Question about Cell Phones
Suddenly for no reason my phone blurts out a tune that I have never heard. I'm not touching the phone and it stops after 10 seconds.
Whi iphone5c suddenly stop working and e charged either?it went off and does not get to be charged either? b
Press down your "home" and "power" buttons at the same time for about 10-30 seconds. Make sure the phone is plugged in while you are doing this. The apple logo should appear after 15 seconds or so. Once it appears, your phone should be good to go!
Feb 15, 2014 | Apple iPhone 5c
My Philips AJ3980 radio suddenly has no sound. Also, the band "MW" appears in the display and I'm unable to tune AM stations. The clock seems okay. Thanks for your help!
1. Press the RADIO button to switch on the radio.
- Radio touch screen controls appears throughout
radio operation
- The radio frequency and waveband appears in the
display for 10 seconds before reverting back to the
clock display.
2. Press the BAND button to select your waveband FM/AM.
3. Tune to your station manually or automatically
by using up / down.
Here is a figure to help find the control buttons:
Please change waveband to FM.
Thanks.
gylacz
Jun 20, 2011 | Philips AJ3980 Clock Radio
While i was typing an s.m.s,the touch screen suddenly stopped responding.
HI,it depends on the phone you are using if it's a flex phone (slide phone or a phone that has not slide.
Slide phones,
The reason your phones touch screen is not working is simply because there is a problem with the flex of the phone.
If the screen is not damaged in any way, then the assumption of it being the screen is absolutely correct.
To fix the flex of the phone;
1. Get the appropriate screwdriver,
2. remove the battery, the battery cover, and your sim,
3. Turn the back of the phone,
4. you will see five rubbers,
5. pick them off with a pincher,you will see screws under them, unscrew the phone,
6. Get a credit card and slip it through the line around the phone then apply a little force in separating them apart,
7. you will see the panel of the phone, carefully lift it up,
8. you will see a flex that runs through the screen to the panel, carefully detach the flex from the panel,
9. unscrew the screen of the phone, remove the flex connected to the screen also and replace it.
10. Reverse the process to reassemble the phone.
Not a slide phone,
You will have to replace the touch screen with another one for it to function properly again.
Take care .
Aug 22, 2010 | Cell Phones
All of sudden my samsung star mobile's touch pad stopped working. I am using this phone since last 10 months and it was working absolutely fine since then.
I rily want 2 know wat makes the touch pad of a samsung star 2 just stop working,because it just paralyses everything
Aug 02, 2010 | Samsung Star GT-S5233 Cell Phone
NO SOUND FROM MY SAMSUNG S8300
the sound in my phone s8300 is low can I up sound
Jun 22, 2010 | Samsung S8300 Ultra Touch platinium-red...
Touch screen suddenly stopped working i am unab...
when a phones touch screen malfunctions, it means that the touch pad is damaged seriously and it needs to be replaced.
Mostly it is caused by dropping the phone on the flow, hitting it on something or even pressing the touch screen pad with the wrong instrument.(any sharp object).
You can take it to a here by store for a replacement of the touch pad.
NOTE: phone is very delicate needs to be handled by an experienced personnel.
Take care.
May 20, 2010 | Cell Phones
Touch screen on lg vue will not respond at all!!!
your touch sensors have gone out. If there is any on off touch screen faulty's to where u can click once every while.try to get to touch calibration. If u do and it doesnt out, read the first sentence over.
Apr 29, 2010 | LG Vu CU920 Cellular Phone
2nd generation ipod touch has suddenly stopped working. Can only get apple on screen and that turns off in less than half a minute and has to be turned back on again. Can't get to any other screen or...
Hold the power button and home button for 10 seconds to ensure the device is off. Let go.
Hold the home button down, plug in the ipod to the computer, after the screen changes to the itunes plug screen, let go of the home button.
The ipod will now be in recovery mode, and you can attempt to perform a restore within itunes.
If the restore fails, and the ipod screen stays black, this means the battery is dead and must be replaced.
Nov 05, 2009 | Audio Players & Recorders
Television suddenly turns off.
Try to get a firmware update. THis happened to me and I got a firmware update from Mitsubishi and now all ok. Call Mitsubishi
Nov 12, 2008 | Mitsubishi WD-52725 52". Rear Projection...
M600i touch screen
Past experience shows you will not satisfactorily resolve this problem until the LCD panel is replaced. Spares are reasonable easy to source, e.g. (ebay.com, item number 280296211660).
Oct 25, 2008 | Sony Ericsson M600i Cellular Phone
Cell Phones Logo
21 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
