I tried those suggestions and the heads are still cut off on my tv
How do I access advanced menu options so I can adjust overscan settings?
get to the on screen tv menu and look for aspect ratio change that ,save and exit
May 18, 2015 | Toshiba 32ZH46P
Pioneer plasma tv picture is cutting off heads
Issue may be adjustable in the Tech menu with your remote---you need to see if you can find the service manual (with schematics and information about getting into that menu and how to adjust).
Try to GOOGLE MODEL NUMBER WITH service manual or contact Pioneer.
Mar 21, 2012 | Pioneer Elite PRO-151FD 60 in. Plasma TV
Replacing the cutting head on Ryobi string trimmer.
There is a nut above the head, place a wrench on the nut then unscrew the head from the shaft, unless yours is different from mine this is how it works. I hope this helps.
Jul 05, 2009 | Garden
Don't know how to advance cutting wire.
Did you try bumping the head on the ground? Also, the head could be dirty, keeping the string from feeding. Or maybe the previous owner tried putting a larger size string in the head. Check to see what the proper size is for your trimmer.
Both of these suggestions could cause this.
Jun 03, 2009 | Craftsman Garden
My Vizio TV screen cuts of heads.
have you tried pushing the "zoom" button?
Mar 20, 2009 | Vizio L32 32 in. LCD HDTV
Picture NOT Alined
Use the zoom for picture adjustment.
Feb 08, 2009 | RCA D52W23 52" HDTV CRT TV
46 inch at least 3.5 yrs old
Has he tried both the aspect on the tv remote and for the cable/satelite box both? These both have their own aspect settings.
Feb 21, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
The head phones
i suggest that you should try other head phones. if it is ok the i suggest that you should replace your head phone. If still have the same problem the problem is with your phone jack.
pls rate me
Jan 21, 2008 | Apple iPod MA446LL/A MP3 Player
Heads cut off and no score...
Try your setting on your cable box (Screen position)
also maybe wide mode try switching to wide zoom good luck
Dec 10, 2007 | LG 42LC2D 42 in. LCD HDTV
Heads Cut Off
Is it in zoom 4:3 or zoom 16:9? Use the left/right arrows to change it.
May 06, 2007 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
Top Televison & Video Experts
