What size power cord? - Office Equipment & Supplies
  • kakima Dec 19, 2016
    Hi Nik Kritsotakis, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    For what?
What power cord do I need for an unidentified generator?
Hi Gail:
The size of a power cord is determined by two factors:
1) the Amperage being delivered, and
2) the Distance that the current is being carried.
Extreme examples could be:
- A diesel generator supplying a small community on a remote island. or
- A tiny generator connnected to a recreational vehicle.
If you can describe what you are trying to accomplish, we'll try to give a specific answer.
Meanwhile:
- small appliance, short distance, small cord.
- Bigger appliance, bigger cord.
- Longer distance, bigger cord.
- Tripping circuit breaker, bigger cord.
- Warm/hot cord, bigger cord.
Cheers.
Dec 01, 2015 | Electrical Supplies
Can you buy the power cord for the gemmy santa clause
Any the adapter plug is identical to a rechargeable drill and the volts for it are 9V hope his helps
Jun 17, 2014 | Gemmy Life-Sized Animated Santa
I need a power chord for a westinghouse 27" television
Hello
For the United States and Canada
In the United States and Canada the male plug is a NEMA5-15 style UL Listed, and CSA
Labeled. For LCD TVs that are placed on a desk or table, type SVT or SJT cord sets may be used. For LCD
TVs placed directly on the floor, only SJT type cord sets may be used. The cord set must be selected
according to the current rating for the LCD TV. Please consult the table below for the selection criteria for
power cords used in the United States and Canada
If the cord size is SJT take 14AWG _ 12Amps
If the cord size is SVT take 17AWG _ 12Amps.
The specific power cord for this LCD TV is enclosed and has been selected according to the country of
destination and must be used to prevent electric shock
Check the socket confuguration of your wall socket and select proper pluged cord.
OK.
Jul 02, 2011 | Westinghouse LTV-27w7 7 in. LCD HDTV
HAVE A TRANSFER SWITCH IN MY HOME TO PLUG A PORTABLE GENERATOR TO. PROBLEM IS WORKED GREAT BUT WAS ON OTHER SIDE OF HOUSE. I HAD A 4' CORD BUT BOUGHT A 80' CORD TO PLUG INTO THE TRANSFER SWITCH NOW WHEN...
Hello, what you are not telling us is the size of the wires in the 4' cord and the 80' cord. However, you are correct in your thinking that the longer cord is cutting back on the available power that you have. Yes, if you extend the length, then the wire size in the cord has to be increased as well. To give you a size we will need to know the generator size. Having said that, an 80' cord is going to be a BIG amount of money. You might want to tell yourself how much money you are saving pulling the generator around. If you have to use the generator a lot, you might consider installing a cable to run the generator with.
joe
Feb 22, 2011 | Honda Electrical Supplies
We used a differed sized power cord and it stopped working is it fixable?
It wouldn't hurt anything to try to use the original power cord. Its possible that the other cord just wasnt making a good contact.
Jan 03, 2011 | Homedics SS-4000 Clock Radio
I need a power cord. Do I have to have a specific
Usually you can use any power cord just be sure it is the same size as the other one you had.
Nov 06, 2009 | Audiovox BA200 Car Subwoofer
I do not have a power cord, can I buy one?
yes... The NEC Plasma TV uses a "standard" PC power cable.
Any computer store (BestBuy) will have one.
Standard size is 6' ... you should get at least an 8' power cord.
Less than $10...
If you have a desktop computer (or parts) try that power cord.
Hope this helps!
Sep 03, 2009 | NEC PlasmaSync PX-42VM2A Television
Any luck? I need the power supply cord too.
hello there:
If you have a thrift store or a goodwill store around your area they are a great place to get power supply cords and speakers and keyboards and power cords for these items ok:
please dont forget to give my solution a rating this really helps me out so i can help you out ok ?
best regards michael
Aug 19, 2009 | Harman Kardon HK595 Computer Speakers
IBM Personal Wheelwriter 2
The cord you wrote about will work with no problem.
DickyO
Sep 11, 2008 | IBM Wheelwriter 30 Typewriter
21 people viewed this question
k24674
jasbo
jasbo
