 12 hours. I cannot find the manual....
Sorry to read about your problem, I hope this helps you out.
unplug and plug back in wait about 10 secs..see if that clears the issue
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Kenmore 72912 / 72914 / 72919 Bottom...
Only one light comes on while charging and it won't turn on! help-it's Christmas eve!!
if you have a warrenty on it then just go to the store that you bought it from and return for a new one, if you dont have a warrenty then nintendo may fix it but im sure for a hefty price! im sorry this isnt a solution for your christmas grief, im sorry!
Dec 25, 2009 | Nintendo DS Console
Lexus ES 300 will not start
sorry but it has been 10 months since Christmas call a local mechanic to assist you
Sep 24, 2017 | 1993 Buick Century
Miscellaneous Logo
51 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
