Cd error.LG washer dryer combo. What is the duration of this cycle ,because this cycle doesnt stop n keeps going on ...
  • Arnoze Dharwar
    Arnoze Dharwar Dec 19, 2016
    And what is the duration of the normal dry cycle
  • 210 Answers
SOURCE: "CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Posted on Jun 03, 2008
  • 1294 Answers
SOURCE: keeps going on test cycle
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
Posted on Mar 08, 2009
  • 44 Answers
SOURCE: AEG Lavamat Turbo 12830 - error code E20
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
Posted on Mar 21, 2009
  • 6784 Answers
SOURCE: washer giving F2 error during wash cycle, cycle doesnt finish
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Posted on Oct 26, 2009
SOURCE: LG Senseclean washer dryer combo won't dry
The problem is likely due to lint build up in the condensing unit. I found a solution here:
I also had a softball size ball of wet, packed lint in the condensing unit. I found that the unit can be cleaned without tools or dis-assembly by:
  1. draining the water.
  2. laying the washer on it's back.
  3. removing the hose clamp on the rubber bellows that connects the drum to the condensing unit (right hand side of machine).
  4. digging the lint wads out with your fingers and a small screwdriver.
Happy drying!
Posted on Feb 01, 2010
How do I replace the fuse in the dryer for stackable Kenmore model 417.98702891
This is an excellent source. Click on the link
Jan 18, 2015 | Kenmore Washing Machines
Ariston combo ( washer + dryer)
Hi there the controller board is faulty replace main controller board.
Thanks J
Feb 05, 2008 | Ariston Technologies AWD120 13 lb. Washer...
LG Washer/Dryer Combo not spinning
If you can make the motor spin a few revolution by manual intervention, then the issue is most likely a faulty motor 'start' capacitor which is located near the motor: this replacement involves a dangerous MAIN AC VOLTAGE device and I would advice getting a qualified technician to check/repair your dryer.
Hope it helps.
Apr 06, 2014 | LG WM-2277HW Front Load Washer
How do i do drying only
From the document I see, it is only a matter of pressing the "Dry" button. This is from the manual, available at and selecting the "Support" tab. On the right, there will be a "Washer/Dryer Combos Manual" link, which will download to your computer. Listed under "Dry" in Section 9 is the following.
• Drying options are easily selected with the Dry button. • For most even drying , make sure all articles in the clothes load are similar in material and thickness. • Do not overload dryer by stuffing too many articles into drum. Items must be able to tumble freely • If you open door and remove load before dryer has finished its cycle, remember to press the Start/Pause button. • By pressing the Dry button, you can select "Normal" - "More" - "Time" - "Off" - "Low Temp" - "Less" • Your dryer can handle a load of up to 9 lbs. (4 kg) dry weight of articles. • When drying cycle is completed, [Cd] (Cool Down) is displayed on the Multi display. • Cool Down is set automatically when the drying cycle is complete. • If clothes are not removed promptly when the drying cycle ends, wrinkles can form. • The Cool Down feature periodically tumbles, rearranges and fluffs the load to avoid wrinkles for up to 4 hours. • The message [Cd] will continue to display until the clothes are removed or the Start/Pause button is pressed
Hope this solves your problem. I highly recommend downloading the users manual, it is a wealth of information and will prove useful in many circumstances.
Please rate and comment Thank You Joe
Sep 06, 2011 | LG WM3431 Front Load Washer / Dryer
WM3677HW - no rinse cycle (not rinsing)
Possible door switch not closing or opening.
Jul 30, 2009 | Washing Machines
LG WD-324RHD stops at 6 minutes left in drying
Your timer has gone bad and you need to replace the time. Best bet is to get a Technician out there but you can do it yoursel. It is behind the face plate where it counts down the time
Feb 09, 2009 | LG WD-3243RHD Front Load Washer / Dryer
LG Sense Clean DD error code "FE" front loader washer/dryer combo
my lg senseclean wash mashine shows the sign Cl on the display and the door cannot be open what does it mean?
Jan 03, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
AI got here after googling the same problem.
There are many reports of this "dHE" error - all with BRAND NEW MACHINES !
I rang LG in Sydney, Australia today and amazingly the girl on the phone said there are no known issues with this dryer
(In Australia the combo dryer is known as WD14700RD ) - 7kg washer / 4kg dryer.
Mine has same problem. Whenever the dryer is selected in the program, it stops after the wash phase and flashed dHE (or dHe, can't remember) and thats as far as it gets.
Its a tech, call out tomorrow to try & fix it.
Very poor LG, these are brand new machines, many reports of this problem from googling it but LG have no knowledge a problem.
This may end up being a recall or at the very least, some public announcement of this dHe problem with this washer.
New buyers beware ... It is a fault with brand new machines.
Melbourne Aust.
Sep 23, 2007 | LG WD-12126RD Front Load Washer / Dryer
Sgt 48
Sep 01, 2007 | LG WM-3677HW Front Load Washer / Dryer
Washing Machines Logo
Top Washing Machines Experts
