Question about Casio Watches
Sir..my casio watch second hand isnt moving suddendly and the minute hand is moving freely.
  • 16 Answers
Hi Sanen
What model is your Casio watch?
For what you describe it would appear as if there is a problem with the cockwheels assembly on your Casio watch. Most likely as a result of a severe impact. hard enough to dislodge the retaining plates or break of the bottom of the minute hand spindle.
Hope this helps
Posted on Feb 12, 2017
SOURCE: Ta Heuer Professional stopwatch minute hand reser to 12 position
pull the crown on first click and push the upper button until it reaches to your desired position.
Posted on Mar 20, 2008
SOURCE: lost maual to amw-700 casio watch
advance the mode 6 times to H S mode and push left upper button till the digital time flashing, then push rigth doun or up buttons to advance, please read manuals
Posted on Jan 20, 2009
freetek
  • 5568 Answers
SOURCE: the second hand stop moving but the watch is still
The hands of an analog watch are often only press-fitted on the shafts (hour and minutes are tubular, seconds solid shaft) and the second hand has probably only slipped so it is no longer being driven. I suspect a watch-maker could reattach it for a small charge.
Posted on Sep 25, 2009
SOURCE: The second hand of my Tissot watch T870/970 starts and stops.
Hello!
Absolutely astonished by this "solution" from escapement.
This watch is working perfectly - it is simply giving its "end of battery life warning".
Posted on Dec 11, 2009
escapement
  • 2334 Answers
SOURCE: need directions on how to move analog hands on
Check out my tips here and find the instructions manual for your watch.
Posted on Feb 07, 2010
On my casio edifice 4334 module and the digital works fine but the analog i can see the minutes handle trying to move but not succeeding , seems to me like it is stuck thanks in advance.
Check if the battery is still in good condition. If this doesn't solve the problem, swipe a magnet over the back of the watch in different directions until the minute hand moves. Take care not to scratch the watch with the magnet. It may be necessary to oscillate the magnet several times at the correct position and direction until the minute hand moves freely.
Sep 26, 2015 | Casio Watches
Casio edifice EF527D-1AV
Do you realize that this watch has a screw down crown to keep it waterproof?
Hold it in and turn it clockwise to lock it down.
Let me know if this helps.
Mar 11, 2014 | Casio Mens EF527D-1AV Edifice Stainless...
Mintues hand problem.
There are two reasons for this. First- you distorted minute hands hole and now it is not sitting tightly on pinion. Second- when you pulled off the minutes hand, you lifted cannon pinion. As the result it is loose and swings freely. I do understand you have no knowledge how the watches are build, so, visit your nearest watch repair shop and ask to fix it. Please, do not take it personally - it is just because you can't do that without watchmakers knowledge, so, save your nerves, time and watch. Rate me, plz.
Mar 18, 2010 | Timex 27191 Wristwatch
Citizen AT03060-50E,i bobught online kind cheap than showroom so still am confused that it is original or not.. my chronograph second and minute hand stops after 1 hour,the small chronograph second hand...
The chronograph will only run for 59 minutes 59.95 seconds.
If you do not have a set on instructions for your watch, you can find one on their web site (citizen.com)
When there, click on "technical support" and the on "setting instructions" and fill in the number off the back of your watch.
Feb 01, 2010 | Citizen Eco-Drive BL5184-56L Wrist Watch
Minute hand and second hand
There is a tool available in the market to remove second hands.
If you have a watch screwdriver you can easily remove both the hands. Just keep the screwdriver in between minute hand and second hand and gently twist the screwdriver. But be careful, it may damage the dial.
Sep 07, 2009 | Casio Watches
Casio Lineage Waveceptor 4717 minute hand off by 20 seconds
You would have to remove the movement from the case, remove the hand and reinstall it, to where you want it.
Aug 06, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Casio 4305 runs 5 minutes slow.
No reason to panic as your watch hands can be advanced to desired time. Her is the link for your watch users manual download:
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=4305&submit.x=52&submit.y=12
Save it on your PC and follow instructions how to set the time.
Don't forget to rate, please.
Jan 05, 2009 | Watches
Casio watch
Press MODE until you reach H-S (e.g. A 11:00 with seconds on top)
Press and hold ADJUST for 3 seconds until H-S blinks
Press and hold SEARCH for every movement; you may wanna press LIGHT so the hands will move freely. Press ADJUST again to when desired time was reached
Oct 21, 2008 | Casio Watches
Instructions for casio wave ceptor 4303
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Nov 06, 2007 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Watches Logo
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
