Question about Grilling
My oven won't turn on its a chief master 905kb . Can't get any power in oven at all
Chief master 905kb
  • 11 Answers
SOURCE: Lil Chief Smoker trips GFI plug
There is a short somewhere in the unit. Return it ASAP!
Posted on Jun 26, 2009
  • 6 Answers
SOURCE: Replacement Parts - Lil Chief
Try www.smokehouseproducts.com or any Cabela's or Sportman's Whorehouse, I mean Warehouse or any big box sporting goods store in general. The heating element is a hard one because it's probably the old style ceramic disk. We have two like that. They run on 175 Watts instead of the newer 250W using the "O" shape elements. They're $29.99 + s/h, we want to try to convert ours to the newer 'O' shape if possible. The elements are around $12.00 at Wally World. Best of luck!
Posted on Jul 31, 2009
SOURCE: 1987 Jeep Cherokee Chief power windows do not
jeep cherokee laredo 1987 problema que cuando suve una pendiente empiesa a vibrar.
Posted on Apr 10, 2010
hunter19_46m
  • 7482 Answers
SOURCE: I need instructions on using
Hi jmcomber..
To use your Brinkman,Luhr Jensen Smoker or Other Smokers
1... Marinate or place a rub on the meat you will be smoking, and let it sit for a few hours or over night in the refrigerator.
2...Cover your wood chips with water(and if you wish you can add some Jim Beam Whisky or other flavorfull liquids in a bowl with the water, 1 inch above the wood chips and use a flat peice of metal (pie pan,etc.)to weigh the wood chips down underwater.
3...Start a fire in the smoker having the fire below the meat, use hardwood or charcoal,
Once they are coated with gray ash, you can place the meat on the racks.
I would place an aluminum drip pan under the center portion of the cooking area on your smoker, to catch the juices from the meat.
4...Place the meat in the smoker on the grilling surface, and place the wood chips over the charcoal and hardwood in the main grilling area Close the lid and do not open it unless you must add wood chips during the cooking process.
5...Continue adding wood chips to the tray as needed during the time you are cooking.
If you have a Brinkmann or other smoker with one chamber for placing the wood chips and the meat, add wood chips only once per hour.
6...Apply your sauce to the meat one hour before the meat should be done.
Test your meat with a thermometer for for an internal tempreture of 160 degrees for medium and 170-180 degrees for medium well to well
Note: Apply the sauce quickly to avoid loosing the heat in your smoker if you leave it open too long it will allow the heat and smoke to escape, increasing the cooking time.
Close the lid if it needs to continue cooking till you reach the right internal tempreture
7...Test your meat with a meat thermometer after a few hours of cooking time.
Make sure your meat is at least 160 degrees internal tempreture for medium and more than 170 degrees for medium to well.
Close the lid and maintain your heat if it needs to continue cooking.
Please take time to rate me.
Posted on Aug 05, 2011
bobicehouse
  • 1524 Answers
SOURCE: Magic Chief Freezer MCCF7W power light is
Most likely loose connections at the light. Try removing and checking. Usually can pry loose with a flatblade screwdriver.
Posted on Oct 15, 2011
2009 Indian Chief Vintage will not turn over
Hi, Johnny before testing any electrical component in the Starting Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Engine Run Switch is "FAULTY" or corroded.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
5. Bank angle sensor needs a reset or is faulty.
6. FOB battery low or dead.
7. Faulty ignition switch.
8. Faulty starter button.
9. Faulty kickstand, clutch, neutral safety switch.
10. Security alarm needs a reset.
11. Starter relay, solenoid, starter motor or circuit wiring faulty.
12. Starter armature or field coils have failed.
13. Main fuse or circuit breaker may be blown or faulty.
14. Faulty ignition relay.
15. The electric starter is working but starter clutch has failed.
16. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2014 Vintage Won start in the Cold
What to do When Your Motorcycle Won Start
Indian Motorcycle Chief Classic Service Manual
Indian Chief Vintage Parts
Indian Motorcycle Chief dark horse Owners Manualual
Jan 19, 2018 | 2009 Indian Chief Vintage
Who won last night master chief
This item does not belong in this forum
Sep 21, 2017 | Miscellaneous
I have a 9M i purchased approximately 10 years ago. The weapon does not want to fire the first three rounds for the magazines. what do I need to do to get it repaired?
Suspicious!!!! A chief of police not knowing it as a 9mm or stating manufacture? Just a bit odd.that you are asking very fundimental question when if you were a trained law enforcement officer you would have the answer and if you really had a problem your department armor would be your source for answers
Jan 07, 2017 | Firearms
Can a billionair own a small local airport and become a owner of a charter airline, chief pilot and airport police chief all by himself?
He would be stretching himself too thin to do it all at once. Airport police chief would require all his time spent on the ground, so being a pilot is possible, it would be impractical.
Jan 04, 2017 | Aircrafts
2011 Indian Chief Roadmaster motorcycle cam chain shoe tensioner problem @
Hi, Janet for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Indian, despair not, for a mere zero $0 you can download another one.
2011 Indian Chief Roadmaster motorcycle cam chain shoe tensioner problem...
TS111 cam chain tensioner wear after 32 000 miles
Motorcycle Service Parts Part Finder Indian Motorcycle Store
Jan 24, 2015 | 2011 Indian Chief Roadmaster
I need a new electric heating element for my Little Chief smoker
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dsporting&field-keywords=Little+chief+replacement+element&rh=n%3A3375251%2Ck%3ALittle+chief+replacement+element Here is one source....
Jan 15, 2013 | Grilling
Magic Chief "Chateau" double oven,
I just had the top completely off of our Magic Chief, which I love and refuse to part with, to fix a problem with one of the burner switches. I believe if you pry up gently in the crack in front with a blade, i.e. small pry bar or screwdriver, being very careful to not chip the paint, the top will snap loose from the two prongs that hold it in place. Then if you disconnect the cluster of wires going to the burners, which is very easy to do, (they just plug together) and remove one screw holding the ground wire toward the back, you can lift off the whole top and get to all of the good stuff. I find the quality of our old Magic Chief Chateau to be of exceptional quality, much better than I see today and I'm pleased that our burner problem was just loose screws. Good luck.
Jan 02, 2011 | Magic Chef Kitchen Ranges
Mar 15, 2009 | 1987 Jeep Cherokee
Grilling Logo
56 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
