My devices laptop and ipad have been hacked. I need help in changing ipad and lap top. Do I need to change both?
    Top Expert:
  • Computers & ... Master
  • 24,770 Answers
Just change your passwords and if too bad use the cloud to restore your iPad to the last good backup.
Posted on Dec 19, 2016
How do I clean and protect my IPad and windows phone from hackers?
You need to set up encryption on your devices using strong passwords (passwords that combine numbers, letters, and symbols). This will instantly prevent further hacking. The exact procedure for each device you listed is different. After doing that you should install a spyware scanner to remove anything that may have been installed on your devices.
I hope this helps,
Oct 29, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Cioecud ipad
Install iTunes on your Windows computer.
It will not only provide access to the device but, will also allow you to perform all sorts of fancy 'tricks' with your iPad.
For example: you can run your PC remotely from an iPad, from across the living room, or halfway around the world using Teamviewer on the iPad.
May 23, 2014 | Huawei Computers & Internet
My IPad has been hacked into I need to. Know how to change my password.
With the push of a button and pull of a slider, you can quickly access all of your iPad's contents, including any sensitive personal data that you've stored within it.
Such easy and unrestricted accessibility to your device could be dangerous in the hands of a stranger, which is why you enable a password to block its use by anyone but you.
If you believe that your password's confidentiality has been compromised, don't fret. You can change it using your iPad's Passcode Lock feature.
Tap "Settings" on the home screen.
Tap "General" on the left sidebar.
Tap "Passcode Lock" on the main pane to the right.
Type your current four-digit passcode in the "Enter Passcode" screen that appears.
Tap "Change Passcode." Type your current four-digit passcode again in the first "Change Passcode" screen that appears.
Enter a new four-digit passcode in the second "Change Passcode" screen.
Retype your new four-digit passcode in the third "Change Passcode" screen.
This will simultaneously verify and activate your new passcode.
iOS: Using passcodes
iOS: Forgotten passcode or device disabled after entering wrong passcode
Jan 13, 2014 | Computers & Internet
I canot send e mail from my Ipad, this just happened recently
Try deleting and recreating your email profile in settings.
Nov 29, 2012 | Tablets & eReaders
When I push the power button to power the lap top up the light display that says outlet power changes from green to amber and the laptop will not power up.
try removing the battery and just use plug power only if it boots normally then change the battery and the change the power supply unit as well I would just start with the power supply unit first then see if the battery charges up if not the battery is bad replace it. Now if the computer will not start with the battery removed then you have a power supply issue.
Change and replace it. Hope this helps. Also when computer lap top get hot they will shut down to protect the computer wait and let it cool down then try to restart your computer. If this does work and the lap top restarts normally get a fan cooler that is USB powered and the lap top sits on top of it. Also make sure the fan is running and is not stopped. Clean and dust it out once in awhile. I hope this assists you with your problem. John
Jan 22, 2011 | Toshiba Satellite Pro 6100 Notebook
I have a Linksys WRT54G, I can connect my wireless lap top, however can not connect wifi IPAD. My IPAD wks at neighbors and public places...just not at home. Changed to Ch 11, WPA PERSONAL...any other...
I have that router and it is fairly simple to use. Make sure it is set to broadcast the SSID. Unplugging and restarting may help too. Make sure the router is using wireless "G" and not "B".
Dec 22, 2010 | Linksys Wireless-G WRT54G Router
Out of range
Out off range means the resolution coming out of your laptop is too high. Remember it's the res. of your second monitor you'll want to change. I'm thinking it'll be 1024x768 max, but may even by lower. Hope this helps.
Jan 22, 2008 | Bush WS6671 28" TV
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
