Question about Kitchen Ranges
My oven is electric so not igniter model number 9503keb
3 Suggested Answers
  • 3640 Answers
SOURCE: Gas stove with electric ignition (oven stopped working)
the electric ignition is bad and needs replaced in oven. I had the same problem a few months ago and it was the ignitor for the oven. if replacing it yourself, be very careful with ignitor, it is very fragil. do not touch ignitor itself, hold on to it by the base of it. they are not that hard to change.
Posted on Jan 31, 2010
Testimonial: "Thank you!! "
Crew Dawg
  • 275 Answers
SOURCE: I have a Hotpoint gas
Most gas ranges with electronic ignition aren't equipped to have a straight pilot ignition.
I'm don't even think they make conversion kit because of the routing of the gas tubing for the pilot source.
Usually you have to turn the gas knob way over to get the "click-click-click" of the igniter.
Its just as easy to turn on the gas and light with a match...or a long butane lighter.
Even a "striker" used in welding will provide a source of ignition.
A last ditch effort would be to get a replacement gas grill igniter...all ya gotta do is place the bottom of igniter on metal surface and press red button. (kinda works like a spark plug) and no A/C needed.
Hope this helps some.
Posted on Jul 18, 2011
Oven sporadically ignites
First and foremost, you or the web administrator have listed this question under a section for an electric oven. So there is nothing that should "ignite" within it. If you are trying to say it does not heat, then please do so, but please give additional info as to what selections are made for use.
If you actually have a gas oven then the problem is most likely caused by a faulty bake igniter if your oven uses one. (another reason to post a correct model number with question).
Jul 27, 2014 | Thermador SC302T Electric Double Oven
Eurolec oven will ignite but not remain on
Depending on the exact model number and features of your Eurolec oven, this could indicate a number of things:
  • no supply of gas (for gas model), or the electrical power is not reaching the heating elements;
  • the heating elements are defective;
  • the controlling system/mechanism is faulty;
  • there is an "unknown" fault internally and the system is not allowing any further action to prevent untoward incidents or aggravate the condition;
  • if it is completely electric powered, try to see if there is a reset button at the back/rear of the unit.
Hope this be of initial help/idea. Pls post back on the exact model number, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 23, 2008 | Kitchen Ranges
HOW DO I LIGHT OVEN PILOT?
Hi and welcome to FixYa, I am Kelly
Your model number was missing digits so I used this manual:
GRP17WEWWW
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=981380002.PDF
and if your unit is older this one:
http://genet.geappliances.com/DocSearch/Dispatcher?REQUEST=ShowPDF&FileName=49-8514.PDF
Automatic Ignition
The oven burner is lighted by electric ignition. To light the burner, press the pad for the desired electrical function and press the INCREASE or DECREASE pad until the desired temperature is displayed. The burner should ignite within 60 seconds. After the oven reaches the selected temperature, the oven burner cycles off completely, then on with a full flame to keep the oven temperature controlled.
GE contact data:
If you don't understand something or need more help, call:
GE Answer Center®
800.626.2000
24 hours a day, 7 days a week
Both the new and OLD units use a glow bar for lighting the burner. Most likely your Glow Bar has failed: GE PN: WB2X9154
The Glow Bar is item 316 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=214914&diagram_id=20725728#d20725728
If you net search the WB ge part number you can save lots of money!!!!
http://www.amazon.com/WB2X9154-Gas-Range-Oven-Igniter/dp/B004H3XQPM
If the glow bar is glowing and you still do not get ignition respond here and we can go through troubleshooting.
Thanks for choosing FixYa,
Kelly
Apr 23, 2011 | GE JGRP17 Gas Single Oven
I am purchasing a home with a kenmore elite gas range model # 790.3670--the seller doesn't seem to know if the oven is electric or gas. What is standard?
Electric or gas would be standard. If this is a stove like in the picture you provided, and is gas on top ... it is probably gas inside. You could always look to see if it has a burner or a calrod. See if there is a setting for Pilot or Igniter. Electric ovens don't need a pilot nor an igiter.
Of course, you could turn it on ... or pull it away from the wall to see what the connection is ... gas pipe or, if electric is involved, a very heavy electric cord - probably 50 amp 220 volts. If it has a small cord plugged into a standard wall outlet ... definitely gas fired. You say the top is gas so there will be a flex pipe for the gas ...
I searched Sears - they claim there is no such model.
Your agent should be able to tell by looking.
