Question about Utilitech 1-HP Cast Iron Shallow Well Jet Pump PPSWJ100
Where can I get a new seal for my Utilitech 1-HP Cast Iron Convertible Jet Well Pump model number 0752650
We had to take about it and the seal no longer seals and leaks where can I get replacement ones
2 Suggested Answers
boysor2933
  • 293 Answers
SOURCE: I have a Utilitech 3/4 HP jet shallow well pump #0003134. On start up, it hums a long! time before turning, sometimes tripping the 15 AMP breaker. Anything I can do?
Try replacing first the capacitor. If it will not solve your problem, check the integrity of the motor winding insulation by doing a line to body resistance measurement. If it is okay, replace the motor bearings.
Posted on Nov 06, 2012
Why doesn't it shut off?
Your well could be dry, your screen could be clogged, you could have a major suction leak, your press switch could be bad, or your impeller could be broke.
If you are getting water, I'd say that your press switch is faulty.
Feb 24, 2016 | Utilitech 1-HP Cast Iron Convertible Jet...
Pump shuts off at 20psi
you need a new pressure switch or adjust the old one for a higher limit ,
Dec 30, 2015 | Utilitech 1-HP Cast Iron Shallow Well Jet...
I have a UtiliTech 1/2 HP Jet pump #0003124. I need a manual. Can I get a larger volume impeler for this mode?l
Put a vacuum gauge on the suction, see if it goes real low after pumping a couple of gallons. If so, your point may be stopped up. A 1/2 hp pump should pump 40/50 psi, fill a 5 gal bucket in a minute or so.
Jul 29, 2015 | Utilitech 1/2 HP Convertible Jet Pump...
Why does my pump loose pressure
Sounds like your not using enough water, and or your pipes to sprinkler is to to small, causing pump to build up to cut off head. I cant lay my hands on a performance chart for your pump, but 60 psi cut off and 20 on sounds about right. Try running another tap when your sprinkler is running, and see if this keeps your pump running
Mar 25, 2015 | Utilitech 1-HP Cast Iron Convertible Jet...
Blade wont spin
Impeller is loose on the shaft, or coupling is broken if it has one.
Jul 30, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Why is the pump not shutting off after the faucets are turned off
It should turn off after it pressurizes again. Might take a minute.
Jul 26, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Can the pressure switch on the Utilitech 1hp convertible shallow well pump be changed from 20/40 to 30/50?
Yes, if the plumbing can handle the extra pressure. There should be a nut in the middle of a large spring inside the pressure switch. Turn that nut clockwise to increase the pressure. You may need to run some water to keep the pump cycling while you do this.
Jul 24, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
How to fit seal on fluidmaster flush valve
before you replace the seal: inspect the bottom seal by running your finger around and inside the rim. not likely but could be a burr. If the seal is OK, install a new flapper bulb. while the old one may look fine, the rubber may have hardened and thus will no longer seal properly. It's an easy fix, just be sure to get the correct replacement bulb. AND/OR, buy some silicon plumber's grease. A small container costs $3 or so. Spread the grease on the bulb and the seal-rim; where the two pieces meet to form the seal. Should provide a better seal.
Jul 05, 2014 | Plumbing
Is it a mistake to not replace pool pump bearings?
If they are noisy Yes also replacement of the pump seal is very important. We recomend replacement of the seal every 2 years if pumps is used to vacuum pool.
Jun 03, 2014 | Sta Rite Max - E - Pro 1 1/2 Hp Dual Speed
Utilitech 1-HP Cast Iron Shallow Well Jet Pump PPSWJ100 Logo
147 people viewed this question
Top Utilitech Plumbing Experts
Paul Carew
jhnolson
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
