Question about Shark Vacuums
I have a shark life away and I have used the cleaning tool and now it's stuck in the tube and won't budge ??
Y Shark "Professional" model 540 26 is making a terribly loud noise and not picking up dirt. t also gets HOT
Check( 'beater bar',suction tube to canister) for accumulation of hair,carpet fiber,pet hair,etc....cut hair,etc,with scissors,clean...might also be hair stuck in belt that drives beater bar
May 08, 2017 | Shark Vacuums
How do I clean the brush and surrounding area?
Hello, this is Ava with Think Crucial.
When you are cleaning your brush, you can use scissors or a knife to cut the hair that are stuck. You may need to use your fingers to pull out the hair off and away the roller brush. You may also want to clean the bearings of the brush. Remove any hair or visible debris hat is stuck under the cup by pulling the hairs or brushing them off. Wipe with wet towel or tissue the housing of the brush if you see any dust or debris. Once you clean your brush and it's surrounding, you can put it back. Make sure that the belt is still fairly tight as it should be for optimal use by pulling the belt slightly.
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=nv350
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Oct 19, 2016 | Shark Vacuums
Shark navigator lift away blowing hot air out of the filter
You would need to clean the tubes and every hose from any clogged particles or blockage and it will fix the problem. You can also check this video tutorial on how you can fix the issue by clicking the video link below:
http://www.thinkcrucial.com/search?type=product&q=shark
Ava B.
Oct 08, 2016 | Shark Nv352 Navigator Lift-away Complete...
Shark navigator nv 352 blowing hot air out of the filter
Ava B.
I need a DIY solution because my shark navigator lift away beater bar attachment stops working intermittently
If you've gotten 4 years out of a Shark you've already beat the system. Give yourself a pat on the back, throw it in the nearest dumpster, then go to your local vac shop and purchase a quality USA made vacuum cleaner that is repairable and will likely last 20-30 years. Chinese vacs are designed to last one year and parts are not made for Sharks.
Jan 07, 2015 | Shark Navigator Lift-Away Upright Vacuum
Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
Oct 21, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steamer not working at all. water tank / electrical outlet all check ok/plugged in and not doing anything
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Oct 24, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop
I had the same prob and found this site off google looking for the solution.
I went back to my shark and took out all the screws, some don't feel like they were coming out but it came apart. Take a pair of pliers and release the spring clip holding the hose to the heat nozzle. Then pull off the hose. Then take a paper clip, unkink it so it's sort of straight with a curve to go into the hole . Shove it in and out to clean out the hole. I got my fingers blasted with residual steam so you should let it cool first. But I think the steam bursting out helped clean out the hole. Don't throw it away till after you try that..It worked great after that. All the best, Satch
Oct 09, 2008 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vacuums Logo
23 people viewed this question
Top Shark Vacuums Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
