Question about Miscellaneous
What is -18 C in farenheit ? - Miscellaneous
  • 4,134 Answers
The formula is
F = 1.8C + 32
thus
-18 x 1.8 = -32.4 + 32 = - 0.4F
Posted on Dec 19, 2016
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Miscellaneous Master
  • 102,366 Answers
-0.4 degrees F.
How do I change my luxpro psd111 thermostat to display temperature back to farenheit from Celsius?
On the Luxpro PSD111, Farenheit or Celcius are selected using the Jumper Switch J2 on the rear of the unit's circuit board:
Open = Celcius
Closed = Farenheit
Jan 20, 2014 | Cars & Trucks
Tip
Changing brake fluid
ATE currently produces and markets two DOT4 brake fluids with the identical specifications: * Dry boiling point of 536 degrees Farenheit which is 122 degrees Farenheit above DOT4 Specifications, which is Super Racing Blue * Wet boiling point of 392 degrees Farenheit which is 113 degrees Farenheit above DOT4 Specifications, which is Original Brake Fluid TVP 200. Other than packaging, the primary difference between the two is color. The Blue is blue in color and the 200 is clear or light amber in color. This facilitates flushing and changing fluid such that if used alternately, the flusher will know that the job is done correctly when the color change is complete.
on May 19, 2008 | 2007 BMW 760Li Sedan
Engine temp sensor bypass or test
WHAT SIZE ENGINE???? ? 4L 2.5L????
ive seen this post many times now.and can not figure it out.
double posted.
what are you trying to do, say that first. or just ask a question
first off,what does bypass mean???? <<very confusing to me...????
This is THE ECT, the ENGINE. Coolant Temperature" sensor.
what do you wish to do with this very critical EFI sensor.???????
just test it.>
Ill guess, you have not read the FSM , as it covers that 2 ways.
the ECT can be tested 3 ways.
ill show 2
1: on car and off car.
1: on car. (is more easy. if strong back)
DMM set to RESISTANCE , aka. ohms. ohmega symbol
the DMM meter is $20 at walfart.
cold car, say at about 50f.
you unplug the ECT connector (2 pin conn)
cold engine it might read, 5000 ohm, this is good,
get engine fully hot. i use a IR pyro gun, it hit 180F or more.
and kill engine.
pull back off the ECT sensor. conn.
and it reads (2 pins 2 meter leads) about 300 ohms.
is this what you want.
first google hit on sensor , but FSM shows truth....
1st hit shows....... its a NTC thermistor with these rules.
212 farenheit 185 ohms
160 farenheit 450 ohms
100 farenheit 1600 ohms
70 farenheit 3400 ohms
40 farenheit 7500 ohms
20 farenheit 13,500 ohms
0 farenheit 25,000 ohms
-40 farenheit 100,700 ohms
the FSM is here
the 93 will be close.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
click fuse system there.
click on pdf page number. 46/66 BINGO ECT TESTS>
off car tests are easy, in a pan of room temp water then hot the in
ice water.
i do 3 tests. 32F(ice) 79F (room) and 200F (near boiling)
super easy test. ask how. if any step seems confusing.
Jan 04, 2014 | 1991 Jeep Cherokee Limited
What is 20 celsius in farenheit
Hi jujaramirez,
Have a nice day.
Here is the formula to compute farenheit to celsius and celsius to fahrenheit:
C is Celsius
F is Farenheit C = 5/9 (F-32
F = 9/5 (C+32
Let's try converting 68 degrees Farenheit to celsius 5/9(68-32)
Step 1: 68 less 32 is 36
Step 2: 5 divided by 9 is 0.5555555555555
Step 3: multiply the repeating decimal by 36
Step 4: your solution is 20
Now, convert 20 degrees Celsius to Farenheit to check your work.
9/5C +32
Step 1: 9 divided by 5 is 1.8
Step 2: 1.8 multiplied by 20 is 36
Step 3: 36 plus 32 = 68
Hope it answers your problem.
Thank you for using fixya.
Adieh
Sep 13, 2011 | Health & Beauty
Im not know what a convertion in fahrenheit
C is Celsius
F = 9/5 (C+32
9/5C +32
Jun 15, 2011 | Super Tutor Pre Algebra (ESDPALG)
How do i switch from farenheit to celcius? thanks
Take your temp in Farenheit and subtract 32. Then take your answer and multiply by 9/5 or 1.8 and that gives you your answer. (farenheit -32) x 1.8 = Celcius
Mar 30, 2011 | Health & Beauty
Convert temp control from celcius to farenheit
This sounds like a Jacuzzi. This is hard to describe. In the control box, on the circuit board, in the upper right corner there is a small bunch of pins in 2 rows 5 or 6 in length. one set of pins have a black jumper on them, remove the jumper and temp should go to farenheit. Turn off power to spa before doing this.
Mar 28, 2009 | Home
MY OVEN WILL NOT GET UP TO THE TEMPERATURE THAT IT IS SET. iT WILL ONLY GET TO 220 DEGREES.
are you sure it's only reaching 220 degrees Farenheit? Many stoves can be set to display either in Farenheit or Celsius. You didn't post a model # but if you look in your use and care guide you can change it back to Farenheit scale Hope this helps
Dec 10, 2008 | Magic Chef CER3725AA Electric Kitchen...
Celsius to Farenheit issue
Maybe we can trade ovens!! Mine is in Farenheit and I'm trying to figure out how to put it back in Celsius!!
Armen
Montreal, QC, Canada
Dec 04, 2007 | Kenmore 95822 / 95824 / 95829 Electric...
GE profile fridge
Are numbers being displayed at all? If you want to confirm whether they are wrong or not, try putting a thermometer inside the fridge for about 10 minutes and check it against the temperature displayed. If it's wrong then it's probably the temperature sensor and would need to be replaced.
I suppose it's a long shot but could it be displaying 18 and feels more like 65? (Celcius vs. Farenheit)
Nov 08, 2007 | GE (JASHO96273)
Miscellaneous Logo
20 people viewed this question
Top Miscellaneous Experts
ray012965
lugnuts1
ajschmitz6
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
