Question about Roper Washing Machines
My Roper top loading washer will fill drain and rinse but will not wash
RJTech
  • 32 Answers
SOURCE: Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
Posted on Dec 18, 2007
SOURCE: ROPER RAS6233KQO T.L.W.-Won't fill/rinse with cold water
Most washers have a small screen at the water inlet valve. They can be accessed simply by revoving the hose from the back side of the washer, using a small screw driver you can carefully remove the screens and clean them out under a faucet.That may be all that is wrong.
Posted on Apr 12, 2008
SOURCE: Washer fills, drains, & final spin
I had the same problem and ended up replacing the control board which solved it.  Contact Westland Sales at 800-356-0766 ext. 5 for tech support.
Posted on Jun 02, 2008
vanni7
  • 163 Answers
SOURCE: Kenmore 22622100 Top Load Washer won't drain the water, nor rinse
HI!!! you seem to have a bad lid switch on your washer..I would also check the timer on it good lucck.
Posted on Feb 13, 2009
  • 109 Answers
SOURCE: I have a GE top load washer model G157. When I
timer is bad
Posted on Aug 23, 2009
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Where is the reset button on Roper washing machine top load water fills but nothing else happens
try to turn the timer dial to rinse and spin, and then see if the water will drain
Jul 07, 2011 | Roper RAS8445KQ Top Load Washer
Washer doesn't fill with water and begin wash cycle. I can hear it instantly draining out rather than fill, and has ran my well dry. We replaced the water pump a month ago, and it washed a few loads of...
Sounds like siphoning. This can happen if your drain pipe is too low and you run the drain hose right into it, or if there isn't any kind of air gap between the drain hose and pipe. Usually it shows up when trying to fill for the rinse cycle - it drains as fast as it fills. Or it might not fill at all. Order a "siphon break kit". They're cheap and easy to install
May 26, 2010 | Roper RAS6233KQ Top Load Washer
Washer does not drain and spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 20, 2010 | Roper RAX4232KQ Top Load Washer
I have a Roper washer. It filled with water to wash, but when it came to draining the water to rinse, it just stops. It will add water on rinse cycle, but it will not drain or spin.
Sounds like the lidswitch. As a safety, the tub will not spin if the door is up (open). In turn, it will not drain if it wont spin. This is a common problem with whirlpool washers. You can go to searspartsdirect.com to get the breakdown and order the part.
Feb 17, 2010 | Roper RTW4300SQ Top Load Washer
Washer will wash but will not advance after draining wash
Very likely a dead spot in the timer, but check the lid switch (bypass it is best) to make sure it in not working intermittently. Hope this helps!
Jan 29, 2009 | Roper RAS8445KQ Top Load Washer
Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
Oct 27, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
