Question about Garden
I have a new snow blower, auger is locked up, everything else is ok, how do i fix?
  • Garden Master
  • 2,459 Answers
Is there something jamming it? Is there ice built up in it? If its new and something wrong it should be under warranty. Take it back but before you do check it over. If it sits in a cold area then ice could be a problem. Put it in a warm area for a few hours and see if that works.
Posted on Jan 06, 2017
I have a Toro two stage snow thrower that has an auger issue..left just spins as it want the right moves snow....how do I fix...the machine is 13 years old can't find any answers....help please.
The shaft has shier pins that break when an object gets caught in the auger. This prevents further damage. You will need to replace that pin. Make sure you stop the blower, unplug the spark plug before working on it. The pin holds the auger to the shaft. Turn the auger until you see the hole through the shaft and insert a new shier pin.
Dec 12, 2016 | Garden
The auger is no longer turning. How do I fix it?
Check for broken shear bolts first. Then, move on and check the auger belt. Finally, if all those are ok, check the gear housing on the auger drive shaft (right in front, between the two auger blades).
Feb 02, 2016 | Poulan Pro 24-Inch 208cc LCT Gas Powered...
Need a auger housing for a snapper le317
Hello! You may have already gotten your new auger housing, but here is a link for our site where a new auger housing is available! I checked to make sure that this was the correct part for your model!
Snapper AUGER HOUSING ASMY Part 7052968YP
Happy Snow Blowing!
Feb 21, 2015 | Garden
I have a Yamaha ys 626 snowblower - how do I fix a non moving auger?
Most snow blowers have a "shear pin", (or roll pin) that links the auger to the drive shaft. It is there in case you strike something hard with the auger. The shear pin will break and protect the auger, the engine, and the operator. The shear pin can be purchased anyplace that services snow blowers, and it can be replaced by the owner.
Jan 10, 2015 | Garden
Impellar will not turn
pull the belt cover off and check the belt if it is ok the key in the beltvpulleyb that drives the auger could be sheared
Mar 13, 2014 | Poulan Pro 24" 2Stage Snow Blower Electric...
Mtd yardmachine snow blower 305 cc auger wont turn
This is a fairly frequent problem that is easily fixed. What happened was the snowblower's auger was either overloaded or got jammed (ice, debris - something other than snow). Rather than twist, damage or break the auger itself, an inexpensive part called a "shear pin" is designed to fail. A shear pin employed between the auger sleeve and drive shaft that is inside the sleeve. You may have broken one if one side of the auger spins) or both (if both sides of the auger spins). Purchase several replacements for your particular machine to have on hand. Do NOT replace s shear pin (or shear bolt) with a regular bolt under any circumstances! Check the video linked below on how to replace the shear pins. Good luck!
Feb 09, 2014 | Yard Machines 28" Two-Stage Snowthrower
Accidently hit stick in side yard. now wont throw snow. Everything else seems good
blower might still work but gear case that runs auger is shot or you sheared the shear pins in auger
Dec 17, 2013 | Yard Machines 31AS63EE700 208cc Gas 24-in...
Snow blower auger stops in snow
There are cotter pins on the second stage blower shaft. I would inspect these. Also, check sheer pins in front auger assembly.
Dec 03, 2013 | Garden
My yardmachine snow blower 8hp auger won't turn. I replaced the cable and belt but it still won't turn. What else could be wrong?
Check the auger shear pins replace if necessary with correct parts(not regular bolts).
If auger and the impeller are not turning your cable is out of adjustment.
If only the auger doesn't turn, and the shear pins are ok then the brass/bronze gear has shredded which is why proper shear pins must be used. Donyboy73 on youtube show how to replace that gear on an older but similar MTD affiliated blower.
Feb 16, 2013 | Yard Machines 24" 208cc Two Stage Snow...
TRS21 cloggs in the chute
I have the exact same problem. Also it won't clog so easily if the snow is deeper because the auger moves more snow through (or if I run with it.) It seems to me that the auger should be as close as possible to the scraper bar without causing any friction. Do you think that distance adjustable, or would new paddles on the auger close the gap sufficiently?
Dec 26, 2012 | John Deere Trs21 Rubber Auger Paddle Set...
Garden Logo
82 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
