Question about Winter Sports
2000 skidoo 120 mini z rear light keeps burning out. Where do I start looking for the problem. If they didn't cost so much I would buy a bunch to diagnose problem but down to last one.
4 Suggested Answers
  • 269 Answers
SOURCE: 2000 FLHTCI burning out the ECU relay
Remove your ECU relay and your ECM fuse. Do not do anything else before you do this! Verify that all your battery connections are tight and clean, next any grounds for lamps, etc. make sure they are tight too. Replace relay and then fuse. Carry an extra relay with you and see how it goes. A loose or bad ground can cause a voltage spike which kills relays, fuses, and other parts. good luck.
Posted on Aug 14, 2009
  • 22306 Answers
SOURCE: I want to buy a used car that cost around
a simple car that has no fancy electronics ,now i would suggest a peugeot 206 ,nice car petrol or diesel but diesel manual preferably ,citreon C5 diesel manual these cars run forever with regular oil change ,Ford focus with the endura diesel turbo ,great motor runs forever and its a ford so parts might be easier in your time zone ,nissan diesel is good but parts are mainly dealer only ? which can be expensive ,same goes for mazda although a lot of parts on a mazda are ford ,although my grandmother always made me promise not to buy japanese as my uncle was on the burma railway ..But i do think the ford is the best bet but dont overlook VW ,they are good cars as well a nice golf diesel very reliable ,keep away from big luxury cars like old jags or mercs nice when running till they go wrong ,same goes for detroit steel as well ,keep away from big gas guzzlers with a high CO2 output because i think that the american goverment will catch a cold soon with their pledge to cut greenhouse gases as i thnk other countries will start to place embargos against it soon unless they are reduced ,Also with the recent oil spill in the golf i do think the goverment will up the price of fuel to europeon prices before long to force these gas guzzlers off the road so get the emmisions down within the limits set by the toyoto convention .So think about the small diesel car and dont dismiss it .Price of petrol here is about 1.20 euros a litre so as an american galoon is about 4.2 litres as i remember imagine paying 5 dollars a gallon then go ahead with buying that V8 cheroke jeep with a auto box then compare it with a small diesel engined car turning out over 50 mpg
Posted on Jul 24, 2010
  • 397 Answers
SOURCE: 1995 Chev Astro Mini Va
If the window goes up and down when the motor is still good, chances are your wiring is not at fault. Check the window regulator for binding or stiffness. It may be all that is required is to lubricate the regulator.
Posted on Jun 23, 2011
How do I replace the fuel pump on 1998 skidoo formula 500 snowmobile?
Buy the manual and this will show you how it is done. Given the amount of money you will be saving by doing the job yourself, this is a small cost.
May 02, 2016 | Cars & Trucks
Oil light comes on and then car overheats
i just had changed the oil in my wifes 2.7 2000 260,000 mile concord.
i got a very unhappy phone call about oil light on and over heating .
shop wanted $750 to fix . i drove it home no light till about 15 minutes into drive. checked oil it didn't even regester .waited a few minutes oil was back. ended up being the pcv valve was pluged and line to it had
rotted off . it was holding the oil in the valve cover and causing it to leak
around plugs and burn oil . cost of fix $20. i used a radiator bypass hose and a new pcv valve . works great .still burns quart of oil every 1,000 miles because of milage .i hope this info will be useful to you.
Jul 05, 2012 | 2000 Chrysler Concorde
I have an mini max nt w 6800 controls ignitor
The voltage to this ignitor should only be 120 volts. If you are getting 240 volts to the ignitor, there is something really wrong with the wiring to the heater or in the heater.
Jul 27, 2011 | Pentair Minimax NT Heater
Replacing rear brake light
From inside the trunk, behind the carpet that covers the back of the taillight. You will need to remove the retaining nuts.
The tail light assembly is attached to the Trunk Lid itself. You must use a deep socket and remove 7 nuts.. 3 from each side and one in the center. The entire back end assembly will come free. All bulbs are the same P161-1a (P161 1 AMP) they are the size of your small finger nail and not easy to find. Try to buy 2-3 before you start the job. I thought I had 1 bulb burned out, but it ended up being 3. Give the bulb sockets an 1/8 turn clockwise to release it, then pull the bulb straight out. Reverse the order for assembly. They look like little flash bulbs from the old 120 flim cameras.
Hope helped (remember comment and rated this).
Apr 10, 2010 | 2002 Buick LeSabre
2000 Jeep Cherokee #7 10 amp fuse
You will have to check the positive wire of the wires that go to the parking and side marker lights for a short to ground.Check the easy things first like the bulbs for these lights.It could just be a shorted bulb.You can remove one at a time and see when the fuse stops blowing.You an get a short finder from a part store and save the trouble of getting a bunch of fuses.Hope this helps.Good luck.
Mar 15, 2010 | 2000 Jeep Cherokee
How do i find a usb adapter for my maxtor one touch 4 mini 120gb it broke?
You can buy a USB to USB mini cable at almost any store with PC accessories, even Walmart. Buy a high quality one since the drive is powered from the USB 2.0 port. Good Luck
Jul 23, 2009 | Seagate Maxtor OneTouch 4 Mini 120GB...
Repair costs for 200 dodge stratus
Hi,the battery will be installed free if you buy it at a good auto parts ,if not around twenty dls, head light about twenty or thirty dls , bumper, if is not going to be painted , around forty to seventy dls, Ihope this will help ....
Aug 23, 2008 | 2000 Dodge Stratus
Copy a dvd
yeah i do it all the time... get a program called Alcohol 120% and Nero. Nero will bypass the copyright and Alcohol 120% will burn it onto a disc. it does most of this for you, just put the disc into the drive and choose Alcohol 120% to run the disc as. the only thing is that i think you have to buy the alcohol 120...... but i dont think its much
Jun 16, 2008 | Computers & Internet
Convergence IC's
Buy the STK392-120 they are a better chip. Some people say go up to the STK392-150 but i had an issue trying that with a panasonic it keep burning resistors as fast as I could change went back down to a STK392-120 and worked great.
Jun 03, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Winter Sports Logo
107 people viewed this question
Top Winter Sports Experts
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
