Question about Gbc Office Equipment & Supplies
GBC Shredmaster 2260x lights flash when plugged in then go off. It wont run.
2 Suggested Answers
SOURCE: Seeking online owners manual for GBC Shredmaster 2260x
http://www.gbcconnect.com/assets/docs/2260X.pdf
Posted on Jun 03, 2010
Gbc shredmaster 5550x: this machine has badly worn plastic gears & one has teeth missing. Is a rebuilt drive unit available?
For an answer to this question, you will have to inquire through the manufacturer, or perhaps, there will be a advertiser who does this type of work whose name will come to you along with this answer. Look around on this page right now.
FixYa.com is not a parts or repair depot.
Thanks for your question today at FixYa.com
Jan 27, 2011 | Quartet gbc Shredmaster 5550X Confetti-Cut...
I have a GBC Shredmaster 2260X. The light on top is blinking that means that the cabinet front foor is not shut. When the front door is shut. I have tried everything I can think of. And it wont work...
most GBX shredders have a magnetic "reed" type switch inside the shredder head that is actuated by a magnet on your door. have you recently lost the magnetic catch on your door? if you have lost it and have access to a strong magnet, you should be able to open door and move magnet around on front side of shredder head and see the light go out. if magnetic catch is on door, then perhaps your door is misaligned in such a way as to not energize the switch.
good luck,
razors
Jan 10, 2011 | Quartet gbc Shredmaster 2260X...
GBD Shredmaster Model 2260X about one year old...door close switch was intermittent and now does not show "closed" at all even when the switch is deflected. Is the problem likely to be in the switch or on...
If blowing some canned air into the switch doesn't cure the problem, the switch will have to be replaced.
Try Radio Shack or an electronic supply store.
Also, check the door alignment screws.
Sep 28, 2009 | Quartet gbc ShredMaster 2260X Cross-Cut...
DISCONNECTED WIRE
I clipped all the zip ties to free up the harness and physically inspected every connector till I found a connector that seemed rather loose and came off with minimal force. I then gathered the 3 wires and install a #18 wiring nut. the shredder is fully functional again.
Jun 03, 2009 | Quartet gbc GBC 10-Sheet Cross-Cut...
How to fix a stuck shredder
get a pair of needle nose pliers and pull the jammed paper out. (you may need to figure out how to pop off the top cover to get better access to the blades)
May 27, 2009 | Quartet gbc ShredMaster 950S Strip-Cut...
My GBC Shredmaster 2260X is jammed and I can not clear it. The teeth try to rotate when stimulated but something is jamming it. Where can I go for service? I am in murfreesboro, TN.
you can do it yourself!! it take a little bit of time and patience. do it in an area that you can clean easily. take off and unplug the top, turn upside down, get a flat screw driver and start removing all the papers in the teeth area. from time to time you will need to put it bank and turn it on and make it go forward and reverse.
Sep 15, 2008 | Office Equipment & Supplies
56 people viewed this question
Top Gbc Office Equipment & Supplies Experts
George Mclaughlin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