Mar 24, 2010 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
The oven pilot is out. The ignitor still works and the burners on the top of the stove still work. Tried to maually light pilot with match from the back of the broiler and it doesnt light
MOST modern appliances that use gas ignition (including dryers) no longer use a pilot. These appliances are equipped with a burner assembly with an electric igniter. The model number you have this question listed under is configured this way. The following link explains igniters and how to access the them on a gas range:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
If you are having ignition problems with one of the oven manifolds (bake or broil), it may be a simple matter of a weak or bad igniter. Just because an igniter glows, does not mean it is good. If the igniter is weak, the gas safety valve will not open and gas will not flow. So...attempting to light with a match will not work. If BOTH manifolds are experiencing the same problem, you may have a bad regulator or electronic oven control (EOC) board. The EOC controls all your oven features.
The surface burners use an electrode type igniter for ignition. There is one mounted next to each surface burner assembly. They get their electric source from a spark module. If none of the surface igniters are working, you may have a bad spark module. If one single burner is not igniting, the problem is probably the electrode.
If you require additional assistance, please let me know. If your model number is different form the one listed, please post back with your correct information so that I may assist you better. The model number should be located on a name plate around the oven door, or lower drawer opening. Some manufacturers place the model number on the back of the operator console.
If you have any questions, please let me know. I hope this is helpful to you.
Nov 10, 2009 | Tappan TGF320 Gas Kitchen Range
How do i light the pilot for the oven
MOST modern appliances that use gas ignition (including dryers) no longer use a pilot. These appliances are now equipped with a burner assembly with an electric igniter. The following link explains igniters and how to access the them on a gas range:
If you are having ignition problems with one of the oven manifolds (bake or broil), it may be a simple matter of a weak or bad igniter. If BOTH manifolds are experiencing the same problem, you may have a bad regulator or electronic oven control (EOC) board. The EOC controls all your oven features.
If you require additional assistance, please post back with your model number so that I may assist you better. The model number should be located on a name plate around the oven door, or lower drawer opening. Some manufacturers place the model number on the back of the operator console.
Nov 08, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
How do we turn on the piolot, never had a gas stove before
If the model number you have this listed under is correct, there is no pilot light. In fact, MOST modern appliances that use gas ignition (including dryers) no longer use a pilot. These appliances are now equipped with a burner assembly with an electric igniter. The following link explains igniters and how to access the them on a gas range:
If the model number is not correct, please post back with the correct information so that I may assist you better. The model number should be located on a name plate around the oven door, or lower drawer opening. Some manufacturers place the model number on the back of the operator console.
Oct 19, 2009 | GE JGBP28 Gas Kitchen Range
I own a GE JGBP33BEH5BB and the oven doesn't get hot enough. I've changed the sensor with one from a JGBP30BEA1WH that was working fine when it was removed. (replacements for both are the same part number...
The orange glow is the igniter. Normally, the igniter turns on and begins to glow. As the igniter heats, the change in it's resistance causes it to use more electrical current (amperage). When the amperage level reaches a threshold (let's say 3.2 amps, for an example) the ovens safety gas valve will open because in knows the igniter (using that much electrical current) is hot enough to light the gas. This process usually takes under two minutes. The igniter stays on until the oven reaches the set temp, then it turns off, and the gas valve shuts off very soon after. Then the cycle repeats when the oven thermostat call for heat again after cooling down a bit.
The trouble is, as these igniters get old, they have a harder time reaching that needed amperage threshold to operate properly. You can just swap the broiler igniter with the bake igniter if you wish, as they are the same part number in your model, and the broil is generally used much less, and so should have much more life left. (of course now the broiler and the self clean will not work, until you replace the broiler igniter with a new one.) In rare cases, if you have low line voltage to the range (say 108 volts) that will also cause the same problem, or if you have a poor electrical connection, but those cases are rare, and about 99 percent of the time your problem will be fixed by replacing the oven igniter. (GE part number WB2X9154 for your model)
Sorry to get so long winded. Just replace the oven igniter.
Aug 15, 2009 | GE JGBP33 Gas Kitchen Range
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
The oven doesn't work ,the ignator doesn't light up. no gas coming
The technical jargon is,.....:
In order for your gas oven to work this is what has to happen: 1. when you turn on the oven, the range sends 120 volts to the glow bar igniter. 2. as the igniter heats up (and starts to glow) it starts using more electricity. 3. when the electric use reaches a set amount (say 3.2 amps) the range knows the glow bar igniter is hot enough to ignite the gas, so it then releases gas through the gas safety valve. 4. when the thermostat tells the oven controller that the temperature has been reached, the control cuts power to the igniter, cutting the amp draw down, causing the safety gas valve to close. 5. process repeats to hold oven temp until you turn off oven.
So,..........the solution is:
most likely your oven igniter burnt out. Find your model number, usually on the range frame just behind the lower drawer or broiler drawer (depending on if it is a self clean gas range or not) and order the correct igniter and replace it.
Nov 02, 2008 | Kitchen Ranges
Kitchen Ranges Logo
32 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
