Question about Boss Music
Replacement remote for Boss music system - Boss Music
Is there a hard reset for a boss Bv9562b? That I can do with out the remote
Contact Roland customer support for the correct procedure.
Apr 29, 2015 | Boss Music
Call Roland Customer Support and they'll tell you how.
Battery problem
DId you remove the plug from the input jack to turn the pedal off? If so then you may have a bad input jack.
Jul 03, 2013 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
Why is my vintage boss dd-3 very quiet on the repeats even when level is turned up full?
Assuming you have the feedback level turned up....can you hear any difference at all when adjusting the feedback?
Aug 17, 2012 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
Need replacment inputs for boss digital delay
the jacks are not diffiult to find nor to install, but don't buy cheap radio shack jacks, go to a good music store and buy jacks ( the price may be 3 to 5 dollars each). take the unit apart and take not of where the wires go, wirte it down/draw a diagram, note colors of wire and where they go. cut the wires loose and take the old jacks out, then solder in the wires where they belong, and you're good to go.
Mar 20, 2011 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
My Boss Digital delay pedal won't stay on unless I keep my foot on it.
This is likely a failing switch under the pedal. Either the toggling mechanism is broken in it or if it is a momentary type it probably has "contact bounce" that exceeds the what the de-bounce circuitry can handle.
Mar 08, 2011 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
How do plug your guitar into the boss rv3 which jacks
Plug your guitar into the input and a cord from one or both outputs to the inputs of whatever you are using. Meant to be run in stereo for best sound. Two guitar amps?
Sep 24, 2010 | BOSS AUDIO SYSTEMS Boss Rv 5 Digital...
Used Wrong trasformer. BossDD3 still in working order BUT the 9 volt battery drains of power within 15 min. Is it repairable. Regards, W.Gibb walsal15@bigpond.net.au
You likely fried the input filter capacitor... it is where the power comes in and on one of the schematics it is C51 which is a 100 MFD/16 volt electrolytic. Also a Zener labeled D6 MIGHT be gone... it is in parallel with that cap. Also the 78L05 May have been degraded, but this is a remote possibility.
The pedal has a lot of hardware to run from a 9 volt battery and I would NOT exoect much life out of one.
Sep 22, 2010 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
I turn on the Pedal and all sound is gone turn it off and the sound is still gone
Contact Roland (UK) Ltd on 01792 702701. Speak to a service engineer who will tell what is required. If it is a replacement part, they will send it.
Jul 01, 2010 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
My Boss DD3 just beeps and nothing else when i turn it on
If you have experience with electronics you could take it apart and use a multimeter. My guess would be one of the delay chips but its something hard to diagnose without taking it apart. An audio tech could help you out. Chances are it would be a pretty cheap fix. Unfortunately Boss pedals are almost entirely surface mount so replacing a component or two takes more skill than the average pedal.
May 16, 2009 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
Music Logo
Top Boss Music Experts
Michial Gueffroy
shaun taylor
drivealot
Are you a Boss Music Expert? Answer questions, earn points and help others
