Question about Bunn Coffee Makers & Espresso Machines
I can't get the spray head off of my Bunn Coffee maker. It seems to be stuck.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • Bunn Expert
  • 289 Answers
Bunn spray heads are about the size of a 50 cent piece. They should unscrew counter-clockwise. Only these round ones unscrew. Call your vendor to have them checked and replaced as needed. They do get very dirty if not wiped down daily. They should be serviced every 6 months (minimal service) you can still wipe and clean them with a tooth brush or portafilter brush (espresso brush) while still on the brewer.
Aloha, ukboy57
Posted on Jan 20, 2018
SOURCE: my bunn coffee maker leaks
You need to replace the washer kit inside the top of the maker. Remove the 3 screws that fasten the top and lift it off. You will see the rocker leaver that allows the water to flow into the tank. At the point where the rocker stops the water there is a series of washers that degrade from the heat over time and allows the leak. The washers are very easy to replace. The problem is finding the washer kit. I found it at: www.buyitnow64.com for $3.95 plus shipping (FedEx is only $9.98). I bought 2 (one for backup) kits.The original washers lasted almost 6 years. I had repaired this problem before with a washer from my shop but it broke down rather quickly from the direct heat from the tank. This washer kit is a Bunn washer kit that is supposed to fit all Bunn machines both residential and commercial.
Hope this helps. It took me 2 hours on line to find the washers!
Posted on Dec 11, 2008
  • 131 Answers
SOURCE: Water supply for Bunn coffee maker
open the cover on the brewer- depending on your model, it could be the front or the back cover. look for a brew timer dial. turn this up slowly, running a brew each time to see if you now have a full pot
Posted on Feb 10, 2009
  • 131 Answers
SOURCE: Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Posted on Feb 13, 2009
  • 189 Answers
SOURCE: I have a bunn coffee maker the NHBX is the # it is
Please give Customer Service a call with the model and date code. If the machine is 3 years old or less, it will be replaced with a new machine. If it is older than 3 years, it can be exchanged for a reduced price.
Posted on May 19, 2010
SOURCE: Tim Hortons Bunn Coffee Maker Instructions
which way do the gaskets go together in the reservoir of the tim hortons bunn coffee maker
Posted on Mar 15, 2011
Bunn cwtf20-3 makes weak coffee
When you pull the basket out after its finished brewing what does the surface of the coffee look like? Are there 6 or so clearly defined dimples in the surface where the water pours from the spray head? Is the powder uniformly wet? If the answer is no to either of these, remove and clean the spray head. Use a descaling tablet or powder to soak the spray head and then use a small tool to clear the holes. Be careful not to make the holes bigger though.
Aug 08, 2013 | Bunn CWTF20-3 Automatic Coffee Brewer -...
Weak Coffee
First think to check is the spray head which pours the water onto the powder. remove the spray head, clean it and soak it in descaler.
reassemble and do a brew. When finished check the surface of the coffee has 6 dimples where the water has poured onto it and that the coffee is uniformly wet. If no dimples or dry spots, get replacement spray heads.
Jul 27, 2013 | Bunn VPS Coffee Maker
Will not brew
Make sure the coffee maker is full of water. Keep filling it till water comes out of spray head.. Should take two full pots plus 3/4 of another one. Wait for water to stop coming out of spray head. Now the unit should be ready to brew after it heats up.
Mar 29, 2013 | Bunn VPR Coffee Maker
Bunn coffee maker ITCB-DV not pouring enough water
The pulse program does not result in lower volume. The control board adds time to account for the pulses. If you are encountering less water than before clean your spray head and spray head fitting. 75% of low volume service calls are from calcified spray heads.
Mar 29, 2013 | Bunn Infusion ITCB DV Coffee Maker
Bunn nhb coffee maker leaking from spray head repair
CHECK THE WATER INLET SOLENOID. SOMETIMES DEBRIS( METAL/PLASTIC) ARE STUCK UNDER THE TINY ORIFICE KEEPING THE VALVE OPEN OR THE PLUNGER IS CORRODE/SPRING DAMAGED/WEEK. THAT WOULD EXPLAIN THE MALFUNCTION.
RUDY.KY
Oct 15, 2017 | Bunn NHB Coffee Maker
The water dont seem to brew all the coffee in the filter....parts of the coffee is still dry....i have cleaned the pot and spray head and empty the tank and refilled with water...my bunn is only 3 months...
It sounds like you are either missing a sprayhead or need the flow restrictor sprayhead. If you will call customer service at 800-352-2866 we will be happy to resolve this issue for you.
Sep 17, 2010 | Bunn 10 Cup Home Coffee Brewer
Water flow has slowed down.
remove the spray head and clean it .also run the cleaning spring through the spray head tube this is what makes them slow down is minerals in the water.
Jul 02, 2009 | Bunn NHB Coffee Maker
My bunn coffee's spray head does'nt stay screwed in, i've lost 2?
likely the threads are stripped in the shower head, get a new one from bunn, or an appliance store
Dec 10, 2008 | Bunn NHB Coffee Maker
Bunn commercial coffee maker does not pour water
clean your spray head by removing it and at the same time run the cleaning spring up through where the spray head screws to. before replacing spray head place your pot under and pour a pot of water through,to rinse.when done replace spray head .wait for it to heat up and your set to brew again...
Oct 28, 2008 | Bunn GR10 Coffee Maker
Coffee Makers & Espresso Machines Logo
189 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
