SOURCE: Ice maker freezing up
If it is only the fill tube that is freezing up, or getting full of ice, than your water valve is leaking (letting drops of water thru to your ice maker and filling the icemaker fill tube up and freezing). If this is the case, replace the dual water valve (part # 1071263) located in the back of the refrigerator, just follow the water line from your wall into the refrigerator. Make sure you turn off the water to the refrigerator and also unplug it. The dual water valve is the one that has two water lines, one going to the icemaker and one going to the water dispenser. On this model, I think you only have one water valve. On some you have two, the primary water valve and a secondary water valve (the dual valve). If this is your case, I would highly recommend you replace both. As far as the Refrigerator side freezing things up, I think that is a whole different issue. Please post back.
SOURCE: how to replace the ice maker unit.
I just RR'd mine. Undo the three screws on the bottom of the metal piece that the ice maker sits on, then the two screws that are horizontle above the . Take of the back, withdraw the termocouple from the tube that goes through the foam, clip the wires (5) leaving enough of a pigtail to crimp a **** splice to the new ones. Withdraw the fill tube. Don't lose the clay that seals the holes through the insulation. Withdraw the ice maker by gently twisting and pulling straight out. Replace in reverse order. Getting the screws back in is a little tricky.
SOURCE: remove faceplate in door of a kenmore frig.
If you look at the bottom of the facial plate, underneath. There are two slots to insert a flat screw driver. You should be able to access everything once you take that off. Good luck
SOURCE: What do I use to clean the calcium deposits in the
CLR will work great, just rinse the ice maker very well after cleaning the calcium deposits and throw out the first few batches or bins of ice produced after the cleaning process. Good luck !
SOURCE: The ice maker no longer produces ice. I removed
For non dispenser models there's now a slotted fill tube that will fix the problem. Contact your distributor.
