Question about Beko Dishwashers
I have a Beko D3422fs dishwasher and the water leaks out. I did a self clean on it but ever since there have been problems. The glasses and stainless steel items have a residue as well.
    New Friend:
  • 20 Answers
Hath su dhole
Posted on Dec 19, 2016
Testimonial: "What does this mean??"
My Beko dishwasher is leaking water from the hot air dryer hole on inside left of machine?
U must clean it. The handyman have special things to repair i and clean it. call him. ull do better then the asking on the internet.
Dec 23, 2017 | Beko Dishwashers
Beko DSFN6830 dishwasher repeatedly flooding itself.
it sounds like the round float toward the left front of washer is not rising to cut off water. I have had this happen to mine. u need to see if it is stuck try moving it up and down to make sure it moves freely
Apr 06, 2014 | Dishwashers
Dishwasher fault finding
you water level in your dishwasher is probably low if you change your water valve and run a dishwasher cleaner through it that will solve your issue
Dec 30, 2013 | Beko Dishwashers
When we switch our Beko DE 2541 on its running straight away with the stop/start button being pressed. On the last successful cycle completed it just carried on making a noise like it was running and has...
sounds like you have a water leak. The machine is fitted with a leak detection device that runs the drain pump constantly as a safety mechanism. If you want to look your self you will need to pull the machine out and tilt it back and if possible remove the bottom panel, should be 4 screws, this gives you access to the components. Then see if you can see where the leak is coming from. Hope this helps.
Feb 23, 2011 | Beko Dishwashers
BEKO DSN 3720 leeks water from bottom of door
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Sep 16, 2010 | Beko Dishwashers
Water is not going into beko dishwasher de2542f .you can hear and feel water going through the pipe but is not going into machine
My BEKO dishwasher is turned off but there is a constant dribble of water running in to the machine. If I open the door when this has happened, it leaks water all over the floor. This means I have to keep turning the machine on to drain the water away.
Feb 06, 2010 | Beko 24 in. D3731F Free-standing...
I have disconneted a pump to the Beko D3422FS to check and clean the impeller. Sadly I didn't take clear enough notes on the wiring connections and the macine is now tripping the mains. Does anyone have a...
i downloaded some circuit diagrams from rapidshare after contacting an expert on justanswer.com.
http://rapidshare.com/files/344031734/d3422fs_2.pdf
http://rapidshare.com/files/344031301/d3422fs.pdf
Alternative locations:
http://ww2.justanswer.com/uploads/Techdesk/2010-02-01_072933_d3422fs.pdf
http://ww2.justanswer.com/uploads/Techdesk/2010-02-01_072958_d3422fs_2.pdf
There are three wires on the base of the motor, Red, Brown and White.
The White conects to the double violets on a conector
The Red to one side of the capacitor (side nearest the motor)
The brown one caused a lot of confusion. I believe this attached both to the yellow connection and then onto the spade connection on the other side of the capacitor.
This is one I slept on, and had an Epiphany.
The circuit diagrams didn't apear too clear to me. They don't sem to indicate which connections go to the capacitor, just the pump cluster as a group. I may be wrong, but have connected as above and will get the father-in-law to check them before I plug the machine back in.
Jan 31, 2010 | AEG Dishwashers
I have a Beko D 2731 FW its about 4 years old and recently it has begun to leave a gritty deposits. I think this may be due to the top spray arm not running as freely as it used to. I would appreciate any...
Here are a few things to check.
* Worn wash impeller (depending on design). Test by placing a glass upright in upper rack with full charge of water in the basin. Run dishwasher for 30 seconds. Glass should fill up. If not, replace wash impeller.
* Debris caught in spray arm holes. Remove spray arm and clean out with water and compressed air.
* Heating element burned out. Check water temp during wash--should read between 130 to 140 F.
* Insufficient water fill in basin. In most models, proper fill level is just up to the heating element. Much less than this will result in poor cleaning.
Hope this helps.
Sep 08, 2009 | Beko Dishwashers
Beko 2431 dishwasher not working
I have the same problem
dishwasher seems to try to wash but not get anywhere.
have tried tipping dishwasher to empty excess water out, filters and arms cleaned.
dishwasher just takes in water, hums for a bit and then the cycle ends after about 20 mins but obviously dishes are not clean
Jun 05, 2008 | Beko 24 in. D3421F Free-standing...
BEKO D3422FS
check that there are no kinks in the drain pipe or that the pipe way is clear.
Thanks J
Oct 23, 2007 | Beko 24 in. D3421F Free-standing...
Dishwashers Logo
46 people viewed this question
Top Beko Dishwashers Experts
Eric Taylor
Paul Carew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
