Question about Samsung Televison & Video
I have a Samsung LED HD TV Model # UN75H7150AF and I would like to know how the back panel should be removed. I have the screws out but want to know what to expect as I try to remove it.
I want to visually inspect the Power Supply board for any obvious issues and then check output voltage to see if operating properly.
    New Friend:
  • 20 Answers
Badwe re khoriye re de
Posted on Dec 19, 2016
Testimonial: "Please answer in English"
How can I remove rear panel?
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 17, 2016 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Samsung 50" led un50h6350. The TV is about 18 months old and the picture went out, the audio and back light are working. I've replaced the t-con board and that didn't fix it. Someone please help!
Samsung LED TV Screed goes blank periodically for 1 sec - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - Lately, my Samsung LED TV's screen will black out from 1 -2 seconds then come back. The TV has been ... The TV is about 6 months old. .... I've only notice this when I'm watching in HD. ... by Stlouib / January 13, 2012 11:18 PM PST ...Mine does the same thing - picture goes black for 1 - 2 seconds and then comes back. Samsung Series 3 (330), won't show any picture/no sound?
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
More results from www.cnet.com
Are there still capacitor problems with Samsung TVs?
Dec 21, 2015 | Samsung Televison & Video
How do i know im getting full hd on my samsung tv
There is far more NON-HD material than HD out there.
This will change with time but isn't there yet.
Oct 14, 2014 | Samsung 46 UE46F5000 Full HD 1080p E-LED...
Remove stand
You actually have to remove all of the screws around the perimeter of the stand - even the hex screws. Once you remove these, the base slides out! Don't remove the entire back as I saw posted on another site.
Aug 27, 2014 | Toshiba 65" Class 64-1/2" Diag. - LED - 4K...
Need to remove base on nAXA Model NTD-1354
I needed to do this as well. The round part comes off but the stem does not come out of the TV. I don't mind taking things apart so I removed the screws on the back all around the frame. There are two screws right above all the hookups that you don't have to remove. After removing the screws, carefully separate the two halves. They snap togetther together on the middle of the sides. It takes a little effort to unsnap them I just kept running my fingernails up and down the seam until it popped apart. The screen half come off and is connected with some wires so don't pull it to far apart. At this point you can access the two silver screws that hold the stem in place. Remove the screws and the stem can be removed. Now snap the two halves back together (being careful not to pinch any wires) and re-apply the screws. I saved all the parts for the base in case I needed to put it back together. Last note, opening anything like this may void any warranty.
Aug 14, 2013 | Naxa 13.3" NTD-1352 12V HD LED AC/DC...
Whats involved in installing a new power supply board in an HP-T5404 Samsung Plasma TV?
hmmmm its easy really..
  • unscrew rear cover
  • cables from power board to other components
  • unscrew and remove power board
  • put in new board and screw down
  • re connect cables
  • screw back on the rear panel
  • plug in
  • turn on
  • watch!!
Sep 14, 2010 | Samsung PS50P7H 50 in. HD-Ready Plasma TV
Color problem
hi it could be a loose cable in the back of the tv
Jan 10, 2009 | Samsung LN-R328W 32 in. HD-Ready LCD...
Samsung
On the back of the tv at the top of the stand will be four silver screws, remove those with the set laying on it's face or the tv may fall over. after those are removed the stand will slide out of the bottom of the tv. Hope this helps.
Mar 11, 2008 | Samsung LTM1755 17 in. HD-Ready LCD...
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Televison & Video Logo
65 people viewed this question
Jerry Greenberg
Jerry Greenberg
